Posted: Sun Aug 25, 2013 2:36 pm Post subject: Longer engine cables - throttle cable and mixture cable |
During my 2nd condition inspection I see that both by throttle and
mixture cables have started to wear through their sheathing in spots. I
know needing longer cables than the stock Vans cables is a common
requirement.
Where are people buying longer cables these days?
I see in the archives that Dave Saylor identifies someone is
California. I also see ACS (not Aircraft Spruce?).
Thanks.
Posted: Sun Aug 25, 2013 3:23 pm Post subject: Longer engine cables - throttle cable and mixture cable |
I sent this note to Van's a year and a half ago. The response back was 'many people are using the recommended cable'. The 50.5" cable from Van's worked just fine (standard Van's engine and push/pull controls).
Carl
From: Carl Froehlich [mailto:carl.froehlich(at)verizon.net]
Sent: Wednesday, April 25, 2012 8:58 PM
To: 'support(at)vansaircraft.com'
Subject: RV-10 Throttle Cable too short
I installed the Van’s recommended throttle cable (CT BLK THROTTLE 47.5) in my YIO-540 RV-10 project. It is simply too short. I just purchased and installed the IO-360 cable (CT BLK THROTTLE 50.5) and it fits better, but not perfect.
Recommend offering a 49” cable for the RV-10 throttle control, or at least selling the 50.5” instead of the 47.5” cable to RV-10 builders.
Your recommended prop and mixture cables worked well.
Carl Froehlich
40528
Kelly McMullen
Posted: Sun Aug 25, 2013 3:42 pm Post subject: Longer engine cables - throttle cable and mixture cable |
Well, I am getting close to ordering my cables. I recall that ACS offers a higher quality cable than what Vans buys from them. Top quality cables also can be obtained from McFarlane, but are priced some where between 2 an 3 times Van's price. I need to talk to McFarlane as to what the real length of their cables that they list for the RV-10 measure, as they show for stock panel and for Aerosport panels but don't say what the length is on their website.
On Sun, Aug 25, 2013 at 3:34 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
| Quote: | --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
During my 2nd condition inspection I see that both by throttle and mixture cables have started to wear through their sheathing in spots. I know needing longer cables than the stock Vans cables is a common requirement.
I see in the archives that Dave Saylor identifies someone is California. I also see ACS (not Aircraft Spruce?).
Thanks.
http://forums.matronics.com
le, List Admin.
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Sun Aug 25, 2013 6:12 pm Post subject: Longer engine cables - throttle cable and mixture cable |
California Push-Pull makes and sells CableCraft cables. The green cables from Vans are also CableCraft, but I used a different spec that seems to handle heat better. Look for 176-VTT part numbers. The part numbers in the archives should be available from any CableCraft distributor.
I changed my cables at around 500 hours. The new ones have close to 800 now and are smooth as silk.
Please note the measurements I gave are for a quadrant.
Dave Saylor
831-750-0284 CL
[quote] --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Thanks.
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
e -
-Matt Dralle, List Admin.
jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Mon Aug 26, 2013 4:32 am Post subject: Re: Longer engine cables - throttle cable and mixture cable |
We used the throttle cable for the RV-7 which is 3" longer than the one supplied for the -10. The mixture cable as supplied worked fine for us (standard panel with push pull). - Jason
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
AirMike
Posted: Mon Aug 26, 2013 7:33 am Post subject: Longer engine cables - throttle cable |
Replaced my Vans cable at about 150 hrs. It developed a wear spot in the plastic shield material. I tried fixing it with tank sealant. That also wore thru. Probably best to start out with the proper cable. Vans is tooooo short!
_________________ See you OSH '18
Q/B - sold. |
