ccoulter(at)wavecable.com Guest
Posted: Tue Feb 19, 2013 1:35 pm Post subject: Aileron Trim Tabs-Anyone Using? Photos to Share? |
I have a small trim tab on my alerons I made out of
aluminum and rivited to the aleron.
On Tue, 19 Feb 2013 06:44:38 -0800
"triumphrider" <investmentsalesconsultant(at)gmail.com>
wrote:
We had a discussion on the left roll tendency that my
Pulsar XP has. It doesn't track straight-I have to have a
slight amount of right pressure on the center stick to
keep it tracking straight. Let go and it begins a slight
left turn. Kind of a pain when you need to review a
sectional, etc.
I usually fly solo, so perhaps the weight on the left
seat only is also a factor?
Are you using a aileron trim tab(s)? Does anyone have a
picture of a small trim tab they are using for on their
aircraft and perhaps, a source for them?
I have a small trim tab on the rudder-it's about an inch
wide and at a 30-degree angle or so from the rudder
tab-Is this the same size I should be looking for?
http://forums.matronics.com/viewtopic.php?p=394568#394568
Un/Subscription,
Forums!
Admin.
Posted: Tue Feb 19, 2013 1:36 pm Post subject: Aileron Trim Tabs-Anyone Using? Photos to Share? |
Every time I eat M&M's I think of the ones you had at the
Pulsar flyin.
Clarke
On Tue, 19 Feb 2013 11:11:58 -0500 (EST)
dougwitkowski(at)netscape.net wrote:
[quote] I used a simple wedge shaped balsa piece (1/4" x 1")
double-side taped to the underside of one aeleron. Cut
length based on correction needed. Been there 16 years.
