Kolb-List Digest: 0 Msgs - 09/18/13
bgreen(at)bimi.org
PostPosted: Thu Sep 19, 2013 6:20 am    Post subject: Kolb-List Digest: 0 Msgs - 09/18/13 Reply with quote
Kolbers:
Everyone must be out flying and enjoying the beautiful weather, since there are no posts. OR, maybe the rest are working away at getting the kits finished. I always enjoy hearing from each of you. John Hauck, anything going on with you?
Travis, how goes the transition to the new location?
Does anyone have an "oil separator" on their MKIIIC or MKIIIX? Where do you have it mounted?
Thank you.
Bob Green
MKIIIX , GPAS VW with re-drive.
neilsenrm(at)gmail.com
PostPosted: Thu Sep 19, 2013 6:52 am    Post subject: Kolb-List Digest: 0 Msgs - 09/18/13 Reply with quote
I used a Bug Pack oil separator. The big VWs need to breathe or they will push oil out everywhere. This unit connects to the redrive breather and both valve covers. I mounted it  high on the engine so residual oil drains back into the engine. I fabricated a mounting strap that I bolted to the flange next to the flywheel then bolted the oil separator to that strap. See the attached photo.
Rick Neilsen
Redrive VW Powered MKIIIC
On Thu, Sep 19, 2013 at 10:19 AM, Bob Green <bgreen(at)bimi.org (bgreen(at)bimi.org)> wrote:
--> Kolb-List message posted by: Bob Green <bgreen(at)bimi.org (bgreen(at)bimi.org)>
Kolbers:
Thank you.
Bob Green
http://forums.matronics.com
le, List Admin.
 Filesize:  197.55 KB
 Viewed:  2337 Time(s)
