		wdaniell(at)etb.net.co Guest
				 Posted: Sat Jan 14, 2006 1:37 pm    Post subject: Wing skin separation HELP |
				I have made an error in construction in the interior of the wings and very
 cleverly close then (with the error inside).
 So now I have to open them again.
 Any ideas anyone?
 Will
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Sat Jan 14, 2006 2:52 pm    Post subject: Wing skin separation HELP |
				Will.....
 Which kind of wings Foam or the later XS skinned wings and what area
 /what error are you trying to fix?
 Bob Harrison G-PTAG Europa MKI/Jabiru3300
				 Posted: Sat Jan 14, 2006 3:36 pm    Post subject: Wing skin separation HELP |
				I guess I had better 'fess up.
 I did the reinforcements 0/90 instead of 45deg.  And then adding really dumb
 behaviour to stupidity, I closed the wings out and then realized what I had
 done...
 I talked to andy about this and he said that the general opinion was to open
 up and do them again.  He suggested heat and wished me luck!  He was very
 nice about it
 I am currently trying to heat up the skins to loosen the Araldite but I am
 getting the distinct feeling that I will end up without useful skins and
 with damage to the underneath structure.  So I fear than unless anyone has a
 bright I idea that new skins are the order of the day.  Expensive.
 So any ideas or help gratefully received.  Anyone got a spare pair of skins
 - or perhaps someone who changed standard wings for glider wings?
 Will
				 Posted: Sat Jan 14, 2006 4:45 pm    Post subject: Wing skin separation HELP |
				Hi! Will..
 I would have thought a heat gun applied to the joint in one place at a
 time and gradually prise the skins apart with a wedge or blunt chisel
 would be a possibility. However I'm not an XS man and so unaware of
 where you will be applying heat and at how many points. Why not make one
 or two test pieces of waste bonded together to develop a technique prior
 to setting to work on the wing?
 Bob Harrison.
		kheindl(at)msn.com Guest
				 Posted: Sun Jan 15, 2006 3:01 am    Post subject: Wing skin separation HELP |
				Will,
 Using just a heat gun would make it very difficult to get started. If it was
 me I would make up a "heat box" out of wood, with a long about 2 inch
 opening, with a heat gun at each end. It would need some holes to let the
 hot air escape. Hold it on top of the joint long enough to let the redux
 soften (trial and error) . Using a spatula, try lifting the skin along that
 section. Once you get one end separated, you may be able to loosen the
 remainder with just a heat gun and metal spatula.
 Karl
  	  | Quote: | 	 		  From: "William Daniell" <wdaniell(at)etb.net.co>
 Reply-To: europa-list(at)matronics.com
 To: <europa-list(at)matronics.com>
 Subject: Wing skin separation HELP
 Date: Sat, 14 Jan 2006 16:36:28 -0500
 Any ideas anyone?
 Will
		n3eu(at)comcast.net Guest
				 Posted: Sun Jan 15, 2006 10:17 am    Post subject: Wing skin separation HELP |
				My attempt to soften Redux, after it had cured a couple weeks, was too a
 failure.  Too much heat required, verses heat to damage the glass
 structure, which conducts heat poorly to get at the green stuff.  For my
 safety at least, I would be assuming this procedure might give me a
 potential airworthiness problem to forever worry me in severe
 turbulence.
 I'm surprised the factory would advise -- not knowing any builder's
 skill level -- removal by any method other than panel destruction and
 replacement (requiring essentially $$, that's all!).  Otherwise a
 Hobson's choice on structural integrity, attempting a fix, the moral
 equivalent of "don't force it...use a bigger hammer."
 I don't have this style wing, but merely perused the XS manual online.
 It's my opinion that the primary purpose of the tapes is such that
 improper orientation of the fibers matters only a little, but I have no
 credentials to say that.  But, when we add two more tapes, we do stiffen
 the ass'y there further, concentrating stresses elsewhere.  That could
 mean a "seven yard gain, with a five yard penalty," as in U.S. football.
 So, if the factory can analyze that one with engineering analysis to say
 no harm, they should be able to say computationally why -- in stress
 paths -- 90 on the tapes is not good.  Or more likely just their gut
 reaction and "usual rules" for FG construction.
 The only thing I would not do was a fix which may compromise the
 structure worse than the original problem.
 Reg,
 Fred F. (nickname "Hobson")
		ami(at)mcfadyean.freeserv Guest
				 Posted: Sun Jan 15, 2006 10:49 am    Post subject: Wing skin separation HELP |
 Merely reduces strength by 30%!
 Would need to do another load test on the wing to confirm the effect.
 Duncan McF
				 Posted: Sun Jan 15, 2006 11:26 am    Post subject: Wing skin separation HELP |
				Duncan McFadyean wrote:
 I guess you mean tensile strength of the tape + resin, not the whole
 structure, but I'd a guessed more than 30.  However, there's stresses
 from several directions here -- up/down in Gs, aft in drag, and twist
 (flap and aileron).  But as to G forces, she tested beyond 10Gs, so
 maybe now 9Gs due to the tape problem?  Who knows. We need only 3.8G for
 utility category safety, though, but I understand the conundrum, is all.
 Reg,
 Fred F.
				 Posted: Sun Jan 15, 2006 11:55 am    Post subject: Wing skin separation HELP |
				Inverse of the square root of 2. Or 0.707.
 Applied at 90 deg, half of the cloth is redundant to stresses orientated
 with weft or warp.
 Duncan McF.
		rowil(at)clara.net Guest
				 Posted: Sun Jan 15, 2006 3:16 pm    Post subject: Wing skin separation HELP |
				At 2006-01-14 18:35 -0500 William Daniell wrote:
  	  | Quote: | 	 		  I am currently trying to heat up the skins to loosen the Araldite but I am
 Will - I suggest you talk to some of the glider repair people before
 doing anything irrevocable. People like Gary McKirdy or Martin
 Carolan would probably have a way to get in & out without buying new
 wing skins. Don't know if they inhabit this list, though. If you wish
 I can forward your query to them off-list. They are in UK so if you
 are elsewhere they can only offer advice - but that might be all you
 need!
 regards
 Rowland
 | Rowland Carson  PFA #16532 <http://home.clara.net/rowil/aviation/>
 | 750 hours building Europa #435 G-ROWI  e-mail <rowil(at)clara.net>
		dglauser(at)gmail.com Guest
				 Posted: Sun Jan 15, 2006 6:17 pm    Post subject: Wing skin separation HELP |
				I had a similar problem after closing my wings. In my case, the plys were in
 the correct orientation but there were some gaps between the rear closeout
 and both the base and the top. (I found these with the aid of a small TV
 camera on the end of a stick, run through panels cut un the wings.) After
 consultation with Kim Prout, I cut access panels out of the wing and did the
 repairs through the holes. Then I closed the holes using the usual
 techniques - add a large flange around the hole that overlaps well onto the
 wing (inside), then use the cut-out piece of wing as a closeout panel after
 applying reinforcement to it too.
 dg
 On 1/15/06, Rowland Carson <rowil(at)clara.net> wrote:
  am
  need!
  regards
  Rowland
		davedeford(at)comcast.net Guest
				 Posted: Sun Jan 15, 2006 10:41 pm    Post subject: Wing skin separation HELP |
				William,
 I think the best heat source for separating the Araldite skin joints is a
 flat silicone heat blanket, perhaps an inch wide by a foot or two long (see
 www.mcmaster.com, part number 35765K154 for an example of what I am talking
 about).  A fiberglass tape heater or Kapton heater would work also.  With a
 contact heater, you can keep the heater temperature just slightly above the
 desired temperature of the joint, leaving it there for a few minutes, until
 the Araldite has softened.  The hot air from a heat gun must be much hotter
 than the ultimate temperature of the joint, and it will rapidly overheat the
 thin fiberglass/foam sandwich adjacent to the solid fiberglass/epoxy joint,
 probably damaging it before the joint can get up to temperature.  When the
 Araldite has softened, it should be possible to slide a putty knife between
 the skin and the rib or spar.  The best place to start is at a corner.  The
 good news (in my experience) is that the glass transition temperature of the
 Araldite is lower than that of the laminating resin, so the joint should
 soften before the skin delaminates.
 For best control of the heating rate, run the heater from a variable
 autotransformer (Variac) or a lamp dimmer.  Putting a thermocouple between
 the heater and the skin lets you know how the heating is progressing.  While
 I have not tried to separate fiberglass joints this way, I have used this
 heating setup to deform the upper "shelf" portion of the fuel tank, as it
 was interfering with the wing spar, and preventing rigging of the wings (a
 problem with the early XS construction manuals).  The temperature range
 between hard (too cold) and runny (too hot) for the plastic tank is narrow
 enough to require fairly delicate temperature control.
 Good luck!
 Dave DeFord
 N135TD (XS monowheel)
				 Posted: Mon Jan 16, 2006 7:18 am    Post subject: Wing skin separation HELP |
				Here is what I wrote to Jerry.
 Let me say it was very pleasant to have a group of guys rooting for one in
 the face of a great disappointment.  Only someone who has built one of these
 can understand the feeling of having made a significant mistake and having
 to go back and correct it.
 Thanks to all.
 Will
 "I have attacked the wing skin.  Weapons of choice wood chisel, wood plane
 and sanding disk.  Thatll teach the bugger!  New skins ordered.
 No way that I can see of saving the skin  or more accurately - might save
 the skin but ruin the wing
 I thought of making a new top skin (making a polyester mould) but discarded
 this idea when I realized that the upper skin changes in construction from
 tip to root  the root area is considerably stronger.
 Two steps forward one (and ) steps back."
 Will
		asarangan(at)yahoo.com Guest
				 Posted: Tue Jan 17, 2006 5:28 pm    Post subject: Wing skin separation HELP |
				I doubt you will be able to soften the Araldite without deforming the
 top skin. I would not try to save the skin, but focus on saving the
 bottom mating flange. If you lose that flange, life could get more
 difficult. One option is to cut through the top skin, and then grind
 away the remaining portion bonded to the flange.
 My feeling is that the reinforcement plies can't be all that critical
 to warrant compromising the entire integrity of the wing. I would
 proceed with the construction and evaluate the options as the projects
 gets closer to the end.
 I decided a long time ago not to bond the top skin until the aircraft
 is almost ready to fly. Bonding the skin does not take a lot of time,
 and you never know what you might want to install at the last minute.
 It is better to keep the options open as long as possible.
  really dumb
  I had
  done...
  to open
  very
  nice about it
  I am
  and
  anyone has a
  skins
  Will
				 Posted: Tue Jan 17, 2006 6:22 pm    Post subject: Wing skin separation HELP |
				Agreed - now - but too late!
 Destruction of top skin started!  You are right - I am more comfor4table
 with grinding off the top skin than trying to heat release the araldite for
 the reasons you give.
 However I suspect (now that I know about the construction of the wing skins
 in some detail)  that the wings skins play an important role in stiffening
 the wings and therefore the incidence should be set with the upper skin in
 place.
 Having said that I have no basis for this whatever.
 Will
		rogerjohnsheridan(at)yaho Guest
				 Posted: Wed Jan 18, 2006 3:29 am    Post subject: Wing skin separation HELP |
				I heard a good saying on the radio today:
 "Anyone who never made a mistake, never made anything"
 Good luck!
 Rog S
				 Posted: Wed Jan 18, 2006 3:45 am    Post subject: Wing skin separation HELP |
				Thanks - Will
 PS maybe I was just dumb enough to confess!
