markacarey(at)msn.com Guest
Posted: Fri Jun 09, 2006 11:47 am Post subject: Door Handles |
I am having difficulting getting my spring assisted door handles to move
freely enough for the roller pins to slide into the slot on the doors. Does
anyone have any suggestions or recommendations. I recall some earlier posts
depicting alternate handles. When I flew the factory 10 the door latches
clicked in real nice.
bhughes(at)qnsi.net Guest
Posted: Fri Jun 09, 2006 12:11 pm Post subject: Door Handles |
I had the same problem. I used a small file and emery cloth to open up
the slots and smooth down all of the rough edges. Bad news is I had to
disassemble the mechanism to correct the problem.
Bobby
40116
(sanding and sanding and sanding)
Tim(at)MyRV10.com Guest
Posted: Fri Jun 09, 2006 12:48 pm Post subject: Door Handles |
I think you just need to make sure that any burrs are gone, and you
have the slots filed in nicely. It took a little playing to clean
it up well, but then it worked great.
Mark Carey wrote:
Does anyone have any suggestions or recommendations. I recall some
earlier posts depicting alternate handles. When I flew the factory 10
the door latches clicked in real nice.
