saafbusiness(at)gmail.com Guest
Posted: Thu Aug 29, 2013 3:24 am Post subject: Gross Take off Weight |
Guys,
I know this is a 10+ year old discussion item, but I can not remember the result and general consensus in the end.
My 1996 Pulsar XP from Aerodesigns had a max gross weight of 1060 pounds. There was a lot of discussion about that number being changed to a higher number.
Just curious if anyone knows.
I ask because after 9 months or reworking wings, they put on a few pounds
myesig.com
scott(at)s-f-x.com Guest
Posted: Thu Aug 29, 2013 3:36 am Post subject: Gross Take off Weight |
I am just increasing my rating for more max weight. It was 960lbs if your kit was 249 or less, if a higher number it would be 1060lbs. It seems a composite spar was used on later models. Source - UK LAA TADS for Pulsar XP.
Hope that helps.
Scott MacIntyre
UK +44 7860 208432
US +1 (818) 397 0666
scott(at)s-f-x.com (scott(at)s-f-x.com)
On 29 Aug 2013, at 12:21, Mark Fox <saafbusiness(at)gmail.com (saafbusiness(at)gmail.com)> wrote:
[quote]Guys,
myesig.com
cs.com
matronics.com/contribution
kdpalmer(at)mweb.co.za Guest
Posted: Thu Aug 29, 2013 4:00 am Post subject: Gross Take off Weight |
The XP is definitely 1060 lb the III is 1200lb the II I'm not sure ?
K'd
Posted: Thu Aug 29, 2013 5:21 am Post subject: Gross Take off Weight |
Scott,
MAUW - Wooden Spars with Capping to the end of the Spar - 960lb - Composite Spars on XP 1060lb - Don't automatically go by serial numbers it is the construction that counts & what was included in that KIT.
K'd
Posted: Thu Aug 29, 2013 5:41 am Post subject: Gross Take off Weight |
Yes, common sense prevails - I have a composite spar but it seems the guy that made the kit went for the lower weight just because he wasn't aware of the later spec.
Thanks for helping make this point clearer.
Scott MacIntyre
On 29 Aug 2013, at 14:18, "Keith Palmer" <kdpalmer(at)mweb.co.za (kdpalmer(at)mweb.co.za)> wrote:
[quote] Scott,
K'd
Posted: Thu Aug 29, 2013 6:00 am Post subject: Gross Take off Weight |
What do your manuals say ?
simon(at)design24.org.uk Guest
Posted: Thu Aug 29, 2013 7:08 am Post subject: Gross Take off Weight |
Hi Scott,
At the time the kit was built, they had just introduced the composite spar and Aero Designs had updated their brochure for the XP - (960 crossed out and 1060 written in biro!)
The PFA at the time had not approved this and so to save time getting into the air, Malcolm went with the original 960. It should only be a formality to up-rate the figure – He and I just never got around to it! It definitely has the composite spar and also the slightly bigger rudder – maybe XPs had this.
Looking forward to seeing her airborne again soon J
Simon. Â
From: owner-pulsar-list-server(at)matronics.com [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of Scott - Special Effects Armourer
Sent: 29 August 2013 14:40
Subject: Re: Gross Take off Weight
Scott MacIntyre
Scott,
K'd
ccoulter(at)wavecable.com Guest
Posted: Thu Aug 29, 2013 9:13 am Post subject: Gross Take off Weight |
No, the weight was not increased. The Series II had a
higher gross as did the III.
Clarke
On Thu, 29 Aug 2013 07:21:44 -0400
Mark Fox <saafbusiness(at)gmail.com> wrote:
| Quote: | Guys,
not remember the
changed to a higher
number.
put on a few pounds
[image: Mark L. Fox Vice President
321-626-4786]<http://myesig.com/esig/link-174057.php><http://myesig.com/esig/link-174063.php><http://myesig.com/esig/link-174061.php><http://myesig.com/esig/link-174062.php>
myesig.com <http://www.myesig.com/r.php?rc=CEA8A3>
sollymelyon(at)yahoo.com Guest
Posted: Thu Aug 29, 2013 10:45 am Post subject: Gross Take off Weight |
Hi Guys,
The II and the III are the same airplane structurally, both had a
GW of 1200 lb
Solly Melyon
AeroMax Aviation
www.aeromaxaviation.com
323.841.4822
Sent: Thursday, August 29, 2013 10:12 AM
--> Pulsar-List message posted by: "HUGH COULTER" <ccoulter(at)wavecable.com (ccoulter(at)wavecable.com)>
No, the weight was not increased. The Series II had a higher gross as did the III.
Clarke
leubanks(at)sunflower.com Guest
Posted: Thu Aug 29, 2013 11:14 am Post subject: Gross Take off Weight |
I have a sales brochure that is pre XP and was intended for the 582 version only and it shows a fiberglass spar, wood skins and a gross weight of 900 pounds. Unfortunately the brochure is not dated but was fairly expensive to produce as it is done similar to a magazine with about 12 pages.
Larry
Posted: Thu Aug 29, 2013 11:31 am Post subject: Gross Take off Weight |
For what it's worth I have another later sales brochure created after the first 912 version was built and it has a picture of the ill fated N912XP on one side. It shows a gross weight for the 582 Pulsar as 1000 pounds and the Pulsar XP(912) as 1060. I believe the difference here is that this was after the fiberglass skins were added to both models.
Larry
