Dan.Beadle(at)hq.inclines Guest
Posted: Mon Jun 12, 2006 6:52 am Post subject: IFR Requirements |
There has been a lot on TSO129. I get that.
What are the requirements for IFR flight in the EFIS age? We are planning a Grand Rapids EFIS with an engine monitor. So far, all eggs in one basket. If not illegal, at least this is not safe enough for me.
Certificated A/C use an AI, Altimeter, Tach, MP steam gage for redundancy.
Would it be legal to put in a second EFIS with an independent AHRS on a separate essential buss and delete the steam gages?
Bruce(at)glasair.org Guest
Posted: Mon Jun 12, 2006 7:19 am Post subject: IFR Requirements |
I suggest you read my posts on the GRT forum before they kicked me off. You need at least an Artificial Horizon (preferably vacuum), Altimeter, and ASI. Even with another separate EFIS you'll still need the steam gauges. If the EFIS's disagree, you'll need a tie breaker.
Bruce
www.glasair.org
Tdawson(at)avidyne.com Guest
Posted: Mon Jun 12, 2006 7:30 am Post subject: IFR Requirements |
“Need” is an interesting word. There are hundreds of IFR Cessnas with only one Attitude Indicator, with a turn coordinator for backup. And they’ve got zero backup altimeters or ASIs.
FAA requirements for “backups” or “tiebreakers” of any sort are on an individual aircraft model installation basis for TC or STC. Since experimental aircraft don’t have TCs, it’s up to you how many or what kind of backups you have.
TDT
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bruce Gray
Sent: Monday, June 12, 2006 11:16 AM
Subject: RE: AeroElectric-List: IFR Requirements
Bruce
www.glasair.org
Posted: Mon Jun 12, 2006 8:01 am Post subject: IFR Requirements |
OK, I've been in enough pissing contests on this subject that I don't want another one. Do whatever floats your boat.
Just remember, the big iron guys have studied this issue for years and mega-bucks. I've seen reports of 5 tube EFIS airliners going dark in IFR where the only thing left was a flashlight and a vacuum ADI.
I have a 75k panel in my Glasair III and no EFIS. I wonder why?
Bruce
www.glasair.org
Posted: Mon Jun 12, 2006 8:21 am Post subject: IFR Requirements |
You won’t find a vacuum ADI on anything rolling off the Boeing or Airbus lines today. As they say, “The only vacuum on this plane runs the toilet” . . .
TDT
Sent: Monday, June 12, 2006 11:56 AM
Bruce
www.glasair.org
john.erickson(at)cox.net Guest
Dan,
A lot of people will respond with what they think or what they heard. Here's what I have in writing. Note that while most Experimental Operations Limits are fairly standardized, they may differ, so check the Ops Limits issued for the aircraft you're putting the EFIS in for specifics.
Here's what my Ops Limits say under the Phase II section.
"4. After completion of phase I flight testing, unless appropriately equipeed for night and/or instrument flist as listed in FAR 91.205 (b through e), this aircraft is to be operated under day only VFR."
OK, pretty straightforward. On to what FAR 91.205 b through e says...
FAR 91.205
(b) Visual-flight rules (day). For VFR flight during the day, the following instruments and equipment are required:
(1) Airspeed indicator.
(2) Altimeter.
(3) Magnetic direction indicator.
(4) Tachometer for each engine.
(5) Oil pressure gauge for each engine using pressure system.
(6) Temperature gauge for each liquid-cooled engine.
(7) Oil temperature gauge for each air-cooled engine.
( Manifold pressure gauge for each altitude engine.
(9) Fuel gauge indicating the quantity of fuel in each tank.
(10) Landing gear position indicator, if the aircraft has a retractable landing gear.
(11) For small civil airplanes certificated after March 11, 1996, in accordance with part 23 of this chapter, an approved aviation red or aviation white anticollision light system. In the event of failure of any light of the anticollision light system, operation of the aircraft may continue to a location where repairs or replacement can be made.
(12) If the aircraft is operated for hire over water and beyond power-off gliding distance from shore, approved flotation gear readily available to each occupant and, unless the aircraft is operating under part 121 of this subchapter, at least one pyrotechnic signaling device. As used in this section, “shore” means that area of the land adjacent to the water which is above the high water mark and excludes land areas which are intermittently under water.
(13) An approved safety belt with an approved metal-to-metal latching device for each occupant 2 years of age or older.
(14) For small civil airplanes manufactured after July 18, 1978, an approved shoulder harness for each front seat. The shoulder harness must be designed to protect the occupant from serious head injury when the occupant experiences the ultimate inertia forces specified in §23.561(b)(2) of this chapter. Each shoulder harness installed at a flight crewmember station must permit the crewmember, when seated and with the safety belt and shoulder harness fastened, to perform all functions necessary for flight operations. For purposes of this paragraph—
(i) The date of manufacture of an airplane is the date the inspection acceptance records reflect that the airplane is complete and meets the FAA-approved type design data; and
(ii) A front seat is a seat located at a flight crewmember station or any seat located alongside such a seat.
(15) An emergency locator transmitter, if required by §91.207.
(16) For normal, utility, and acrobatic category airplanes with a seating configuration, excluding pilot seats, of 9 or less, manufactured after December 12, 1986, a shoulder harness for—
(i) Each front seat that meets the requirements of §23.785 (g) and (h) of this chapter in effect on December 12, 1985;
(ii) Each additional seat that meets the requirements of §23.785(g) of this chapter in effect on December 12, 1985.
(17) For rotorcraft manufactured after September 16, 1992, a shoulder harness for each seat that meets the requirements of §27.2 or §29.2 of this chapter in effect on September 16, 1991.
(c) Visual flight rules (night). For VFR flight at night, the following instruments and equipment are required:
(1) Instruments and equipment specified in paragraph (b) of this section.
(2) Approved position lights.
(3) An approved aviation red or aviation white anticollision light system on all U.S.-registered civil aircraft. Anticollision light systems initially installed after August 11, 1971, on aircraft for which a type certificate was issued or applied for before August 11, 1971, must at least meet the anticollision light standards of part 23, 25, 27, or 29 of this chapter, as applicable, that were in effect on August 10, 1971, except that the color may be either aviation red or aviation white. In the event of failure of any light of the anticollision light system, operations with the aircraft may be continued to a stop where repairs or replacement can be made.
(4) If the aircraft is operated for hire, one electric landing light.
(5) An adequate source of electrical energy for all installed electrical and radio equipment.
(6) One spare set of fuses, or three spare fuses of each kind required, that are accessible to the pilot in flight.
(d) Instrument flight rules. For IFR flight, the following instruments and equipment are required:
(1) Instruments and equipment specified in paragraph (b) of this section, and, for night flight, instruments and equipment specified in paragraph (c) of this section.
(2) Two-way radio communications system and navigational equipment appropriate to the ground facilities to be used.
(3) Gyroscopic rate-of-turn indicator, except on the following aircraft:
(i) Airplanes with a third attitude instrument system usable through flight attitudes of 360 degrees of pitch and roll and installed in accordance with the instrument requirements prescribed in §121.305(j) of this chapter; and
(ii) Rotorcraft with a third attitude instrument system usable through flight attitudes of ±80 degrees of pitch and ±120 degrees of roll and installed in accordance with §29.1303(g) of this chapter.
(4) Slip-skid indicator.
(5) Sensitive altimeter adjustable for barometric pressure.
(6) A clock displaying hours, minutes, and seconds with a sweep-second pointer or digital presentation.
(7) Generator or alternator of adequate capacity.
( Gyroscopic pitch and bank indicator (artificial horizon).
(9) Gyroscopic direction indicator (directional gyro or equivalent).
(e) Flight at and above 24,000 ft. MSL (FL 240). If VOR navigational equipment is required under paragraph (d)(2) of this section, no person may operate a U.S.-registered civil aircraft within the 50 states and the District of Columbia at or above FL 240 unless that aircraft is equipped with approved distance measuring equipment (DME). When DME required by this paragraph fails at and above FL 240, the pilot in command of the aircraft shall notify ATC immediately, and then may continue operations at and above FL 240 to the next airport of intended landing at which repairs or replacement of the equipment can be made.
Reading this again makes things pretty clear. Basic Day/VFR equipment is listed first. Night VFR requires all the Day VFR equipment with some additions. IFR requires Night/VFR with some more equipment. Here's where another question typically arises when discussing EFIS use in IFR flight. FAR 91.205 (d) specifies Gyroscopic rate of turn, pitch and bank, and direction indicator. What is gyroscopic (especially since most (if not all) AHRS's do not have any moving parts at all. Here's what I copied off EAA's Homebuilt page (link is http://members.eaa.org/home/homebuilders/faq/1Equipping%20a%20Homebuilt%20for%20IFR%20operations.html and does require membership)
"What is a gyro?
The often-asked question is, what constitutes a “gyroscopic” instrument. Is an instrument containing an actual rotating mass gyro required, or are alternatives such as ring laser gyros or accelerometer-based instruments acceptable? Unfortunately, there is no specific definition of a gyroscopic instrument to be found in any FAA regulation or guidance document.
In order to try to answer this question, the EAA contacted the FAA Small Airplane Directorate in Kansas City, MO. The Small Airplane Directorate confirmed that there is no published guidance on this subject, but indicated that the function of the instrument is the main consideration. Any instrument that performs the function of the required gyroscopic instrument and presents info to the pilot in the same manner as the gyroscopic instrument will meet the requirement of 91.205, regardless of what mechanical or electronic means are used to generate the information and display."
Bottomline, it seems pretty obvious from all this that all of the popular EFIS systems out there meet the definition of gyroscopic instruments given above, satisfy the equipment required by the FAR's, and the requirements for instrument flight specified in the Ops Limits. Note that nowhere in any of this is there any requirement for any backup of any sort (other than the requirement in the Night/VFR section for spare fuses). I like your statement of "If not illegal, at least this is not safe enough for me." Remember the regs are a minimum. Lots of stuff to consider including electrical system design, quality of EFIS hardware AND software, installation, etc. However, once the regs are met, everything else is really personal preference. What one person feels is perfectly safe may seem to someone else incredibly unsafe. To each his own. I'm going to have backups in my RV-10.
John Erickson
RV-10 #40208 Wings
(I think this is my longest post ever... )
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dan Beadle
Sent: Monday, June 12, 2006 7:47 AM
Subject: IFR Requirements
Posted: Mon Jun 12, 2006 8:52 am Post subject: IFR Requirements |
Yes, they have that cute little battery operated Jet 2.25 ADI that costs 15k.
Bruce
www.glasair.org
Kellym
Posted: Mon Jun 12, 2006 8:59 am Post subject: IFR Requirements |
Note however, that every TC aircraft with glass panel, whether G-1000,
Avidyne or other, all had to put in the basic steam gages for their TC.
I suspect that the FAA is more concerned with electrical/panel failure
than they are with a mechanical gage that needs no power or vac source
to operate.
Quoting Tim Dawson-Townsend <Tdawson(at)avidyne.com>:
[quote] "Need" is an interesting word. There are hundreds of IFR Cessnas with
they've got zero backup altimeters or ASIs.
FAA requirements for "backups" or "tiebreakers" of any sort are on an
experimental aircraft don't have TCs, it's up to you how many or what
TDT
Gray
Subject: RE: IFR Requirements
Bruce
www.glasair.org
KCHD |
bferrell(at)123mail.net Guest
Posted: Mon Jun 12, 2006 9:56 am Post subject: IFR Requirements |
Dan -
And to add another datapoint, my FAA (Cincinnati) regional inspector who will do
my op limits stated that he had no concerns with my self-certifying that my dual
BMA EFIS system met these requirements (no vacuum system at all, no round
gauges). Folks need to do what they're comfortable with, and do so from a
position of knowledge, but I agree that it's pretty clearly established what is
"required".
Brett
Quoting John Erickson <john.erickson(at)cox.net>:
| Quote: | Dan,
in my RV-10.
John Erickson
RV-10 #40208 Wings
Note that Garmin or Avidyne probably could have satisfied the FAA if
they installed two EFIS systems (with 2 ADAHRS) on separate buses, as
long as the aircraft had an appropriate electrical architecture. (note
Cirrus' backup ADI is electric) Then one could eliminate the "steam
gauges."
Of course, two EFISs starts to add up to $$ . . .
TDT
brinker(at)cox-internet.c Guest
Posted: Mon Jun 12, 2006 10:04 am Post subject: IFR Requirements |
I would like to read the reports. Not trying to be a smart alex just out of curiosity.
Randy
Posted: Mon Jun 12, 2006 10:32 am Post subject: IFR Requirements |
Accually GRT is now offering a dual ahrs system for $1500 extra. From
my understaning both ahrs's are in the same enclosure, but funtion
indipendently. for experimental use only of course.
Randy
Posted: Mon Jun 12, 2006 11:24 am Post subject: IFR Requirements |
I found this PROBABLE CAUSE: "Numerous electrical anomalies as a result of a loose main battery shunt connection and undetermined electrical system causes." at http://aviation-safety.net/database/record.php?id=19960528-0
It would seem they had no control over their dc bus. I would say this is a good reason for anyone building an airplane to go with a pilot operated e-bus.
Randy
rv8ch
Posted: Mon Jun 12, 2006 11:27 am Post subject: IFR Requirements |
Although they didn't lose radios in the above incident, if I were
flying transatlantic today, I'd bring a handheld. You sure
don't want to try to come into the US NORDO. Divert to Canada.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
Posted: Mon Jun 12, 2006 12:09 pm Post subject: IFR Requirements |
John,
Thank you for the thoughtful reply.
I had read the regs several times and had visited the EAA site. I just didn’t quite put it together as you have. I am comfortable with dual, independent systems on separate battery busses. In the unlikely event of a lightning strike, I might lose both, but I can live with that.
I probably will go with the dual battery, dual EFIS, dual AHRS system and no gyros. I may have to educate the DAR for sign-off, but it should be doable.
Thanks.
Dan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Erickson
Sent: Monday, June 12, 2006 9:19 AM
Dan,
"4. After completion of phase I flight testing, [b]unless appropriately equipeed for night and/or instrument flist as listed in FAR 91.205 (b through e[/b]), this aircraft is to be operated under day only VFR."
FAR 91.205
(2) Altimeter.
"What is a gyro?
John Erickson
RV-10 #40208 Wings
Posted: Mon Jun 12, 2006 1:14 pm Post subject: IFR Requirements |
Tim,
Just to throw another data point on the fire, it's my understanding that the
G1000 and Avidyne systems in certified aircraft are certified as secondary
flight instruments. The round steam gauges are considered the primary flight
instruments by the FAA.
Bruce
www.glasair.org
BobsV35B(at)aol.com Guest
Posted: Mon Jun 12, 2006 3:34 pm Post subject: IFR Requirements |
In a message dated 6/12/2006 12:57:56 P.M. Central Standard Time, bferrell(at)123mail.net writes:
| Quote: | Dan -
"required".
Brett
Good Evening All,
May I add another small comment?
The FAA has only recently started to interject a need for redundancy in IFR aircraft. Anything approved before the FAA got on this kick is not required to have ANY redundancy.
Personally, I don't think they should be able to make such a requirement.
It is my opinion that it is up to the operator to decide what level he/she is comfortable with.
If you talked to ALPA they would tell you that no airplane should be allowed in the sky unless it had a minimum of two engines and two pilots.
I think one engine, one pilot, one generator, one battery, one radio and one gyro instrument is all the regulations should require. If I want more, I will add it.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
Posted: Mon Jun 12, 2006 4:44 pm Post subject: IFR Requirements |
Not true.
TDT
RV-10 40025
flyboy494
Posted: Mon Jun 12, 2006 6:47 pm Post subject: IFR Requirements |
To take this thread in a little different direction, what is everyone's thoughts on Sporty's electric backup attitude indicator?
Kent
---- Tim Dawson-Townsend <Tdawson(at)avidyne.com> wrote:
Not true.
TDT
RV-10 40025
