ghf4986(at)gmail.com Guest
Posted: Sun Jun 09, 2013 8:40 am Post subject: Engine problems, stuck in Red Bluff, CA |
Ignition grounds?
Sent from an IPad
On Jun 9, 2013, at 9:12 AM, Sonja Englert <paqs345(at)gmail.com (paqs345(at)gmail.com)> wrote:
Hello Everyone,
I am stuck at the Red Bluff airport because me Rotax 912 is running really rough and I have no idea what it could be. It is worst below 3000 rpm, smoother at higher rpm. Switching tanks and boost pump on/off has no effect. Switching ignition hs no effect. I don't see anything loose, leaking or otherwise wrong. It has enough fuel and oil and the spark plugs look good.
It has done this once before and after several startups and short runs on the ground it smoothed out and run fine for the next 5 h. Now it is worse and not smoothing out.
Does anyone have any ideas?
Sonja
ttp://www.matronics.com/Navigator?Pulsar-List
ics.com
.matronics.com/contribution
331bp
Posted: Sun Jun 09, 2013 9:22 am Post subject: Engine problems, stuck in Red Bluff, CA |
Check the welch plugs on the top of the carbs. I had one come loose which causes that diaphragm to get out of sync with the other carb.
Hope that helps,
Bill Coleman
On Jun 9, 2013, at 11:09 AM, Sonja Englert <paqs345(at)gmail.com (paqs345(at)gmail.com)> wrote:
[quote]Hello Everyone,
Sonja
freedom4life(at)xtra.co.n Guest
Posted: Sun Jun 09, 2013 1:27 pm Post subject: Engine problems, stuck in Red Bluff, CA |
Hi Sonja
Check the plugs for soot on the insulator. If you don’t have a second set of plugs to try then close up the plug gap to about 18 – 20 thou. This will prevent the spark tracking down the insulator. The other thing you might look for is an HT lead that has rubbed through on the block somewhere. I have had both issues happen to me.
Cliff
Sent: Monday, June 10, 2013 3:09 AM
To: pulsar-list (pulsar-list(at)matronics.com)
Subject: Engine problems, stuck in Red Bluff, CA
Hello Everyone,
Sonja
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
w7ikt(at)fly-web.us Guest
Posted: Sun Jun 09, 2013 3:04 pm Post subject: Engine problems, stuck in Red Bluff, CA |
Check the compression.
After running look for the cooler cylinder with one of the point temperature meters
God Bless
Bob (W7IKT) Carol (N5CBQ) Heiser
On 6/9/2013 10:09 AM, Sonja Englert wrote:
[quote] Hello Everyone,
Sonja
Checked by AVG - www.avg.com
06/08/13 [b]
everettmcollier(at)yahoo. Guest
Posted: Sun Jun 09, 2013 5:57 pm Post subject: Engine problems, stuck in Red Bluff, CA |
Sonja,
We live in Lake California, about 10 miles north of Red Bluff.
I have no idea what the problem is, but we are close, only about 18 mi by car. If you could use help with tools or anything please call 530-347-4988. Should be happy to assist in any way I can. Can not fly down though my nose gear is under repair.
Everett
Sent from my iPad.
paqs345(at)gmail.com Guest
Posted: Mon Jun 10, 2013 6:45 am Post subject: Engine problems, stuck in Red Bluff, CA |
Hello Everyone,
Fortunately I'm back home.
My problem turned out to be an induction system leak through the
primer system. I was able to make a temporary fix by disabling the
primer and fly it home after a few hours delay for troubleshooting.
Thanks everyone for the suggestions.
Sonja
On 6/9/13, Sonja Englert <paqs345(at)gmail.com> wrote:
| Quote: | Hello Everyone,
look good.
Sonja
