mike91911
Joined: 03 Jul 2013 Posts: 14 Location: Riverside, RI
Posted: Thu Aug 22, 2013 12:09 pm Post subject: Best way to ship a Rotax 503. |
What is the best way to package a Rotax 503 for shipping? I'm sending engine, gearbox and carbs. The guy who is overhauling it recommended a 30 x 17 x 17" 350 lb. Double Wall Corrugated Box with plywood and 2x4's on the bottom with the engine bolted to the 2x4's and then cushion with styrofoam sheeting. The box is rated to hold 150lbs and the sides are rated to take 350lbs of sidewall pressure. Others have said build a crate. If you recommend building a crate can you offer any design advice?
Mike
rickofudall
Posted: Thu Aug 22, 2013 12:19 pm Post subject: Best way to ship a Rotax 503. |
Mike, I've shipped two engines pretty much as you describe except I made a base of plywood with a 2 X 2 frame to which the engine was bolted, then put the box over the top and screwed it to the base. Both times the box was ripped off by the shippers. If I were you I'd ship it in a wooden crate. It won't weigh that much more and that's about the minimum that has a chance against an idiot with a fork lift.
Rick Girard
On Thu, Aug 22, 2013 at 3:09 PM, mike91911 <ko1m.mike(at)gmail.com (ko1m.mike(at)gmail.com)> wrote:
| Quote: | --> RotaxEngines-List message posted by: "mike91911" <ko1m.mike(at)gmail.com (ko1m.mike(at)gmail.com)>
Mike
http://forums.matronics.com/viewtopic.php?p=407255#407255
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
Blumax008(at)aol.com Guest
Posted: Thu Aug 22, 2013 12:35 pm Post subject: Best way to ship a Rotax 503. |
In a message dated 8/22/2013 4:19:19 P.M. Eastern Daylight Time, aslsa.rng(at)gmail.com writes:
| Quote: | | It won't weigh that much more and that's about the minimum that has a chance against an idiot with a fork lift. |
Hey, I trucked for a living a few months when I made the Big Mistake of getting out of commercial aviation. You're correct, there's plenty of idiots in the trucking and fork lift fields of employment.
I once saw a man & wife trucking team with asses so wide they overlapped an eight foot bench! True story!
Guy Buchanan
Posted: Thu Aug 22, 2013 1:11 pm Post subject: Best way to ship a Rotax 503. |
I shipped my 582 in a plastic Tupperware "crate" I bought at
K-mart. Plywood base with 2" styrofoam under, 2" styrofoam insulation
from Home Depot cut to fit tight so if the box turned over the plywood
base would rest on it, and lots of duct tape. I also did the corrugated
box successfully the same way: standard corrugated box doubled up with
some extra cardboard, raised plywood base, (2" styro under,) 2" styro
box over it with shaped support well taped together, lots of fiberglass
packing tape and duct tape. I also "made" lots of handles so the morons
wouldn't be tempted to forklift. (Cut holes in the box and reinforce
them with fiberglass tape.)
The main thing is to shape the styro supports so the engine is safe
resting in any position. Of course you'll mark it "This end up" anyway,
but we know how that works.
(Digression: I flew to Belize once for a bike trip. We boxed our
bikes, but didn't do it too carefully, figuring "what could happen?"
Well, when we got to Belize City we stood waiting in the customs line
out on the tarmac outside a small building and watched in horror as they
unloaded the plane by pushing the baggage out the baggage door of the
767 and letting it drop to the ground. I estimate the drop at about
8-10'. Fortunately the bikes survived.)
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded
Now a glider pilot, too.
Deceased K-IV 1200
A glider pilot too. |
rvsimons
Posted: Thu Aug 22, 2013 1:36 pm Post subject: Best way to ship a Rotax 503. |
I have shipped two 503's from Washington to AZ. I built a create out of OSB with 2x2 skids on the bottom and also used 2x2 stock to frame the inside of the box. Both boxes worked great and the engines were returned in the same boxes I built. On one of them I made rope lifting handles and the second one I just cut holes. I cut 1x2 stock and drilled holes in them to except the mounting studs on the bottom of the engine then screwed them to the bottom of the box when I had the engine in a position I liked it. I used board foam to cushion the engine sides and egg foam on the top before securing the box lid on. It may sound like overkill but I didn't want anything to happen to my engine. I didn't have an issue with either of them shipping. Hope this helps. I have seen engines shipped in less and do fine also.
Vance. On Aug 22, 2013 1:14 PM, "mike91911" <ko1m.mike(at)gmail.com (ko1m.mike(at)gmail.com)> wrote:[quote] --> RotaxEngines-List message posted by: "mike91911" <ko1m.mike(at)gmail.com (ko1m.mike(at)gmail.com)>
Mike
le, List Admin.
_________________ Vance Simons
Post Falls, Idaho
Zenith 701 |
