kulpa(at)att.net Guest
Posted: Mon Aug 19, 2013 9:15 am Post subject: [Pulsar-Aviators] New Stator Coil In - Flying Again |
Another alternative is to monitor your engine. The engine monitor on my
210 has individual sensors on both mags so if either fail when the
master switch is on, I get an indication.
Prior to getting the engine monitor, I would do a runup and mag check
prior to shutdown. I suggest that checking mags in flight is not a good
idea.
BK
On 8/19/2013 11:09 AM, dougwitkowski(at)netscape.net wrote:
[quote] A failed igniton should show up as a reduced performance, ie. more
throttle for the same speed. And it should show as higher EGT's and
possibly higher water temps. Both coils fire at the same time but if
one is not working, the cylinder is running essentially with retarded
spark. If you did not observe this, both systems may have
been working and the one failed when you did your test. I must admit,
though, that I have never tested the plane in-flight with one mag
only, to see how it acts.
If you switch to mag 2, mag 1 is grounded. Mag 1 could fail during
the test and would show up as failed when you switch to mag 1. If the
engine dies on the first mag that is tested, then it was failed during
the time of running. (I am thinking of the typical 'mag 1 / mag 2 /
both / start' switch)
Not saying they don't fail in flight, just that it's not the common
mode of failure.
