RV8a baffles
Site Admin
PostPosted: Thu Mar 14, 2013 7:57 am    Post subject: RV8a baffles Reply with quote
At 06:23 PM 3/13/2013 Wednesday, you wrote:
nearing completion of FWFD, having trouble visualizing the baffle seal plan around the front of the top cowling. I have the Van's cowling and IO-360 angle valve engine. If anyone has good pics showing how to fit the seals to stop the air flow in the upper front center area, I would appreciate seeing them.
Hi Dennis,
I've got an IO-390 with a front-mounted prop governor, but the seal layout is about the same. Attached are some pictures of how I did mine. I had no problems with CHT or EGTs.
RV-8 #82880 N998RV "Ruby Vixen"
http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log
http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log
Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
RV-6 #20916 N360EM "The Flyer"
http://www.mattsrv6.com - Matt's RV-6 Revitalization Log
Status: 140+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
 Filesize:  189.31 KB
 Viewed:  1503 Time(s)
 Filesize:  150.33 KB
 Filesize:  154.38 KB
 Filesize:  156.34 KB
 Filesize:  140.26 KB
 Filesize:  150.77 KB
 Filesize:  155.95 KB
 Filesize:  147.19 KB
 Filesize:  143.99 KB
 Filesize:  154.61 KB
 Filesize:  162.55 KB
 Filesize:  283.05 KB
 Filesize:  289.82 KB
 Filesize:  179.75 KB
 Filesize:  186.29 KB
 Filesize:  187.22 KB
 Filesize:  184.86 KB
 Filesize:  165.14 KB
 Filesize:  173.47 KB
 Filesize:  205.46 KB
 Filesize:  164.23 KB
 Filesize:  180.6 KB
 Filesize:  152.37 KB
 Filesize:  150.82 KB
Site Admin
Hi Dennis,
 Filesize:  189.31 KB
 Filesize:  150.33 KB
 Filesize:  154.38 KB
 Filesize:  156.34 KB
 Filesize:  140.26 KB
 Filesize:  150.77 KB
 Filesize:  155.95 KB
 Filesize:  147.19 KB
 Filesize:  143.99 KB
 Filesize:  154.61 KB
 Filesize:  162.55 KB
 Filesize:  283.05 KB
 Filesize:  289.82 KB
 Filesize:  179.75 KB
 Filesize:  186.29 KB
 Filesize:  187.22 KB
 Filesize:  184.86 KB
 Filesize:  165.14 KB
 Filesize:  173.47 KB
 Filesize:  205.46 KB
 Filesize:  164.23 KB
 Filesize:  180.6 KB
 Filesize:  152.37 KB
 Filesize:  150.82 KB
panamared505(at)brier.net
PostPosted: Thu Mar 14, 2013 10:10 am    Post subject: RV8a baffles Reply with quote
Matt
I am impressed. Great work.
Bob
