n744bh(at)bellsouth.net Guest
Posted: Mon Feb 25, 2013 1:33 pm Post subject: Ground plane diameter |
I'm upgrading avionics in my Glasair and one of the units I'm adding is a Garmin GDL-88 for ADS-B out. The antenna I'm using is a Comant CI-105 and seeing it's a "plastic" airplane I've been wondering if a 6" diameter copper disc is large enough for the ground plane or should I go a bit larger? TIA
Bill
Glasair SIIS-FT
Checked by AVG - www.avg.com
p> [quote][b]
Posted: Mon Feb 25, 2013 6:00 pm Post subject: Ground plane diameter |
At 03:30 PM 2/25/2013, you wrote:
| Quote: | | I'm upgrading avionics in my Glasair and one of the units I'm adding is a Garmin GDL-88 for ADS-B out. The antenna I'm using is a Comant CI-105 and seeing it's a "plastic" airplane I've been wondering if a 6" diameter copper disc is large enough for the ground plane or should I go a bit larger? TIA |
To understand the workings of ground planes under
vertical 1/4-wave radiators (like comm, transponder
and DME) antennas, you need to take a little 'head
trip'.
The older brother to a 1/4-wave antenna fed at the
base is a 1/2-wave antenna fed at the center (aka
VOR/LOC/GS atennas). The 1/2 wave antenna doesn't
need a 'ground' because is has useful places to send
1/2 of the total energy into each of two identical,
complimentary radiators.
Now, take a dipole and turn it up vertically as if
you wanted to use it for comm. Hmmmm . . . hard to
attach the coax to it while insulating the hot
end of the lower element. Okay, bend the lower element
90 degrees. Now the feed point at the antenna
center comes down to skin level on the airplane . . .
but the 'bent' half of the antenna is seriously
compromised for efficiency as it no longer works
in concert with its unmodified counterpart.
Hmmmm . . . how to make the lion's share of the energy
flow into the freely extended portion of the antenna
while reducing a wasteful venture onto the
compromised portion of the antenna? How about adding
a second compromised element? Assume the feed point
impedance of each element is R. Then a dipole in
extended splendor has a feed point impedance of 2R.
You've still got R + R with the compromised dipole
but paralleling two 'crippled' elements at the base
gives you 1/2R + R. We see that energy fed to
this network divides with 1/3 going to the compromised
side and 2/3 to the free element. Let's consider adding
2 more 'compromised' elements. Now we have 1/4R + R.
Great! 4/5ths of the energy goes to the working part
while only 1/5th is left free to roam and be a general
nuisance to your radiation pattern.
Now, if you want to squirt your signal off at an
angle that is closer to the horizon, you can droop
those elements not unlike the antennas seen around
many airports.
Take this exercise to an extreme . . . say 100
'compromised' elements. Now you get 1/100R + R
and only 1% of the energy is left free to be
problematic. Further, 100 compromised elements
look very close to a solid disk of material having
a RADIUS equal to the HEIGHT of the free element.
You sometimes see 100 drooping elements that look
very much like a cone of solid metal.
So, getting back to your question, the IDEAL small
ground plane has a radius equal to the 1/4-wave
distance for the frequency of interest. In the case
of transponders, this works out to 300M meters/sec
divided by 1050 cycles/second times 39.36 inches/meter
times 0.25 wavelength and you get 2.8 inches. Twice
this value is 5.6", the ideal resonant ground plane
for transponder antennas.
Making it just a little bigger because you can is
counter productive. On the other hand, making it
MUCH bigger (like the belly of a metal airplane)
and it begins to approximate a non-resonant, infinite
ground plane which is very good too . . . but a
a whole different ballgame.
The short answer is that for a non-conducting
mounting surface the antenna performs best with
the idealized, 1/4-wave radius disk. If you
could mount it to several square feet of aluminum
it would only slightly better . . . so slight
that you would need to measure the difference
in a well heeled RF lab. So the best recommendation
is go for the 5.6" disk.
Bob . . . [quote][b]
Posted: Mon Feb 25, 2013 8:29 pm Post subject: Ground plane diameter |
OK, thanks Bob. It operates on 978 Mhz so I probably could have figured it out by breaking out my ARRL Antenna Book but I guess I was just a bit on the lazy side.
Bill
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Sent: Mon, February 25, 2013 8:06:58 PM
Subject: Re: Ground plane diameter
trip'.
many airports.
Bob . . . [quote][b]http://www.matronics.com/Navigatrums.matronics.com/" rel=nofollow target=_blank>http://forums.matronics-> [b]
Posted: Tue Feb 26, 2013 6:31 am Post subject: Ground plane diameter |
At 10:27 PM 2/25/2013, you wrote:
| Quote: | OK, thanks Bob. It operates on 978 Mhz so I probably could have
Very good. Yes, 978 MHz does work out to
a 6" diameter ground plane . . .
mrspudandcompany(at)veriz Guest
Posted: Tue Feb 26, 2013 9:06 am Post subject: Ground plane diameter |
I have seen often that antennas get cut off to tune
for maximum radiation. Is the ground plane as
critical in dimension as the radiating element?
Roger
Do you have a slow PC? Try a Free scan http://www.spamfighter.com/SLOW-PCfighter?cid=sigen
Posted: Tue Feb 26, 2013 9:35 am Post subject: Ground plane diameter |
Roger
I guess it depends on your threshold for assigning
criticality. I've spent hours in the labs watching
displays on instruments that dutifully reported
measurable differences. It's really EASY . . . especially
for designers and technicians to work in relative
isolation from practical results to take lots
of pride and assign criticality to small
improvements.
Improvements in the lab go to statistical process
control. LOTS of tiny improvements in the bits
and pieces can add up to significance improvements
in the full up system. At the same time, the guy
who is fine-tuning his little bit has no control
over how it will be installed nor will he control
less than optimum outcomes for associated bits.
In the world of antennas, the observable effects
for fabrication are greatest in management
of radiation pattern. I've seen some plots on
airframe mounted antennas with deep nulls in
azimuth plots. Careful tuning for resonance
is the least part of the recipe for success.
I.e., optimized SWR and field strength numbers
can be misleading.
http://tinyurl.com/bea4785
Bottom line is that taking time to 'trim' a
ground plan is probably the least productive
effort. Fortunately, the very short UHF monopole
antennas are pretty easy to locate to minimize
airframe distortions of pattern. We are further
aided by the fact that terrible losses can be
tolerated in the world of relatively short
range, line of sight world for aircraft
communications.
The only airplanes we ever studied for antenna
radiation patterns were the big guys who flew
routinely over water at 41,000 feet with very
distant radio-horizons. The only pattern work
I ever witnessed on a small airplane was done
by Dr. Gordon Wood on a C-172 at Cessna about 1963.
I don't think the outcome of those studies
prompted any changes to our legacy installations.
Don't worry about the ground plane . . .
rv7a.n18pf(at)gmail.com Guest
Posted: Tue Feb 26, 2013 2:31 pm Post subject: Ground plane diameter |
It might seem lazy on your part just to get a number - but some of us got an education on WHY that was the number. So thanks for asking!
(and of course Thank You Bob for the explanation!)
- Paul On Feb 25, 2013 10:44 PM, "William Hibbing" <n744bh(at)bellsouth.net (n744bh(at)bellsouth.net)> wrote:[quote] OK, thanks Bob. It operates on 978 Mhz so I probably could have figured it out by breaking out my ARRL Antenna Book but I guess I was just a bit on the lazy side.
Bill
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
trip'.
many airports.
tp://forums.matronics.com
Posted: Tue Feb 26, 2013 4:26 pm Post subject: Ground plane diameter |
At 04:30 PM 2/26/2013, you wrote:
| Quote: | It might seem lazy on your part just to get a number
- Paul
My pleasure sir. I know some folks may feel
a bit over-informed but I'll ask that they
keep in mind that this list has about 1600
subscribers (at last count 6 months ago).
Interest in answers has to span a wide
range and I try to address it.
Not trying to preach or 'stuff' anyone
with data they don't wish to possess . . .
bob.verwey(at)gmail.com Guest
Posted: Thu Feb 28, 2013 1:31 am Post subject: Ground plane diameter |
If we consider the simple whip antenna for our VHF comms, what is the best trimmed length for the antenna part and the ground plane diameter to optimise the frequencies in the early '120's?
Best..
Bob Verwey
On 26 February 2013 19:02, R. curtis <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)> wrote:
[quote]--> AeroElectric-List message posted by: "R. curtis" <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)>
| Quote: | OK, thanks Bob. It operates on 978 Mhz so I probably could have figured it out by breaking out my ARRL Antenna Book but I guess I was just a bit on the lazy side.
I have seen often that antennas get cut off to tune for maximum radiation. Is the ground plane as
Roger
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
Posted: Thu Feb 28, 2013 6:58 am Post subject: Ground plane diameter |
At 03:29 AM 2/28/2013, you wrote:
| Quote: | If we consider the simple whip antenna for our VHF comms, what is
Center of the VHF comm spectrum is (118+135)/2 or 127.5 MHz
Free space full wavelength in meters is 300/127.5 = 2.35M
2.35M x 39.34 in/meter yields 92"
1/4 wave radials (or antennas) at 127.5 are
92/4 or 23".
Posted: Thu Feb 28, 2013 8:13 am Post subject: Ground plane diameter |
Thanks Bob,
Care to elaborate on the ground plane a little? If the structure of the aircraft is 'Cub-like' steel tubing, and one mounts the antenna on the roof, is it sufficient to use the airframe as the groundplane?
Bob Verwey
On 28 February 2013 16:53, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | If we consider the simple whip antenna for our VHF comms, what is the best trimmed length for the antenna part and the ground plane diameter to optimise the frequencies in the early '120's?
92/4 or 23".
le, List Admin.
Posted: Thu Feb 28, 2013 9:06 am Post subject: Ground plane diameter |
At 10:10 AM 2/28/2013, you wrote:
| Quote: | Thanks Bob,
ANY conductive material can be brought into service
as a 'ground'. Given our unique line-of-sight, short-range
expectations for radio communications, a wet-string would
probably serve 96% of your communications expectations.
Consider the lowly hand-held. Talk about compromised
ground planes!! The rubber duck in a sweaty fist works
for some situations, other situations (mostly driven by
customer's willingness to pay) are optimized to the
best-we-know-how-to-do. Most of us will secure happiness with
some intermediate but decidedly less expensive configuration.
ANY combination you choose to try should be first tailored
for lowest possible SWR over the range of interest. The
transmitter has no idea what's at the other end of the
feedline. Gross efficiency and/or radiation patterns are
separate issues not easily measured and massaged.
Are there things we could do that are 'better' than
using a rag-covered-tube ground plane? Sure. Would the
guy at the other end of the link know the difference?
Probably not. This is but one of several advantages
we enjoy over the drivers of TC iron, we can try it.
If found insufficient to design goals, do something
different.
FisherPaulA(at)johndeere. Guest
Posted: Thu Feb 28, 2013 9:37 am Post subject: Ground plane diameter |
I’d like to try to answer this:
300 million meters per second is roughly the speed of light – also about the speed the radio waves propagate. Dividing this by the frequency in megahertz gives you the wave length. So 300,000,000/127,500,000 = 2.35 meters.
seems like this was on the test for my ham license… surprising I still remember it!
Paul Fisher
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Christopher Cee Stone
Sent: Thursday, February 28, 2013 11:07 AM
Subject: Re: AeroElectric-List: Ground plane diameter
Bob...
I follow your calcs and the underlying physics until I see the 300/127.5 = 2.35M. Where is the 300 from? What does it represent?
Always learning!
Chris Stone
cyav8r(at)yahoo.com Guest
Posted: Thu Feb 28, 2013 9:55 am Post subject: Ground plane diameter |
Then would be the recommendation for a more modern design that is all carbon fiber? The carbon is conductive, but absorbs radiation instead of reflecting it from what I understand. Go with a foil circle or strips of the appropriate diameter on the outside of the carbon, but under the paint?
Paul
Sent: Thursday, February 28, 2013 11:05 AM
rv8iator(at)gmail.com Guest
Posted: Thu Feb 28, 2013 10:01 am Post subject: Ground plane diameter |
Ahhh... Â Yes.
Still mired in English units 186,000 miles per second.
Thanks!
chris stone
On Thu, Feb 28, 2013 at 9:34 AM, Fisher Paul A. <FisherPaulA(at)johndeere.com (FisherPaulA(at)johndeere.com)> wrote:
Â
Â
Â
Â
Paul Fisher
Â
Â
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Christopher Cee Stone
Â
Bob...
Â
I follow your calcs and the underlying physics until I see the 300/127.5 = 2.35M. Â Where is the 300 from? What does it represent?
Â
Always learning!
Â
Chris Stone
Â
Posted: Thu Feb 28, 2013 10:36 am Post subject: Ground plane diameter |
At 11:48 AM 2/28/2013, you wrote:
| Quote: | Then would be the recommendation for a more modern design that is
That's a whole other can of worms. The carbon fiber
is, as you've described, pretty lossy stuff. Yeah, it
is conductive but much of electrical energy flowing
through a carbon matrix is converted to heat.
Trying to create idealized ground planes over the
carbon and under the paint is exceedingly expensive
and problematic for affecting structural integrity
of the shell.
At HBC, non-resonant ground planes were bonded to the
inside surface of the fuselage shell. Relatively
inexpensive and the flight test results deemed them
adequate to the task.
Posted: Thu Feb 28, 2013 10:57 am Post subject: Ground plane diameter |
At 11:34 AM 2/28/2013, you wrote:
| Quote: | I’d like to try to answer this:
license… surprising I still remember it!>
Yeah, pretty cool stuff. First learned to do those
calculations on a slide rule about 60 years
ago . . .
Posted: Thu Feb 28, 2013 11:07 am Post subject: Ground plane diameter |
I'd forgotten about a compendium of antenna articles
that were waiting to be posted to the website. I just
put them up where they can be downloaded and inquiring
minds can exploit as appropriate:
http://tinyurl.com/d2ql8lw
