ghf4986(at)gmail.com Guest
Posted: Fri Jul 26, 2013 1:11 pm Post subject: High Compression Pistons |
I had them put in my rebuilt engine by Mississippi South, a Rotax
engine rebuilder. I really like the power I have. With a Prince
power tip I can fly at 155 mph true at about 5000 rpms in my XP.
The only comparison that I can make is last year, Austin Moses and I
went flying (he has an 80 HP XP with a Prince power tip), his comment
was that I could climb out a lot faster than he could. My plane is
quite a bit heavier than his and I throttled back a little.
I have about 120 hrs on the engine with no problems.
Dennis
N375CM
Sent from an IPad
mortweaver(at)sbcglobal.n Guest
Posted: Sat Jul 27, 2013 3:06 am Post subject: High Compression Pistons |
Dennis -
What is the lowest octane fuel you are able to run with the high compression pistons and fuel burn rate at 5,000 rpm cruise?
Dave Weaver N912GR
Sent: Friday, July 26, 2013 4:09 PM
Subject: High Compression Pistons
--> Pulsar-List message posted by: Dennis Adams <ghf4986(at)gmail.com (ghf4986(at)gmail.com)>
Dennis
N375CM
Sent p; nbsp; -Matt
Posted: Sat Jul 27, 2013 4:36 am Post subject: High Compression Pistons |
Dave,
I usually run 91 octane no alcohol auto fuel, and 100 LL when I have to usually going cross country. I am at 4856 feet msl when I take off however so that 91 octane seems just fine.
Dennis
Sent from an IPad
On Jul 27, 2013, at 5:09 AM, David Weaver <mortweaver(at)sbcglobal.net (mortweaver(at)sbcglobal.net)> wrote:
Dennis -
Dave Weaver N912GR
From: Dennis Adams <ghf4986(at)gmail.com (ghf4986(at)gmail.com)>
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Subject: Pulsar-List: High Compression Pistons
Dennis
N375CM
Sent p; nbsp; -Matt
ics.com
.matronics.com/contribution
ccoulter(at)wavecable.com Guest
Posted: Sat Jul 27, 2013 7:00 am Post subject: High Compression Pistons |
Dave
I use 87 in my 912 UL but the 912 ULS or the high
compression pistons in the 912 should use 91.
Clarke
On Sat, 27 Jul 2013 04:04:07 -0700 (PDT)
David Weaver <mortweaver(at)sbcglobal.net> wrote:
| Quote: | Dennis -
rpm cruise?
Dave Weaver N912GR
<ghf4986(at)gmail.com>
South, a Rotax
a Prince
in my XP.
Moses and I
tip), his comment
My plane is
little.
I have about 120 hrs on the engine with n=
-Matt Dralle=========
