tmartino(at)troubleshoote Guest
Posted: Wed Jun 14, 2006 8:13 am Post subject: VOLTAGE FLUCTUATION |
I have had 55 hours of flying with no electrical problems until now! Recently I saw something in flight that bothered me.
My panel lights started flickering a bit and the (Electronics
International) voltmeter showed varying voltages anywhere from 12.3
volts up to 14 volts ... kind of erratically. Then the "Discharge"
light on the voltmeter lit up. Then the "Low Voltage" light coming
from my voltage regulator lit up.
I have the B & C Solid State Voltage Regulator (Model LR3C-14) and the B & C L-60 Alternator.
Upon touch down and roll out everything went back to normal. No
"discharge" no "low voltage". I checked connections and everything
seems normal. I can't get it to act up on the ground.
Any ideas?
Tom
pbraswell(at)alterthought Guest
Posted: Wed Jun 14, 2006 8:23 am Post subject: VOLTAGE FLUCTUATION |
Tom,
Have you checked the belt on your alternator?
-peter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Tom Martino
Sent: Wednesday, June 14, 2006 12:04 PM
Subject: VOLTAGE FLUCTUATION
Any ideas?
Tom
jschroeder(at)perigee.net Guest
Posted: Wed Jun 14, 2006 4:04 pm Post subject: VOLTAGE FLUCTUATION |
Check your grounds.
On Wed, 14 Jun 2006 10:04:26 -0600, Tom Martino
<tmartino(at)troubleshooter.com> wrote:
| Quote: | Upon touch down and roll out everything went back to normal. No
Any ideas?
Tom
