dustinp(at)hughes.net Guest
Posted: Mon Jun 12, 2006 12:24 pm Post subject: Organization of power bus |
I seem to recall reading a recommendation on this list of a particular order in which various electrical loads should be placed on the power bus in order to minimize interference / noise propagated to other equipment whose power came from the same bus.
For instance locating the power lead for the strobes, with its pulsating power requirement at one end of the bus or the other to lessen the effect on other equipment with power leads located before or after it on the bus.
I can't seem to find this info searching the archives, and wonder if anyone could refresh this info if in fact it actually is true.
Dustin Paulson
GlaStar builder
nuckollsr(at)cox.net Guest
Posted: Mon Jun 12, 2006 5:07 pm Post subject: Organization of power bus |
At 03:20 PM 6/12/2006 -0500, you wrote:
| Quote: | I seem to recall reading a recommendation on this list of a particular
Not true.
Order your systems in any way that pleases you.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
