mmul6471(at)bigpond.net.a Guest
Posted: Fri Jun 09, 2006 7:54 pm Post subject: DOUBLE FLARING |
Greetings Listers, I have been told that the safest way to treat flares
brake and fuel fittings is with a double flaring tool. I can get my hands
on a double flaring tool, but it is a 45degree fitting not 37 degree. I was
thinking that I could use the double flaring tool to make the initial folded
over flare, then my single 37degree flaring tool to finish it off. Does
anyone see a problem with this approach??
Thanks, Mick
khorton01(at)rogers.com Guest
Posted: Sat Jun 10, 2006 4:29 am Post subject: DOUBLE FLARING |
On 9 Jun 2006, at 23:53, Mick Muller wrote:
flares brake and fuel fittings is with a double flaring tool. I
can get my hands on a double flaring tool, but it is a 45degree
fitting not 37 degree. I was thinking that I could use the double
flaring tool to make the initial folded over flare, then my single
37degree flaring tool to finish it off. Does anyone see a problem
The only problem is that there is no service history for this
technique, so there is no way to know how likely a failure is. It
might be acceptable, or they might have a high failure rate.
I wouldn't use this technique on any flare where the failure could
cause a safety problem. Fuel and brake lines are not a great place
to be using an unproven technique.
Yes, double flares are probably a bit more reliable than single
flares. But, there are many thousands of aircraft flying with single
flared tubes, and they aren't falling out of the sky because of
them. Either buy the right double flaring tool, or stick with single
flares.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
jcimino(at)echoes.net Guest
Posted: Sat Jun 10, 2006 7:56 am Post subject: DOUBLE FLARING |
I don't think aluminum line will take well to double fares. You would also
have to remove it from your tool and put it in the 37 degree tool which
would not work well. Single fares are the standard for aviation and works
well, I don't think there is any need to go to double fares. The pressures
we are running are just not that high.
Jim
Jim Cimino
N7TL
RV-8 S/N 80039
150+ Hours
http://www.geocities.com/jcimino.geo/
Posted: Sat Jun 10, 2006 8:11 am Post subject: DOUBLE FLARING |
I myself don't see too much of a problem with that scenario. However, I
don't think a double flare is a standard aviation activity. I'm not
sure if a double flare is 'safer' than a single flare anyway. A double
flare just adds 'meat' to the flare, allowing the compression to take
care of any differences between the tube and the fittings. However,
having said that, those brake lines with double flares are STEEL, not
aluminum, and doing all that stretching necessary for a double flare in
aluminum tubing may make the tubing more susceptible to cracking, and
furthermore the cracking may be inside the folded part where you can't
see it.
I commented on the thread about sealants, and I had a brain fart ......
I was thinking of metal brake lines, and there may be nylon brake lines
in the leaking assembly. But then they'd be compression fittings with
the nylon tube, not flare. So, I'm confused. ..... I don't like the
nylon tubeing as brake lines, but that's just my personal feelings.
However, I do see a lot of homebuilts with the nylon tubeing with
leaking problems. Most problems are due to leaving out the internal
ferrule ..... the part that looks like a rivet with a hole through it.
The internal ferrule is there to give the outside compression ferrule
something to squeeze the tubeing between.
Linn Walters
Mick Muller wrote:
flares brake and fuel fittings is with a double flaring tool. I can
get my hands on a double flaring tool, but it is a 45degree fitting
not 37 degree. I was thinking that I could use the double flaring tool
to make the initial folded over flare, then my single 37degree flaring
tool to finish it off. Does anyone see a problem with this approach??
Thanks, Mick
http://wiki.matronics.com
chaztuna(at)adelphia.net Guest
Posted: Mon Jun 12, 2006 5:11 am Post subject: DOUBLE FLARING |
Mick,
I had considered doing EXACTLY what you propose. However, I found
that the vise block on the automotive double flaring tool had
serrations designed to prevent slippage of the steel automotive
tubing. These serrations imprinted themselves onto the soft aluminum
tubing. These creates stress risers, which I found unacceptable. I
created a "favorite search" for the correct tool on EBay. After
several months, I was able to purchase the tool for $137.
Check with your A&P friends or your local EAA Chapter. They may be
willing to loan or rent you the tool.
Charlie Kuss
tool to make the initial folded over flare, then my single 37degree
flaring tool to finish it off. Does anyone see a problem with this approach??
Thanks, Mick
