I'm back and shopping for CJ
Goto page Previous  1, 2
Ernie
PostPosted: Tue Oct 08, 2013 11:50 am    Post subject: I'm back and shopping for CJ Reply with quote
Oh shoot, I thought this was off list.
On Tue, Oct 8, 2013 at 3:42 PM, Rico Jaeger <rijaeger(at)wausau.k12.wi.us>wrote:
[quote] Sorry to butt in here guys, but....can you tell me more about the
compressor failures??
On Tue, Oct 8, 2013 at 2:29 PM, Ernest Martinez <erniel29(at)gmail.com>wrote:
> Thanks,
> I like that you're using the Phillips, I've seen compressor failures with
> those who were using Exxon.
> WIll get back to you.
> Ernie
> On Tue, Oct 8, 2013 at 3:21 PM, Pete Fowler <pfdesign1(at)cox.net> wrote:
>> > How did you arrive at the engine and airframe times? Do you have the
>> original Chinese Logs? What overhaul # is the engine on 1st 2nd or 3rd?
>> The engine was purchased by Bob Watts (the previous owner) from Jim
>> Selby, it's believed to be first overhaul. It doesn't have original logs
>> but Jim is familiar with the motor. The airframe hours are estimated based
>> on a guess of 3500 hours in Chinese service. The plane has been in the U.S.
>> since 1991 (it's one of the first 10) so the US logbooks cover the last 22
>> years. The engine that's on there now replaced a 1200 hour motor that the
>> plane previously had that I believe Keith Harbor now has (he did the engine
>> installation back in 2007 or so).
>> The airframe hours were counted several different ways over it's life.
>> Eventually a hobbs meter was installed but given how much formation time I
>> do and how much time we spend on the ground (getting 5 or 6 planes across
>> the airport and warmed up and ready to go takes time), I personally do all
>> my maintenance based on tach hours.
>> > Was the ADF wiring removed?�
>> Most of it is. The instrument panels and some of the cockpit has
>> original wiring but the chinese radios and ADFs are long gone. I have the
>> original radio boxes in the cockpit, my plan was to someday gut them and
>> hinge them and make them into storage bins.
>> > What prompted the prop replacement?
>> I was parked in the dirt/grass at All Red Star a couple of years ago and
>> got a pretty bad rock ding on one prop blade from a plane running up in
>> front of me that ended up getting some intergranular corrosion so I
>> replaced the blades.
>> > Any damage history?
>> Not that I'm aware of. None that was ever recorded and if you do a
>> search for 4183E, there isn't any mention in the NTSB database (other than
>> the original Piper that carried that N number before this plane had it)
Ernie
PostPosted: Tue Oct 08, 2013 11:57 am    Post subject: I'm back and shopping for CJ Reply with quote
All,
I'm sorry for all this noise. I thought I was responding directly to the owners.
Anyone that wants to send me their CJ info please contact me off list.
Ernie
On Tue, Oct 8, 2013 at 3:48 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
[quote]Oh shoot, I thought this was off list.
On Tue, Oct 8, 2013 at 3:42 PM, Rico Jaeger <rijaeger(at)wausau.k12.wi.us (rijaeger(at)wausau.k12.wi.us)> wrote:
Sorry to butt in here guys, but....can you tell me more about the compressor failures??
On Tue, Oct 8, 2013 at 2:29 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
I like that you're using the Phillips, I've seen compressor failures with those who were using Exxon.
Ernie
On Tue, Oct 8, 2013 at 3:21 PM, Pete Fowler <pfdesign1(at)cox.net (pfdesign1(at)cox.net)> wrote:
--> Yak-List message posted by: "Pete Fowler" <pfdesign1(at)cox.net (pfdesign1(at)cox.net)>
> How did you arrive at the engine and airframe times? Do you have the original Chinese Logs? What overhaul # is the engine on 1st 2nd or 3rd?
 The engine was purchased by Bob Watts (the previous owner) from Jim Selby, it's believed to be first overhaul. It doesn't have original logs but Jim is familiar with the motor. The airframe hours are estimated based on a guess of 3500 hours in Chinese service. The plane has been in the U.S. since 1991 (it's one of the first 10) so the US logbooks cover the last 22 years. The engine that's on there now replaced a 1200 hour motor that the plane previously had that I believe Keith Harbor now has (he did the engine installation back in 2007 or so).
The airframe hours were counted several different ways over it's life. Eventually a hobbs meter was installed but given how much formation time I do and how much time we spend on the ground (getting 5 or 6 planes across the airport and warmed up and ready to go takes time), I personally do all my maintenance based on tach hours.
Most of it is. The instrument panels and some of the cockpit has original wiring but the chinese radios and ADFs are long gone. I have the original radio boxes in the cockpit, my plan was to someday gut them and hinge them and make them into storage bins.
I was parked in the dirt/grass at All Red Star a couple of years ago and got a pretty bad rock ding on one prop blade from a plane running up in front of me that ended up getting some intergranular corrosion so I replaced the blades.
Any damage history?
Not that I'm aware of. None that was ever recorded and if you do a search for 4183E, there isn't any mention in the NTSB database (other than the original Piper that carried that N number before this plane had it).
What oil are you using?
Phillips 25/60 and it has a 10 micron oil filter. I've been doing 50 hour oil changes with Blackstone oil analysis each time (which validates the oil change interval). I used aeroshell 100 for a while but prefer the Phillips. I just did an oil change yesterday as well as the 25 hour air system service (dryer) and 50 hour greasing the landing gear.
To quote Blackstone: "The typical interval we see is about 30 hours, so it's great to
see nice and low metals in this sample after a longer oil change interval."
 Does it have schrader fittings?
Chinese fittings on the gear legs, shrader on the main air tank. I have the valve and regulator for topping up the main air system that I can include in the sale.
What else is included in the sale?
It has a full canopy cover, pitot cover and a few spare parts (some gill shutters and miscellaneous stuff). Some spare rocker gaskets...stuff like that. Flying helmet and scuba tank are negotiable.
http://forums.matronics.com/viewtopic.php?p=410085#410085
target="_blank">http://www.matronics.com/Navigator?Yak-List
MS -
e -
         -Matt Dralle, List Admin.
Rico Jaeger
Choir / Wausau East High School
Page 2 of 2
