nigel_graham(at)m-tecque. Guest
Posted: Sat Sep 07, 2013 2:47 am Post subject: Firewall Off-cut |
A bit of a strange request but ...... does anyone (in the UK) still have
the section of the phenolic firewall that would have been cut out and
discarded when installing the main engine/undercarriage frame? As some
of you will be aware, I am developing a conventional gear and as this
does not make use of this frame, I am looking to close off the hole with
suitably fire retardant material.
If you still have this lurking in the scrap pile in your workshop, I
would be happy to offer it a new home.
Nigel
riddon(at)sent.com Guest
Posted: Sat Sep 07, 2013 3:07 am Post subject: Firewall Off-cut |
Nigel.
I have a small piece approx. 7in. x 13in. if this is any good to you.
Richard Iddon
G-RIXS.
On 7 Sep 2013, at 11:46, nigel_graham(at)m-tecque.co.uk wrote:
A bit of a strange request but ...... does anyone (in the UK) still have the section of the phenolic firewall that would have been cut out and discarded when installing the main engine/undercarriage frame? As some of you will be aware, I am developing a conventional gear and as this does not make use of this frame, I am looking to close off the hole with suitably fire retardant material.
If you still have this lurking in the scrap pile in your workshop, I would be happy to offer it a new home.
Nigel
johnfcliff(at)googlemail. Guest
Posted: Sun Sep 08, 2013 9:17 am Post subject: Firewall Off-cut |
installing the main
I have a piece about 9" x 11" if it's any use.
John Cliff
#0259
Posted: Tue Sep 10, 2013 9:53 am Post subject: Firewall Off-cut |
Thanks to everyone that responded to my request - both on and off-list.
I have been offered enough phenolic off-cuts to build a new workshop!
It is truly alarming how much material does get thrown away during the
build process - I still have a (warm) loft full of blue foam.
Nigel
On 07/09/2013 11:46, nigel_graham(at)m-tecque.co.uk wrote:
<nigel_graham(at)m-tecque.co.uk>
Nigel
