Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Wed Sep 04, 2013 6:48 am Post subject: Refilling a Europa by hand |
Hi All.
My plan is LAA cleared for use with MOGAS.
I fill it with a 28 litre plastic cann, lifting this weight of fuel to above my shoulders to fill the plan is hard work.
I know Trans Air do a filler nozzle hand pump, I presume this take a lot of time squeezing the trigger to re fill.??
Has anyone used or details off , an electric inline pump that can be plugged into the aircrafts AUX power socket, I have not seen any on the market, so is it make your own,??
Regards.
Alan
riddon(at)sent.com Guest
Posted: Wed Sep 04, 2013 7:22 am Post subject: Refilling a Europa by hand |
Hi Alan.
I lift my can onto a non slip pad the wing then use a battery operated fuel pump to transfer it to the tank. Search for battery operated fuel pump on Amazon or Ebay. They are a bit flimsy and not terribly fast but they work OK and you can buy one for about £15. I am on my second one in 8 years. They take a couple of D cells and the batteries last at least a full season with me.
Richard Iddon. G-RIXS
On 4 Sep 2013, at 15:48, Alan Carter <alancarteresq(at)onetel.net> wrote:
Hi All.
Regards.
Alan
http://forums.matronics.com/viewtopic.php?p=408005#408005
alanb(at)dpy01.co.uk Guest
Posted: Wed Sep 04, 2013 9:41 am Post subject: Refilling a Europa by hand |
Personally I use 10 litre fuel cans which I can lift to pour into a filter funnel with a micro mesh filter.
I have also seen a standard fuel pump, as in the Europa electric pump, connect to a small rechargeable lead acid cell. All mounted on a 'Sack Barrow' with a 25 litre can.
Alan
On 4 Sep 2013, at 15:48, "Alan Carter" <alancarteresq(at)onetel.net> wrote:
Hi All.
Regards.
Alan
trevpond(at)aol.com Guest
Posted: Wed Sep 04, 2013 11:57 am Post subject: Refilling a Europa by hand |
Hi Richard
I have the same pump, runs on 2 A type batteries - Brilliant! Used mine for years.
Trev G:-LINN
Sent from my iPad
On 4 Sep 2013, at 16:21, Richard Iddon <riddon(at)sent.com> wrote:
Hi Alan.
> Hi All.
> Regards.
> Alan
graeme bird
Posted: Wed Sep 04, 2013 11:59 am Post subject: Re: Refilling a Europa by hand |
I brought a hand pump for fuel and mounted it on my hangar wall, its the type with a leaver you waggle. Its quick enough but then I brought a flylight filter and found that a lot of fuel remained in the feed and out 1" pipes. So I use 20 ltr cans and find I can rest them on the side of the filter and they are ok. Its rare that I put in more than 1 or 2. Mine has the middle old position filler.
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
john.heykoop(at)gmail.com Guest
Posted: Wed Sep 04, 2013 12:30 pm Post subject: Refilling a Europa by hand |
Hi all
I fitted a car battery and a standard Europa fuel pump on a 'sack barrow', but filling the plane this way takes a lot longer than refueling by simply lifting the jerry can above my shoulders. There is also the hassle of having to load the barrow into the car every time I go flying. So I soon got fed up with this and now do everything the hard way. The exercise probably does me good.
What I haven't been able to master is how to keep a filter funnel upright while refueling from a jerry can (my Europa is an XS). After the damn thing had fallen over a number of times, covering me and the plane with fuel I decided to do without. So far without adverse consequences - I have never found a drop of water in the fuel, and my gascolator filter is always very clean. All the same, I am uneasy about not using a filter funnel, and would be interested to know how other XS owners manage this.
John
Europa XS G-JHKP
On 4 Sep 2013, at 18:39, Alan Burrill <alanb(at)dpy01.co.uk> wrote:
Alan
> Hi All.
> Regards.
> Alan
kheindl(at)msn.com Guest
Posted: Wed Sep 04, 2013 1:07 pm Post subject: Refilling a Europa by hand |
I used to use one of those cheap electric pumps, with a 25l can on the wing. But the pump eventually fell apart. They are only meant for pumping water, maybe heating oil also. I was also concerned about the motor being surrounded by fumes.Much easier, quicker and safer is to have 2 or 3 of the same 25l plastic fuel cans, but have them only half full. Then they are easy to lift up and pour. The filter fits right into the cobra neck. I can't remember where I bought it.
Cheers, Karl
[quote] Hi all
John
Europa XS G-JHKP
> --> Europa-List message posted by: Alan Burrill <alanb(at)dpy01.co.uk>
> Alan
> Sent from my iPhone
>> --> Europa-List message posted by: "Alan Carter" <alancarteresq(at)onetel.net>
>> Hi All.
>> Regards.
>> Alan
Posted: Wed Sep 04, 2013 1:08 pm Post subject: Refilling a Europa by hand |
John, I have a simple funnel with the spout cut off so it
is about 6 or 7cm long and with a string attached to the
brim. This attaches by a half hitch to the door strut and
the whole thing is nicely stable. A paint filter inside
the funnel completes the set up when I am using a jerry
can. I don't bother with the funnel when I am filling from
an airport pump. Regards, David Joyce, G-XSDJ
On Wed, 4 Sep 2013 21:27:54 +0100
John Heykoop <john.heykoop(at)gmail.com> wrote:
Hi all
good.
manage this.
John
Europa XS G-JHKP
> Alan
> Sent from my iPhone
>> Hi All.
>>hard work.
>>fill.??
>>own,??
>> Regards.
>> Alan
Un/Subscription,
Forums!
Admin.
robert.hitchcock(at)virgi Guest
Posted: Wed Sep 04, 2013 1:34 pm Post subject: Refilling a Europa by hand |
Hi All
I have used the same Polarn pump for the last four years. No battery needed and allows precise control directly from the jerry can that I place on a stool. Can't remember where I purchased from. This link has a good picture.
http://www.absoluteflying.co.uk/Jerry_Can_Fuel_Pump/cat933351_842633.aspx
Your hand is left free to guide the filler tube into the filter.
Easy and safe.
Bob
On 4 Sep 2013, at 21:27, John Heykoop <john.heykoop(at)gmail.com (john.heykoop(at)gmail.com)> wrote:
[quote]--> Europa-List message posted by: John Heykoop <john.heykoop(at)gmail.com (john.heykoop(at)gmail.com)>
Hi all
John
Europa XS G-JHKP
On 4 Sep 2013, at 18:39, Alan Burrill <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)> wrote:
[quote]--> Europa-List message posted by: Alan Burrill <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)>
Alan
On 4 Sep 2013, at 15:48, "Alan Carter" <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)> wrote:
| Quote: | My plan is LAA cleared for use with MOGAS.
| Quote: | I fill it with a 28 litre plastic cann, lifting this weight of fuel to above my shoulders to fill the plan is hard work.
| Quote: | I know Trans Air do a filler nozzle hand pump, I presume this take a lot of time squeezing the trigger to re fill.??
| Quote: | Has anyone used or details off , an electric inline pump that can be plugged into the aircrafts AUX power socket, I have not seen any on the market, so is it make your own,??
| Quote: | Read this topic online here:
<====================================================sp;--> http://==========================bsp; - MATRONICS W href="http://forums.matronics.com">http://forums.matronics.com==============================================
churchy
Posted: Wed Sep 04, 2013 2:19 pm Post subject: Refilling a Europa by hand |
I can second Bob's pump choice - available from Demon Tweeks online - I use it to fuel my gyro with a high tank inlet (pending actually building my XS mono), the pump is designed for rally car fuelling in the field and can pump with the jerry can at ground level or syphon if the can is close to the same level as the tank inlet.
Richard CC
On 4 Sep 2013, at 22:33, Bob Hitchcock <robert.hitchcock(at)virgin.net (robert.hitchcock(at)virgin.net)> wrote:
[quote]Hi All
Easy and safe.
Bob
Kelvin_G-BZAM
Posted: Wed Sep 04, 2013 11:35 pm Post subject: Refilling a Europa by hand |
I am set up similar to David, I have the smallest 'Mr Funnel' and use a small length of para cord to tie to passenger lift strut.... Very secure. At the hangar I have a 'waggle side to side handled pump', but on trips just carry a plastic Jerry and my funnel and do the filling with good old fashioned brute force.... Hmmm, as I'm not getting any younger, perhaps one of those battery pump thingies might be worth a look
Sent from my iPad
On 4 Sep 2013, at 22:05, David Joyce <davidjoyce(at)doctors.org.uk> wrote:
John, I have a simple funnel with the spout cut off so it is about 6 or 7cm long and with a string attached to the brim. This attaches by a half hitch to the door strut and the whole thing is nicely stable. A paint filter inside the funnel completes the set up when I am using a jerry can. I don't bother with the funnel when I am filling from an airport pump. Regards, David Joyce, G-XSDJ
> Hi all
> John
> Europa XS G-JHKP
>> Personally I use 10 litre fuel cans which I can lift to pour into a filter funnel with a micro mesh filter. I have also seen a standard fuel pump, as in the Europa electric pump, connect to a small rechargeable lead acid cell. All mounted on a 'Sack Barrow' with a 25 litre can. Alan
>> Sent from my iPhone
>>> Hi All.
>>> Regards.
>>> Alan
> Un/Subscription,
> Forums!
> Admin.
roddyeuropa(at)aol.com Guest
Posted: Thu Sep 05, 2013 12:41 am Post subject: Refilling a Europa by hand |
I have used a polarn oump for a number of years. The pump attaches to the top of a jerry can and you use a hand air pump to pressurize the jerry can. Integral tube goes through jerry can fitting from base of can to europa filler. Takes quite a lot of pumping to get the fuel transferred - probably 1 - 2 mins per 20l can.See here: http://www.demon-tweeks.co.uk/motorsport/fuel-containers-funnels/demon-tweeks-polarn-pump
Needs an extension to reach the filler from jerry can on the ground.
Roddy Kesterton
G-IKRK
brian.davies(at)clara.co. Guest
Posted: Thu Sep 05, 2013 12:56 am Post subject: Refilling a Europa by hand |
". I don't bother with the funnel when I am filling from an
David, you might be interested in the following news item;-
Contaminated fuel caused Cathay A330 incident
By: MAVIS TOH SINGAPORE
3 hours ago - [url=javascript:window.print()]Print[/url]
Fuel contamination has been confirmed as the cause of a double engine malfunction on a Cathay Pacific Airbus A330-300 on approach to Hong Kong International airport (HKIA) in 2010.
In a final report released on 4 September, Hong Kong's Civil Aviation Department (CAD) says that 24.4t of contaminated fuel was uplifed into the aircraft at Surabaya's Juanda International airport. This caused "stiction" - static friction - in the fuel metering unit of both engines, leading to the total seizure of these components and the loss of thrust controls of the aircraft during approach to HKIA.
It found that though the aircraft was uplifed with the proper grade of fuel, it was contaminated with super absorbent polymer (SAP) spheres. During the flight, some SAP spheres were trapped in the fuel metering unit on both engines, causing stiction in the unit that resulted in engine pressure ratio fluctuations.
Moral- don't trust airport fuel pumps. I still use my Mr Funnel even when I uplift from aviation pumps.
Brian
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of roddyeuropa(at)aol.com
Sent: 05 September 2013 09:39
Subject: Re: Refilling a Europa by hand
Roddy Kesterton
G-IKRK
Posted: Thu Sep 05, 2013 1:25 am Post subject: Refilling a Europa by hand |
Brian
I had a similar thought but had no evidence.
Graham
Sent: Thursday, 5 September 2013, 9:55
Subject: RE: Refilling a Europa by hand
3 hours ago
Brian
Roddy Kesterton
G-IKRK
Posted: Thu Sep 05, 2013 7:12 am Post subject: Refilling a Europa by hand |
Brian, I should perhaps have added 'This side of
Budapest'! There the Avgas supplied at the otherwise
fantastic GA airfield of Buduors, came out a horrible
yellow colour and you could imagine lumps in it too. But
the policy has worked well for 12 years.
Regards, David
On Thu, 5 Sep 2013 09:55:50 +0100
"Brian Davies" <brian.davies(at)clara.co.uk> wrote:
[quote] ". I don't bother with the funnel when I am filling from
an
> airport pump."
item;-
By:
<http://www.flightglobal.com/landingpage/mavis%20toh.html>
MAVIS TOH
SINGAPORE
3 hours ago
* Print <javascript:window.print()>
double engine
Civil Aviation
engines, leading to
spheres. During the
fluctuations.
Brian
Behalf Of
of can to europa
s-polarn-pump
the ground.
Roddy Kesterton
G-IKRK
Posted: Thu Sep 05, 2013 11:30 am Post subject: Refilling a Europa by hand |
Kelvin, David
Thanks for the advice about keeping 'Mr Funnel' from falling over when refilling a Europa XS from a jerry can. Now why didn't I figure out something like that myself ....
John
On 5 Sep 2013, at 08:34, Kelvin Cobb <kelvin.cobb(at)icloud.com> wrote:
Sent from my iPad
>> Hi all
>> John
>> Europa XS G-JHKP
>>> Sent from my iPhone
>>>> Hi All.
>>>> Regards.
>>>> Alan
>> Un/Subscription,
>> Forums!
>> Admin.
Posted: Thu Sep 05, 2013 11:43 am Post subject: Refilling a Europa by hand |
| Quote: | >What I haven't been able to master is how to keep a filter funnel upright while refueling from a jerry can (my Europa is an XS).<<
Mine's an XS also.
Large Oblong shape funnel with a spout that has been cut so it's about 3 in long. Hooks into the filler and stays in place. Not upright admitted.
Can has a spout fixed to it. Pour fuel from can without resting on funnel and don't overdo it, aim direct for funnel filter and try not to overfill funnel use a constant flow of fuel.
Alan
[quote]What I haven't been able to master is how to keep a filter funnel upright while refueling from a jerry can (my Europa is an XS).[b]
Alan Carter
Posted: Mon Sep 09, 2013 12:34 pm Post subject: Re: Refilling a Europa by hand |
Hi all.
Many thanks for replies, Lots to choose from.
Personally I am not keen on jerry cans, maybe safer in transporting, but I like plastic possibly cleaner inside. however I have seen many use jerry cans without problems.
I always use a filter, I have a plastic one that fits quit tightly into the filler hole, What I do notice in the filter after refilling is insects ie a small flies.
I suppose one of these could block the jets, ???
So recommend using a filter,
They was a post saying filter as you refill you cann at the pumps, sounded a good idea to me, till I remembered the flies.
Regards.
Alan
Posted: Mon Sep 09, 2013 2:01 pm Post subject: Refilling a Europa by hand |
Alan, As a point of interest one of he (rarely) fatal
ditchings in the UK was said by the AAIB to be due to a
fly blocking he carburettor jet! Regards, David Joyce,
GXDJ
On Mon, 9 Sep 2013 13:34:42 -0700
Hi all.
the flies.
Regards.
Alan
http://forums.matronics.com/viewtopic.php?p=408302#408302
Un/Subscription,
Forums!
Admin.
Alan Carter
Posted: Mon Sep 09, 2013 3:10 pm Post subject: Re: Refilling a Europa by hand |
Well just goes to show, The carburettor jet life or death.
I don't know why she swallowed the fly, perhaps she'll die.
Alan
