Thom Riddle
Posted: Fri Jun 09, 2006 4:33 am Post subject: #1 cylinder plugs are black |
During our annual inspection we removed all spark plugs, cleaned and
gapped them before re-installing them. They had about 100 hours on them
with virtually no wear and all the plugs except for both plugs in #1
cylinder were perfectly colored. Both plugs in #1 cylinder were black.
We also balanced the carbs and have sense flown the airplane about 5
hours.
A couple days ago we removed plugs from #1 and #3 cylinder to see if
the black sooty condition had improved. #1 plugs (both) again are black
and sooty while #3 plugs are fine.
Engine seems to run fine and smooth at all power settings. Apparently,
#1 cylinder is running rich but both it and #3, which is burning clean,
are fed from the same caburetor.
Any ideas as to what's going on?
Thom in Buffalo
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Fri Jun 09, 2006 9:05 am Post subject: #1 cylinder plugs are black |
Hello Thom
"#1 plugs (both) again are black and sooty while #3 plugs are fine. Any
ideas as to what's going on?"
Not in order just rattling:
****First off change the plugs. Unless you have access to a pressure
tester to make sure they are not snuffing out under pressure
****Make sure you have the proper heat range plugs! If the porcelain is
shorter, it will run cooler and could run black.
****You sure it is black from running rich, or could it be black from oil
fouling?? Perhaps run a compression test, that will not tell you if oil
ring leaks or valve stem seal, but if low hint to look further.
****Are you using Whacker Silicone based thermal conductive compound on
plug threads?
****You have a CHT and EGT to help diagnose problems?
****If you look up mixture check procedures for 914 at take off power,
they have you measure each cylinder for O2 content. They want a minimum
amount to be certain that things are not running too lean. Eastwood sells
such a tool, could be used to check for proper mixture at various throttle
settings as well.
****Make sure float bowl shows no signs of overflowing, check needle valve
and float look OK, clean carb while you are at it
****I am not certain on this one, but a restriction on exhaust is not a
good thing, make sure clear on that cylinder
****If it is only happening on 1 of the plugs in that cylinder, could be
besides a bad plug, faulty ignition pick up, coil, module or wires
****You getting cooling problems on that cylinder, like too hot or too
cool?
****MAKE SURE YOU HAVE PROPER HEAT RANGE OF PLUGS especial on black
cylinder
****If you could somehow get hold of a EGT put it in suspect cylinder. If
you turn off gas, you should not get a very severe rise, if you do then
too rich.
Try it with a good cylinder to see what normal is. Remember black could
be caused at many a throttle position. Choke motor when hot a very low
throttle opening which you know is rich, and see what rise is. Just be
very careful on purpose running lean like this above 50% power, do it just
to get peak then retard throttle and turn on fuel.
Had enough yet?
If not, what motor you have? How does it start? How does it start in cold?
How many hours? MoGas or 100LL? What is compression on 4 cylinders? Did
you install new length dipstick? What type of oil you running? You
checking oil properly where you do not have things overfilled? Is there
blue smoke coming out of exhaust, if 2 pipes, then the one with #1 upon
cold start up? How bout black smoke on cold start up? Is your oil pressure
excessive high, has it changed since you did not have black plugs?
Let us know how you make out
Ron Parigoris
Ron Parigoris
Thom Riddle
Posted: Sat Jun 10, 2006 3:53 am Post subject: #1 cylinder plugs are black |
Ron,
Thanks for your response. My question should have been stated
differently. My question should have stated that I'm looking for any
peculiar characteristics of the 912 that might cause this problem
because I am relatively new to the Rotax 912 engine but not to engine
mechanics. I am an FAA Powerplant Mechanic and one of my airplane
partners is an A&P I/A but both of us are relatively new to Rotax 912
series engine. In any case, I appreciate your response and following
are my answers which might help others diagnose similar situations if
they arise in their engines.
pressure
I will swap the nearly new plugs from this cylinder to another to see
if the same happens to the plugs from another cylinder or the same
plugs in the other cylinder.
porcelain is
I have the proper plugs in all the cylinders.
from oil
if oil
We did a compression test during annual inspection two weeks ago. Three
of the cylinders were 80 psi, including this one, and #4 was 78 psi.
We also removed the valve cover to see if there were a broken spring
and checked for too much valve lash. Negative on both counts.
compound on
plug threads?
We are using standard anti-seize compound on plug threads but not on
the threads that extend into combustion chamber, which of course would
be a no-no.
We have four EGTs. #2,3,4 were running between 1410F and 1480F during
cruise(normal). #1 was running around 1550F and the thermocouple probe
began falling apart and finally failed on last flight. We loosened the
intake manifold on this side to see if there were air obstructions but
there were not. However, there is a black streak along the bottom of
this intake manifold tube that runs right into the cylinder head port.
There is no such streak in the #3 cylinder intake manifold or on either
cylinder on the other side. I scratched and sniffed this black streak
and it smells like unburned fuel. I'm now convinced that there is raw
fuel being passed into this cylinder with the high velocity air during
cruise power, past the Y-junction in the intake manifold and thus not
showing up in the #3 cylinder intake manifold. This raw fuel is also
responsible for the high EGT reading on this cylinder as it burns in
the exhaust tube and the ultimate failure of the EGT probe. We will be
removing, disassembling, inspecting and cleaning this carb. I suspect
this will cure the problem but won't know for sure until we do it.
power,
minimum
Eastwood sells
throttle
settings as well.
The EGT temps during all power settings tell us what we need to know
here but if all else fails, we may try this.
needle valve
This will be checked during carb inspection and cleaning.
not a
Checked and it is clear.
could be
As I said in the original post, it is happening to both plugs. Not
related to ignition system.
or too
cool?
No cooling problems.
black
cylinder
You already said this. But thanks for the reminder.
cylinder. If
do then
too rich.
See above.
black could
very low
Just be
do it just
Had enough yet?
912UL
Starts fine hot or cold.
How many hours?
385 hours and averaging about 150 hours per year.
MoGas or 100LL?
90% mogas 10% 100LL on cross-country trips
See Above
Did you install new length dipstick?
Came with engine.
CPS AV-9
You checking oil properly where you do not have things overfilled?
Yes
Is there blue smoke coming out of exhaust, if 2 pipes, then the one
with #1 upon
No smoke of any color.
Is your oil pressure excessive high,
No
No
Will do.
Thom in Buffalo
Buffalo, NY (9G0)
- Anonymous |
Posted: Sat Jun 10, 2006 8:51 am Post subject: #1 cylinder plugs are black |
Hello Thom
After reading your reply:
Chech exhaust for cracks/leaking
A retarded spark can cause high EGTs, did you check Rotax info and in fact
your ignition, the pick ups, and gaps are up to date?
I posted a site a while back that states it is easy to cross wires in
ignition wiring, did you check?
Give a try to go and fly on 1 mag, then the other at a high power setting,
do it for 5 minutes and see if there is a noticiable difference.
I don't like high EGTs, I know black is rich, but go looking for a intake
leak, a stumbling cylinder can cause unburned fuel to get into exhaust??
Look at cross tube, and other sources of air leak in.
When was last carb cleaning?? Did you look for ripped diaphram during
inspection? Look very close at the needle valve.
OK another, where do you have the float bowl vent terminating? If it is in
an area of lower pressure than ambient you will run lean, if in higher
pressure will run rich. Run to just downwind of air cleaner is often done,
look for kinks, restriction and leaks and route to ambient air.
Check you have latest recomondation for main jet, jet needle and position
of clip, O ring on jet needle, latest needle jet. Look for carb snot very
careful, check O-rings.
If you have a friend into BMW Boxers with carbs, have em give you a hand
with carb (they use type 64), or a Rotax guru.
After talking to the research guru at Rotax, Whacker is what should only
be used on plug threads. He did plenty of testing, and Whacker was hands
down winner. You want thermal conductivity.
When checking for exhaust cracks, be very careful looking for
obstruction/debris or whatever in the muffler. I hear a broken exhaust
pipe on the 914 shortly thereafter begins to play silent night.
Let us know what you find.
Ron Parigoris
