maurv8(at)gmail.com Guest
Posted: Thu May 16, 2013 4:39 pm Post subject: Z13/8 all electric airplane |
I'm using your Z-13/8 diagram wiring my RV-8 and want to use a CB Switch combo to replace the individual circuit breaker and switch for the AUX ALT ON/OFF SWITCH. The circuit breaker has two terminals labeled line & load. Which one do I hook to GND?
Mauri Morin
Posted: Fri May 17, 2013 9:08 am Post subject: Z13/8 all electric airplane |
At 07:38 PM 5/16/2013, you wrote:
| Quote: | Bob,
Either one.
Bob . . . [quote][b]
jonlaury
Posted: Sat May 18, 2013 12:39 pm Post subject: Re: Z13/8 all electric airplane |
(at) Bob: "Either one" really?
I may be missing something here, but wouldn't " Line" indicate the battery and "load" would indicate the Aux Alt field.
If "Line" is Batt Positve, connecting "Load" to ground will trip the breaker.
Posted: Sat May 18, 2013 3:06 pm Post subject: Z13/8 all electric airplane |
At 03:39 PM 5/18/2013, you wrote:
| Quote: | --> AeroElectric-List message posted by: "jonlaury" <jonlaury(at)impulse.net>
yep, here's a thread from 2008
I am rewiring my Navion panel using busses with Potter-Brumfield W31
switch breakers and Klixon 7277 c/b's. I put the P-B buss bar on the
bottom following their Load-Line labeling but put the Klixon bar on top to
ease access to the load terminals. My IA neighbor (not my supervising IA)
tried to tell me it was backward but I had already checked and there is no
labeling on the Klixon c/b's. I see no intuitive reason it should care
about polarity but then I don't have a real understanding of their inner
workings. Did I miss something? Does polarity matter for the Klixons? If
so, I can change my buss. If not, why does P-B label their units (it's
also on their W23 c/b's?) Is it real or just a case of eliminating choice?
Thanks for the education.
BN: Intuitively, the physics of a series-connected
heat-tripped, switch do not suggest a reason why
the breaker would care which way electrons flow
through it . . . and in particular, AC system
breakers where electrons are known to turn around
and run the other direction 120 times a second!
You've already had some good responses but I'll
take this opportunity to elaborate. Not all
breakers are rudimentary . . . i.e. a simple
spring-loaded, heater-tripped latch holding a
set of single or double-break contacts closed.
Breakers can be had with auxiliary switches,
indicator lights, voltage sense coils, and
all manner of enhancements where proper function
of the enhancement depends on a connection to
power being available even when the breaker is
open. Obviously, some third terminal is necessary
for an enhancement to function, this is sometimes
an obvious connection, or perhaps it gets hooked
up through the mounting.
In any case, it's not uncommon for a manufacturer
to use common tooling to mold a breaker housing
for all versions, hence you often see the word
"load", "line" or both formed right next to the
breaker's terminals . . .
I've asked several tech reps for breakers and
except for enhanced breakers, orientation in
the system doesn't matter. Interestingly enough,
if an electrician encounters "line" and/or "load"
labels on a breaker, he'll wire it up that way
whether it matters or not. And I suspect many
aviation techs do too . . . not because the
physics matters but because some inspector who
doesn't know any better can be counted on to
insist that the protocols be followed.
The only time I've encountered this as a
"problem" is when a builder finds it convenient
to fabricate a two-row bus-bar and take load
feeders off opposite ends of the breaker. When
they come stamped with a breaker rating,
they look pretty funky with one row upside-down
in their holes!
jonlaury
Posted: Sun May 19, 2013 7:18 am Post subject: Re: Z13/8 all electric airplane |
[/quote]
yep, here's a thread from 2008...
Bob . . . [quote]
My question was less about electron directional flow than it was about the fellow's intention to connect the switch/breaker to GND. Unless he is switching/breaking the GND to control the alternator field, which I thought in most instances was bad practice, isn't he wiring up a dead short that will trip the breaker everytime the alt field is switched on?
Bob McC
Posted: Sun May 19, 2013 9:05 am Post subject: Z13/8 all electric airplane |
Jon;
Did you look at schematic Z13/8 to see what is being discussed?? There is
no "field" associated with the AUX alternator as it's a PM type. (Dynamo in
the dwg) The schematic clearly shows the breaker and switch connected
between the alternator "B" lead relay and ground. And yes, when the over
voltage module operates it causes a direct short to ground through this
breaker tripping it.
Bob McC
[quote] --
_________________ Bob McC
Falco #908
(just starting) |
Posted: Sun May 19, 2013 10:38 am Post subject: Z13/8 all electric airplane |
| Quote: | My question was less about electron directional flow than it was
As Bob suggests . . . trace the circuit.
The alternator control switch is used to
energize a relay that connects the PM
alternator to the BUS.
The control relay coil is paralleled with
a crowbar OVM . . . open circuit 99.99%
of the time but becomes a dead short
when voltage across the device exceeds
about 16.4 volts.
The "short" across the relay coil would
indeed force it to relax the contacts and
disconnect the offending alternator from
the bus. But it would also burn the wires
that supply power to the relay coil through
the closed switch.
The goal for keeping one's cockpit smoke free
suggest some form of fault current mitigation
like a fuse, breaker, polyswitch, etc.
In this case it's a breaker which can be ANYWHERE
along the series path from bus to ground.
Actually, I've been contemplating replacement of
the breaker in that drawing with a polyswitch.
Given the low current demands for driving the
relay coil, this would be an excellent place
to incorporate a polyswitch. I'm wrestling
with annunciation issues. A popped breaker is,
not a great annunciator but it's not bad. If
we 'hide' a tripped condition by going solid
state polyfuse, then perhaps some form of OV
TRIP indication is called for.
I've got some ideas and will incorporate the
most elegant configuration into the Z-figures
that control PM alternators with the RELAY/OVM
combination.
jonlaury
eschlanser
Posted: Thu May 23, 2013 8:37 am Post subject: Re: Z13/8 all electric airplane |
Instead of a polyswitch in the PM alternator circuit, may I suggest using the Linear OVP module from PerhelionDesign.com? http://www.periheliondesign.com/lovm.htm
Disclaimer: I have no connection with the company except for using the LOVP instead of crowbar OVM/RELAY combinations in both main alternator (IR) and aux alternator (SD8) circuits in my project's Z-13-8 derived electrical system.
I had considered using polyswitchs. True, the LOVP module is way more expensive than polyswitches. But in return for the cost, the engineering work has been done. It has provision for an Led lite annunciator and a reset feature. I don't understand all the engineering, but it seems to me that a thermally activated polyswitch is not under the pilot's control. After cooling, wouldn't it keep trying to reset itself?
I'd like to see how you would use the Perhelion LOVP in Z13/8 as I struggled with the wiring.
Eric S.
Z13/8 in a W-10 Tailwind/O-320 project
[/quote]
combination.
Bob . . .[/quote]
Posted: Thu May 23, 2013 10:19 am Post subject: Z13/8 all electric airplane |
At 11:37 AM 5/23/2013, you wrote:
That is one of many ov management options
used in vehicular DC power systems . . .
| Quote: | I had considered using polyswitchs. True, the LOVP module is way
The polyswitch does not go open, only to a high
resistance state which keeps drawing enough current
to STAY in that high resistance state. This means
that fault current that would put wiring at risk is
limited to some acceptably low value. In the
case OV management for the PM alternator, the
NORMAL current that holds the relay closed will
not drip the polyswitch. A dead short OV module
connected across the relay would burn wires unless
a fuse, breaker or polyswitch did not respond to
limit the current. Fuses and breakers take the current
to zero . . . the polyswitch takes it to some low,
non-hazardous value. Either philosophy is consistent
with Z-13/8 design goals.
In the interim, I've once again backed off the incorporation
of the polyswitch. NOT because it fails to function
as advertised but because it's designed to mount to
an ECB. Artful incorporation of the polyswitch into
Z-13/8 PM alternator control calls for mounting it
into some fabricated assembly. I looked at a surface
mounted device on an ECB along with resistors to
drive a 'tripped' indicator light.
Too much monkey motion . . . so my track record is
still intact. Since my first introduction to the
realm of inrush limiters and polyfuses at LearJet
in 1980, I've not discovered an elegant way to
incorporate these critters into airframe system
wiring. They work fine as a component INTERNAL to
a black box.
| Quote: | I'd like to see how you would use the Perhelion LOVP in Z13/8 as I
You use it per the installation instructions. It's
wired in series with the device that you want to
shut down in the event of an ov condition.
The point of Z13/8 is to mitigate "struggling". The
drawing is not intended to be the epitome of systems
but simply an elegant solution that meets design goals
for the system.
There are certainly useful variations on the theme
that can and should be considered if the drawing
as-presented fails to meet some other design goal.
Assuming you perceive a need to depart from the
suggested wiring, what new or overlooked design goal
needs attention? In other words, what feature of Z-13/8
drives your willingness/need to "struggle"? What
changes are you considering and what is the anticipated
return on investment for the change?
eschlanser
Posted: Thu May 23, 2013 3:01 pm Post subject: Re: Z13/8 all electric airplane |
Thank you for the education on the polyswitch. Once again, you cleared up an electrical design for me.
Z13/8 is awesome. The only reason I changed anything in Z13/8 was due to the advertising for the LOVP. The marketing sold me on it. However, the LOVP has more wires and connections than the crowbar OV, making it more involved to incorporate.
For this first timer, anything electrical is a struggle. I should have built the absolute simplest system, Z11, first. Then, I could have worked my way up to Z13/8 after getting some practical experience in the art.
Attending one of your seminars and studying the AEC have been great exposure to the formal discipline of aircraft electrical science.
Thanks again for so generously sharing your experience,
Eric S.
[/quote]
Bob . . .[/quote]
Posted: Thu May 23, 2013 4:42 pm Post subject: Z13/8 all electric airplane |
At 06:01 PM 5/23/2013, you wrote:
You're most welcome . . . it's what we do. Without
a doubt, the LVOP performs as advertised. My best
counsel is to set system desing goals and then
work for lowest parts count, weight and cost of
ownership.
I fiddled with a little different technique for
incorporating the Polyswitch into the PM alternator
OV protection . . . even came up with a little ECB
to carry a surface mount device along with the companion
resistors for trip annunciation. It would have been a
new product to offer . . .
Problem was that it applied to a limited number
of total situations for replacing a CB . . . namely
the disconnect relay for a PM alternator.
The 9024 4-function module is slated to replace crowbar
ovm in the control of PM alternators. So to spend $resources$
to spruce up a low-volume application slated to be obsolete
just didn't make sense.
Getting on the List and standing your own design goals
against recipes for success is the very best way to
strive for the elegant solution. It's a collegial service
I enjoyed during my tenures at Electro-Mech and Beech.
No reason it shouldn't work here too.
