kheindl(at)msn.com Guest
Posted: Fri Aug 16, 2013 3:04 pm Post subject: MG Spins |
Hi Terry,
This is the first note I have seen about spinning the motorglider. Could you give us details please about recovery and height loss per rotation ? I have been unable to stall mine in level or descending flight and I have been reluctant to force a spin without knowing that it would be okay.
Cheers,
Karl
[quote] From: iancook_1(at)btinternet.com
Subject: RE: Europa-List: Re: stopping engine in flight
Date: Fri, 16 Aug 2013 21:40:19 +0100
--> Europa-List message posted by: "Ian Cook" <iancook_1(at)btinternet.com>
Terry,
We have just finished the spinning trials in my mono motor glider
after two years of trying to satisfy the LAA (UK) requirements to get a
Permit to Fly, so was very interested in your comments, especially about
blocking of the cooling ducts to improve the LD ratio, do you have any
further details that you can make available? I had the company (Europa) fit
small wing tip wheels to my wings so I can take the outriggers off
completely if I want to go wave flying. Is your machine a mono or Tri-gear?
Best Regards
Ian Cook
G-CBHI
terrys(at)cisco.com Guest
Posted: Fri Aug 16, 2013 4:18 pm Post subject: MG Spins |
Hi Karl,
We have not spun our plane with long wings, that was another participant to this thread.
Terry
________________________________________
From: owner-europa-list-server(at)matronics.com [owner-europa-list-server(at)matronics.com] on behalf of Karl Heindl [kheindl(at)msn.com]
Sent: Friday, August 16, 2013 4:03 PM
Subject: MG Spins
Hi Terry,
Cheers,
Karl
Subject: RE: Re: stopping engine in flight
Terry,
Best Regards
Ian Cook
G-CBHI
iancook_1(at)btinternet.c Guest
Posted: Sat Aug 17, 2013 12:11 am Post subject: MG Spins |
Karl,
It will not be cleared for deliberate spinning, as it will still be classed as non-aerobatic, but at least we have now covered the currently approved Mass 621 kg (1370 lb), C of G configurations (60.4 to 62.5), in and out of spin control positions, flaps open and closed, wheel up and down cases. The LAA and Europa are still to review all the data and videos so I will not pre-empt their report other than to say it was generally good news, but as with all Europa A/C, the spin is very near the vertical so care is needed not to go too far forward with the stick or you can get into negative ‘g’ situations which can be off putting! With care during recovery, speeds did not go above 105 knots indicated (127 kt limit). However, we still need to get the increase in mass approved (to at least 1450 lb), to be a viable machine, it is currently too limited with the extra wing weight to operate at 1370 lb standard XS limit. Several of the take-off and landing at 1370 lb were completed from a grass strip 400 m by 20 m with 1 degree up slope (290 ft above SL), from nil wind up the 12 cross wind limit without problems.
Ian
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Karl Heindl
Sent: 17 August 2013 00:04
Subject: MG Spins
Hi Terry,
Cheers,
Karl
[quote] From: iancook_1(at)btinternet.com (iancook_1(at)btinternet.com)
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
--> Europa-List message posted by: "Ian Cook" <iancook_1(at)btinternet.com (iancook_1(at)btinternet.com)>
Terry,
Best Regards
Ian Cook
G-CBHI
Posted: Sat Aug 17, 2013 4:50 am Post subject: MG Spins |
Ian,
Thank you for the useful information. I had done the 1450 pound test flight without a problem. Here we only require a climb test (minimum of 300fpm at standard temp. and pressure), but I was about 3 times above that.
And as you say, takeoff is always very swift, and landings can take forever unless I come in really slow and airbrakes on.
How quick is the spin recovery, or will rotation stop when controls are released ? I am a little concerned about the small rudder.
Karl
Subject: RE: Europa-List: MG Spins
Date: Sat, 17 Aug 2013 09:11:07 +0100
Karl,
Ian
Subject: MG Spins
Hi Terry,
Cheers,
Karl
Terry,
Best Regards
Ian Cook
G-CBHI
