scott(at)s-f-x.com Guest
Posted: Tue Dec 03, 2013 10:02 am Post subject: Cabin heat options ? |
Hi
Just curious what options have worked for installing cabin heat in Pulsars. My passengers seem to be getting cold even on mild winter’s days.
I did a search on the forum and noticed Barry (G-XPXP) has a small radiator with a fan but hoping there may be a conventional kit that fits/works to give lots of heat.
Cheers
Scott MacIntyre
23 Mellor Road
New Mills
Derbyshire
SK22 4DP
UK
UK Mobile: +44 7860 208432
US Mobile: +1 (818) 397-0666
Email: scott(at)s-f-x.com (scott(at)s-f-x.com)
pulsar1(at)sbcglobal.net Guest
Posted: Tue Dec 03, 2013 10:25 am Post subject: Cabin heat options ? |
I just ran across this inexpensive auto heater at Harbor Freight. I haven't tried it but when I saw it I thought that it might work in my Pulsar. Take a look.
http://www.harborfreight.com/12-volt-auto-heater-defroster-with-light-60525.html
To: Pulsar-List Digest Server <pulsar-list(at)matronics.com>
Sent: Tuesday, December 3, 2013 10:01 AM
Subject: Pulsar-List: Cabin heat options ?
Hi
Cheers
Scott MacIntyre
23 Mellor Road
New Mills
Derbyshire
SK22 4DP
UK
[quote]http:="http://www.buildersbooks.com/" target="_blank" rel="nofollow">http:www.homebuilthelp.com/" target="_blank" rel="nofollow">http://www.homebtstore.com/" target="_blank" rel="nofollow">http://www.mypilotstore.com-===================================
ghf4986(at)gmail.com Guest
Posted: Tue Dec 03, 2013 11:18 am Post subject: Cabin heat options ? |
What is your power budget look like. Rotax without a separate alternator only puts out about 12 or 15 amps! Usually this is used by other components.
I have the heater kit in my XP, but it never worked well until I got the oil temperature up around 200 degrees F, and thus the water temp up around 180. I have flown at 7 degrees outside air temp and have been comfortable, on a sunny day.
Dennis Adams
Sent from an IPad
On Dec 3, 2013, at 11:27 AM, George Gennuso <pulsar1(at)sbcglobal.net (pulsar1(at)sbcglobal.net)> wrote:
From: Scott MacIntyre <scott(at)s-f-x.com (scott(at)s-f-x.com)>
To: Pulsar-List Digest Server <pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)>
Hi
Cheers
Scott MacIntyre
23 Mellor Road
New Mills
Derbyshire
SK22 4DP
UK
uot;">www.aeroelectric.com
ldersbooks.com"">www.buildersbooks.com
"">www.homebuilthelp.com
"">www.mypilotstore.com
;">www.mrrace.com
uot;">http://www.matronics.com/contribution
ar-List"">http://www.matronics.com/Navigator?Pulsar-List
://forums.matronics.com
red five
Posted: Tue Dec 03, 2013 12:23 pm Post subject: Re: Cabin heat options ? |
The Pulsar 582 that I just bought has a collector on part of the back of the right radiator and a duct to carry the hot air to the cockpit. The builder said it worked good in Houston area cold weather.
_________________ Pulsar 582 n66em |
ronko(at)att.net Guest
Posted: Tue Dec 03, 2013 6:24 pm Post subject: Cabin heat options ? |
Scott,
I have a 582 that I did the plumbing to tee into the radiator coolant. I found a computer radiator that fits a 5 inch fan and has half inch threaded couplings that I used for the interior heater core. Works okay but the 582 thermostat opens at around 150 degrees which doesn't through off allot of heat at the heater core.
One thing that does work surprisingly well. I purchased a $20 electric car seat heater/cushion. It is both seat and back cushion with heater. On the low setting it consumes around 2 amps and on high around 3-1/2 amps. It heats up quickly and I feel the high setting is a bit too hot. I think the fiberglass construction insulates and contains the heat this device puts out.
I hope this adds to your options to consider.
Ron
Sent: Tuesday, December 3, 2013 12:01 PM
Subject: Cabin heat options ?
Hi
Cheers
Scott MacIntyre
23 Mellor Road
New Mills
Derbyshire
SK22 4DP
UK
="http://www.aeroelectric.com/" rel=nofollow target=_blank>http://www.aeroelectric.com/
/" rel=nofollow target=_blank>http://www.buildersbooks.com/
="http://www.homebuilthelp.com/" rel=nofollow target=_blank>http://www.homebuilthelp.com/
ofollow target=_blank>http://www.mypilotstore.com/
ow target=_blank>http://www.mrrace.com/
| Quote: | Dralle, List Admin.
ark>Un/Subscription,
more:
bakerocb
Posted: Wed Dec 04, 2013 4:26 am Post subject: Cabin heat options ? |
12/4/2013
Hello Scott, If you can come up with the electrical power resource electrically heated clothing is a very effective way to go. See here:
http://www.thewarmingstore.com/gerbings-heated-clothing-store.html?gclid=CKTaovHHlrsCFQPNOgodjzoAqg#.Up8e88RDt8E
OC
'O C' Baker says "The best investment you can make is the effort to gather and understand information."
Time: 10:02:13 AM PST US
Hi
Pulsars. My passengers seem to be getting cold even on mild winter=92s
days.
Cheers
Scott MacIntyre
23 Mellor Road
New Mills
Derbyshire
SK22 4DP
UK
barrynorman(at)comcast.ne Guest
Posted: Wed Dec 04, 2013 5:02 pm Post subject: Cabin heat options ? |
I use a Pontiac heater core and a five inch computer fan and route coolant through it in the winter. I also block one of the radiators to get the coolant temps up to about 180 when it's really cold. Plenty of heat. I use cable operated valves to route the coolant.
Barry
To: "Pulsar-List Digest Server" <pulsar-list(at)matronics.com>
Sent: Tuesday, December 3, 2013 1:01:36 PM
Hi
Cheers
Scott MacIntyre
23 Mellor Road
New Mills
Derbyshire
SK22 4DP
UK
_blank">www.aeroelectric.com
" target="_blank">www.buildersbooks.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
arget="_blank">http://www.matronics.com/Navigator?Pulsar-List
tp://forums.matronics.com
