ceengland7(at)gmail.com Guest
Posted: Sat Apr 20, 2013 6:18 am Post subject: microair transponder/encoder hookup question |
Has anyone successfully installed a Microair T2000SFL-01rev8 transponder combined with their EC2002-01rev3 encoder, using serial connection?
The manual for the xp rev8 at
shows *2* data lines between the components: encoder pin6data receive to xp pin 5data transmit, and encoder pin 7data transmit to xp pin 4data receive. *But*... note 7 on the hookup page (pg 13) says that the diagram is applicable to revs 5,6, & 7.
I can't find an install manual for the 01rev3 encoder on their web site, but the manual for the 01rev12 shows pin 6 of the encoder (labeled rs232in) as unconnected.
However....
Looking at the page on their pre-wired harnesses at
http://www.microair.com.au/index.aspx?page=186&productID=36
The diagram for wiring their xp to their encoder shows encoder pin 6 (data receive) to be *grounded*.
So, various docs on the Microair website show the encoder pin 6 to be: open, tied to transponder pin 5, and grounded (through the harness) to the case of the transponder.
Anyone have any words of wisdom on the *right* way to do it?
[url=http://www.microair.com.au/index.aspx?page=186&productID=26][/url]
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Avionics-List |
