Kellym
Posted: Tue May 28, 2013 12:11 pm Post subject: how can I find out the gear reduction for the governor driv |
Yes, the -3 works with some adjustment. However, the -5 has the correct
gear reduction and pressures to begin with, so given the opportunity to
get the correct one rather than having to make adjustments, for the same
money seems like one of the easier build decisions.
On 5/28/2013 8:03 AM, rv10flyer wrote:
My -3 also has worked fine after some minor speed adjustments. I spoke to MT and it is acceptable.
The -3 or -5 defines the settings– relief valve pressure, max. RPM, control arm travel and position etc.
Wayne G.
SB 12/01/2009-12/01/2011
TT= 103
http://forums.matronics.com/viewtopic.php?p=401477#401477
Checked by AVG - www.avg.com
KCHD |
