robin(at)PaintTheWeb.com Guest
Posted: Mon Apr 22, 2013 6:13 pm Post subject: LOP Article - FLYING magazine |
There is an article on LOP operations in the April issue of FLYING. Yes I know the May issue is in hand but I am just getting around to it. The article has a simple graph and discusses the physics of LOP ops. It also discusses some history of why LOP ops and why there may be some historical misunderstanding or the procedure. Peter Garrison is an advocate of LOP operations as I am but he even goes LOP right after takeoff and climbs out at 65% power or less. Not sure I would get acceptable climb rates but I may give it a try at some point.
Article Name: The Passion of Mixture
Robin
Kelly McMullen
Posted: Mon Apr 22, 2013 6:22 pm Post subject: LOP Article - FLYING magazine |
| Quote: | No reason to limit yourself to 65% power LOP for climb. Many of the
Bonanza guys operate at 85% power LOP by doing the big mixture pull once
safely into cruise climb. If you simply pull back to 14.8 gph while at
full throttle, you will be LOP at 85%. |
On Mon, Apr 22, 2013 at 7:12 PM, Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)> wrote:
Robin
tp://forums.matronics.com
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
rv10flyer(at)live.com Guest
Posted: Mon Apr 22, 2013 6:46 pm Post subject: LOP Article - FLYING magazine |
Robin;
I do just that, I take off full power, at 1000ft AGL reduce rpm to 2500rpm, pull the throttle back to 65% and Lean out to 10.5 gph- which is what I know is close enough for normal, based on testing this scenario, my CHT’s stay low and I climb out at 120-130kts as I climb, I continue to give it more throttle to keep it at 65%, the plane like this more, shown with lower pressures and temps, than full throttle and so do I when 20gph goes down by half but my speed doesn’t.
I also will do this and go to full throttle (after EMT) to get above the hills to the north of us. the forward speed keeps the temps lower than if I had left the throttle in the whole time.
Sent: Monday, April 22, 2013 7:12 PM
To: rv10-list(at)matronics.com (rv10-list(at)matronics.com) ; rv-list(at)matronics.com (rv-list(at)matronics.com)
Subject: LOP Article - FLYING magazine
Robin
rv10flyer
Posted: Mon Apr 22, 2013 7:08 pm Post subject: Re: LOP Article - FLYING magazine |
I only climb LOP in cooler temps, light loads and over forgiving terrain. During the summer at gross, I want my "free A/C" asap, climb better than a 172(500-700 fpm) and remain in glide range of the airport on climb out.
_________________ Wayne G. |
Posted: Mon Apr 22, 2013 7:26 pm Post subject: LOP Article - FLYING magazine |
I generally do WOT climbs to cruise, only leaning to keep "the same" EGT
temps to altitude. "The same" being the EGTs I get at say 1,000' AGL
with the mixture full rich (or at least at the mixture I decided to use
at a high elevation field).
As I understand it, this is not a LOP climb but rather a climb that
conservatively maintains the cooling effects of a full rich climb
without overdoing it. I then go to LOP cruise.
Bill "I couldn't afford to do this without some LOP ops" Watson
On 4/22/2013 11:08 PM, rv10flyer wrote:
Wayne G.
SB 12/01/2009-12/01/2011
TT= 103
http://forums.matronics.com/viewtopic.php?p=399185#399185
Checked by AVG - www.avg.com
