jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Sun Aug 04, 2013 7:53 am Post subject: Slick Mag AD? |
All, while at Oshkosh I had a conversation with the slick mag guys. Joe warned me of a service bulletin (Slick SB1-98, Lycoming SB 537) which turned into an AD that should apply to our engines IO540-D4A5 but for some reason does not explicitly list our model. Instead they make reference to a list of models and engines with fifth order balancers which the last "5" in our suffix refers to. The service bulletin calls for mandatory 250 hour inspections of impulse couplings, ultimately advising replacement of impulse coupled mags with retard breakers and slick start.
So to the brain trust - what is your interpretation of this SB (a short Google search will find it)? I wonder why they continue to offer impulse coupled mags on new IO540-XXX5 engines. When I talked to Lycoming they said, "yup it looks like this applies to your engine". - Jason
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
rleffler
Posted: Sun Aug 04, 2013 10:14 am Post subject: Slick Mag AD? |
does it only apply to an impulse mag?
On Aug 4, 2013, at 11:53 AM, "jkreidler" <jason.kreidler(at)regalbeloit.com> wrote:
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=405907#405907
_________________ Bob Leffler
N410BL - Phase I
jkreidler
Posted: Sun Aug 04, 2013 12:14 pm Post subject: Re: Slick Mag AD? |
Yes, only impulse mags if it applies at all, I am still very curious why the D4A5 would not have been listed if it applied. At the same time I don't want an omission on their part to leave us with the same real issue even if the paperwork didn't follow. - Jason
rleffler
Posted: Sun Aug 04, 2013 2:07 pm Post subject: Slick Mag AD? |
Thanks. I just moved and my network access is limited. I can get the 10 ready for first flight or wire the new house.
Fortunately for me, the engines that Vans sell all have a retard mag.
On Aug 4, 2013, at 4:14 PM, "jkreidler" <jason.kreidler(at)regalbeloit.com> wrote:
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=405923#405923
N410BL - Phase I
Kelly McMullen
Posted: Sun Aug 04, 2013 6:06 pm Post subject: Slick Mag AD? |
The way the Lycoming and Slick service bulletins are written at this time, they do not apply to the C4B5 or D4A5 engines. Given that those engines were extensively used on the Aztec and Comanche aircraft, if the bulletin was to apply to them, it would state that. Not saying you shouldn't keep an eye on the impulse coupling, but the SB names all affected aircraft. Since the engines normally used in the -10 don't come from any of those aircraft, probably does not apply.
Of course many of the donor aircraft didn't have problems with Slick mags because they were originally certified with Bendix mags (which have some of their own ADs, but are generally more durable and more rebuildable than Slicks)
On Sun, Aug 4, 2013 at 8:53 AM, jkreidler <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)> wrote:
Quote: | --> RV10-List message posted by: "jkreidler" <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)>
Jason Kreidler
le, List Admin.
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
jkreidler
Posted: Mon Aug 05, 2013 10:17 am Post subject: Re: Slick Mag AD? |
Kelly, can you tell me if the Aztec or Comanche came with Slick impulse mags? I think the problem might be that the D4A5 technically did not come with impulse mags. For us, Lycoming offered them as an 'upgrade', but still called the engine a D4A5.
dmaib@me.com
Posted: Mon Aug 05, 2013 10:50 am Post subject: Re: Slick Mag AD? |
jkreidler wrote: | Kelly, can you tell me if the Aztec or Comanche came with Slick impulse mags? I think the problem might be that the D4A5 technically did not come with impulse mags. For us, Lycoming offered them as an 'upgrade', but still called the engine a D4A5. |
Jason, I can tell you that my C4B5 came off an Aztec and it had the Slick impulse mags on it.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
jkreidler
Posted: Mon Aug 05, 2013 11:05 am Post subject: Re: Slick Mag AD? |
David, I glanced at Lycoming SSP-401 which gives the lineage of the engines. Here is how the IO-540-C4B5 plays out....
IO-540-C4B5 - Same as –C1B5 but with more effective counter weights for use with Hartzell “compact” propeller
IO-540-C1B5 - Same as O-540-A1D5 but with Bendix fuel injector
O-540-A1D5 - Same as –A1B5 except for Retard Breaker Magnetos
O-540-A1B5 - Same as –A1A5 except for short propeller governor studs and two impulse Magnetos
O-540-A1A5 - Same as –A1A but one fifth and one sixth order counterweights
O-540-A1A - Two sixth order counterweights
So from the looks of it your engine should have had retard breakers tracing back to the -A1D5 and a fifth order counterweight traced back to the A1A5...
Is there a more efficient way to find out exactly what accessories were on which engines?
dmaib@me.com
Posted: Mon Aug 05, 2013 11:21 am Post subject: Re: Slick Mag AD? |
I don't know, Jason. I googled the sb and found this 1999 bulletin from Piper. Clear from this that the C4B5 on the Aztec was not on the list at that time.
ftp://64.191.142.163/pub/piper%20SE/pa32/ServPubs/VSP-SA/VSP%20117.pdf
RV-10 #40559
jump2(at)sbcglobal.net Guest
Posted: Mon Aug 05, 2013 11:55 am Post subject: Slick Mag AD? |
The c4b5 does not have the option of impulse coupling. Look up slick magneto and engine and I believe you will not find that option.
The Aztec engine I first used did not have impulse coupling 1980.
When we were thinking of switching from slick start to impulse we did a intense search and that is what we found out. Impulse will work but joe at champion really advises against it.
My two cents
Patrick Thyssen
Ps another note we just found was the k&n filter shrinks over time and needs to be replaced its not a life time filter.
Tim Olson
Posted: Mon Aug 05, 2013 12:03 pm Post subject: Slick Mag AD? |
I found the same thing this year on the filter. Mine had shrunk
CONSIDERABLY.
I bought a replacement, but didn't replace it yet...first I had to
re-rivet in those
holder tabs that keep it from moving around. Or maybe I did replace it.
I can't remember right now. But, I know the new one will shrink too.
My two cents
Patrick Thyssen
Kellym
Posted: Mon Aug 05, 2013 1:00 pm Post subject: Slick Mag AD? |
No Lycoming engine came with Slick mags until Continental bought Bendix
mags (long after both aircraft were out of production). It was a Textron
corporate decision to change to Slick mags for everything except those
for which there was not a Slick equivalent, like the dual headed single
mag engines.
So no table of differences between engines is going to tell you what
they are currently shipped with. However, ALL new and rebuilt/overhauled
engines from Lycoming will come with Slick mags with the above noted
exception. Changeover was more than 20 years ago.
Service bulletins and ADs are written to either be very specific about
what engines or airframes, OR to say they apply to all engines with this
specific appliance, batch of parts, etc. Almost all lists of parallel
valve O-540 and IO-540 engines suitable for the RV-10 are models with 5
as the last digit. Only a handful of those appear on this Service
Bulletin, so there is some characteristic about the specific engines
they aren't telling you.
I would suggest contacting both Vans and Lycoming to ask their tech
support as to whether the SB applies to the D4A5 engine or not, whether
installed in a Comanche or RV-10, and if so, why the Comanche as a
certified aircraft is not listed on the SB. No need to ask about the
C4B5 because it is an identical engine except for data plate and
governor redline setting.
On 8/5/2013 11:17 AM, jkreidler wrote:
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=405978#405978
KCHD |
Kellym
Posted: Mon Aug 05, 2013 1:13 pm Post subject: Slick Mag AD? |
I don't know why an Aztec couldn't have impulse coupled engine. There
are several versions of the engine that do have impulse coupling,
including the C4C5D
the D4A5, the D4B5, etc. Piper and other manufacturers went back and
forth between impulse coupling and retard breaker starting systems quite
a bit back in the sixties and 70s. Only the presence of a vibrator, the
wiring and ignition switch are different. The retard breaker has had
less ADs, both otherwise both are pretty equivalent for starting.
My two cents
Patrick Thyssen
> David Maib
> RV-10 #40559
> Transition Trainer
> http://forums.matronics.com/viewtopic.php?p=405987#405987
KCHD |
aerosport1
Posted: Mon Aug 05, 2013 1:21 pm Post subject: Slick Mag AD? |
I had the same thing with my filter. Mine shrunk and also was cutting into
the fiberglass. I did replace
Mine at my annual. I prosealed A .03-.04 aluminum ring in the fiberglass
housing. It worked really good. Got the idea from someone else On VAF. My
filter was almost a 1/3 thru the fiberglass. Here is a PDF full scale of the
ring
Geoff
Geoff Combs
Description: |
 Download |
Filename: |
filter_ring.PDF |
Filesize: |
33.01 KB |
Downloaded: |
591 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Jim Combs
Joined: 24 Jan 2010 Posts: 141 Location: Lexington, Ky
Posted: Tue Aug 06, 2013 4:20 am Post subject: Slick Mag AD? |
My C4B5 had Bendix mags. I replaced the left mag with a light speed ignition. Use left only for starting and run with both.
Plan is to replace the Bendix mag at some point with a second electronic system.
I think it had impulse mag on left when I got it.
Jim C
N312F - 550+ hours
Do not archive.
On Mon, Aug 5, 2013 at 3:54 PM, Patrick Thyssen <jump2(at)sbcglobal.net (jump2(at)sbcglobal.net)> wrote:
[quote] --> RV10-List message posted by: Patrick Thyssen <jump2(at)sbcglobal.net (jump2(at)sbcglobal.net)>
My two cents
Patrick Thyssen
On Aug 5, 2013, at 2:21 PM, "dmaib(at)me.com (dmaib(at)me.com)" <dmaib(at)me.com (dmaib(at)me.com)> wrote:
> --> RV10-List message posted by: "dmaib(at)me.com (dmaib(at)me.com)" <dmaib(at)me.com (dmaib(at)me.com)>
> David Maib
> RV-10 #40559
> Transition Trainer
le, List Admin.
_________________ RV-10 -> N312F - Flying as of 12/2008 |
Albert Gardner
Posted: Tue Aug 06, 2013 5:36 am Post subject: Slick Mag AD? |
Quote: | Speaking of mags, did the e-mag/p-mag people have anything new concerning 6 cylinder models at Oshkosh?Albert GardnerN991RVYuma, AZ |
_________________ RV-9A N872RV
RV-10 N991RV |
