Posted: Fri Feb 01, 2013 10:01 am Post subject: Dynon Skyview software version 5.0? |
Does anybody on the list have SkyView software version 5.0 (not 5.1) that they can email me?
Thanks.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
jc-matronics_rv(at)jline. Guest
Posted: Fri Feb 01, 2013 10:17 am Post subject: Dynon Skyview software version 5.0? |
http://www.dynonavionics.com/downloads/Software/SkyView-5.0.0-dynon_update.dup
If you only want the firmward download, the original download link still
works. This does not include any of the map data updates at all, but I
don't think there were any map changes anyway with 5.1.
Jae
On 2/1/2013 10:00 AM, Jesse Saint wrote:
Thanks.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Kellym
Posted: Fri Feb 01, 2013 11:57 am Post subject: Dynon Skyview software version 5.0? |
Is there an issue with 5.1? I have 5.0, but haven't loaded it yet.
still works. This does not include any of the map data updates at all,
but I don't think there were any map changes anyway with 5.1.
Jae
> Thanks.
> Jesse Saint
> C: 352-427-0285
> F: 815-377-3694
Checked by AVG - www.avg.com
KCHD |
rv10flyer(at)live.com Guest
Posted: Fri Feb 01, 2013 1:11 pm Post subject: Dynon Skyview software version 5.0? |
I have a VP-200, the new EMS stream that allows Data logging for the Dynon
apparently is incompatible with the Vertical Power.
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 26321 Location: Livermore CA USA
Posted: Fri Feb 01, 2013 3:17 pm Post subject: Dynon Skyview software version 5.0? |
Did your VP-200 just stop receiving EMS data from the Skyview after the upgrade to 5.1? I was going to install 5.1 tomorrow, but it sounds like I might want to hold off?
Matt
At 01:11 PM 2/1/2013 Friday, you wrote:
Quote: |
I have a VP-200, the new EMS stream that allows Data logging for the Dynon apparently is incompatible with the Vertical Power.
_________________ Matt Dralle
Posted: Fri Feb 01, 2013 4:40 pm Post subject: Dynon Skyview software version 5.0? |
My apologies, In my rush to respond, I used the wrong word. I should have
said "May be" versus "apparently is". As far as I know, no one has tested
it
to confirm one way or the other. My theory is Dynon mentioned there was an
upgrade to the EMS information so I threw that out as a "potential issue".
If I was able I would install the upgrade this weekend and confirm. Worst
case I would just reinstall the 5.0.0 firmware.
Pascal
said "May be" versus "apparently is". As far as I knw, no one has tested it
Pascal
Posted: Fri Feb 01, 2013 4:47 pm Post subject: Dynon Skyview software version 5.0? |
At 04:40 PM 2/1/2013 Friday, you wrote:
said "May be" versus "apparently is". As far as I know, no one has tested it
Pascal
Below is my dialog with Dynon over the issue. I also emailed Vertical Power about it. Seems like a roll back to 5.0 if 5.1 didn't prove viable would be worth the trouble at this point.
[quote]Matt:
Another customer told us today that Vertical Power recommended not updating to v5.1 because of changes Dynon made to the streaming data format.
We advise talking to Vertical Power first.
Steve
Dynon Avionics Technical Support
support(at)dynonavionics.com
Phone: 425-402-0433 - 07:00-17:00 Pacific weekdays
Posted: Fri Feb 01, 2013 5:58 pm Post subject: Re: Dynon Skyview software version 5.0? |
I got the email below from Vertical Power today regarding the VP-200 compatibility with the new 5.1 Skyview EMS data.
You know, I want to say that this is now the SECOND time Dynon has changed the format of the EMS data and caused issues with the VP-200. Dynon needs to rev their data streams and not obsolete the previous versions. Each new major change to the data stream format should be a new version that is selectable from the serial menu. e.g. EMS 1.0, EMS 2.0, EMS 3.0. Expecting every vendor in the world to update their equipment to retain compatibility is simply not acceptable, IMHO.
Backward protocol compatibility must be a prime concern when adding features.
RV-8/RV-6/RV-4
Kellym
Posted: Fri Feb 01, 2013 6:09 pm Post subject: Dynon Skyview software version 5.0? |
Especially since only Dynon charges its customers for software support
of Vertical Power, unlike the other EFIS vendors.
RV-8/RV-6/RV-4
KCHD |
Posted: Sat Feb 02, 2013 12:07 pm Post subject: Re: Dynon Skyview software version 5.0? |
Fear not. Dynon Skyview 5.1 AHRS/EMS data output *IS* fully compatible with the latest version of the VP-200. Confirmed this morning.
Note that the SKyview WILL NOT let you DOWNGRADE the software from 5.1 to 5.0! That's seems lame.
RV-8/RV-6/RV-4
Posted: Sat Feb 02, 2013 12:35 pm Post subject: Dynon Skyview software version 5.0? |
Thank you Matt!
Appreciate the effort to put this to rest!
Pascal
Posted: Sat Feb 02, 2013 8:56 pm Post subject: Re: Dynon Skyview software version 5.0? |
Well, I spoke too soon. Turns out, that the VP-200 sync's up on the data stream, but mis-interprets most if not all of the data objects. When I first got things up on the new version, the big red X's on the VP-200 EMS data went away and I was elated. It wasn't until later in the day when I started the engine that I noticed that the RPM wasn't working. Then I looked closer and noticed that the EGT/CHT wasn't right, and some of the others.
So, that's an Epic Fail. I am really flabbergasted that Dynon would break their AHRS/EMS protocol like that. The whole point of a "protocol" is that it represents some semblance of stability. I'd get fired for making a protocol change to our product at work that wasn't backwardly compatible.
Anyway, so I did try to roll back to 5.0.0.xxxx but the Skyview wouldn't let me. Is there some way to force it to go back to an older version on the Skyview?
Matt
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Sat Feb 02, 2013 9:04 pm Post subject: Dynon Skyview software version 5.0? |
Seems there would be a way to force the old data. I know the G3X is to hold
down the toggle button while turning on the unit with the old software in
the data card slot. I think there should be if they screw up on a software
upgrade.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Posted: Sun Feb 03, 2013 12:25 pm Post subject: Dynon Skyview software version 5.0? |
Matt;
Here is the response from Dynon support. Give them a call.
We updated the serial stream because we had some important customers that
asked for specific elements to be added to the stream. We knew this was a
possibility since day one, and even put a version number in the serial
stream so an application can tell that the stream has been changed. We would
always prefer to not change the format, but at some point you need to
balance the needs of a variety of customers, and we had a clear business
case to support customers asking for new features in the serial stream.
One of the issues here is that the VP-200 is not a product we "support."
While we have official support for the VP-X,
Vertical Power used our serial stream for the VP-200 on their own accord
without any input from us. This is fine and in fact the whole reason that we
created a documented serial stream, but this means we didn't even really
know they were using it so it's hard for us to realize that we were going to
break anything. Compatibility is something that we test every release for
products we support, but isn't something that we can promise for arbitrary
3rd party devices that few of our customers use.
We only moved a few parameters around in the new serial stream, so it's
unfortunate that it will take them months to fix this as it's likely just a
few constants in their code to make it work again.
It is possible to revert to 5.0 without much hassle. Contact support via
email or phone and we can send you instructions.
Pascal
Posted: Tue Feb 05, 2013 9:16 am Post subject: Dynon Skyview software version 5.0? |
I don't know if this has already been addressed, but this is an issue with the VP-200, not the VP-X. It is frustrating, especially since Dynon doesn't have a way to roll back to earlier software. If anybody gets brave enough to try 5.1 with a VP-200, let us know if it works.
Thanks.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
On Feb 1, 2013, at 9:08 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
Quote: |
Especially since only Dynon charges its customers for software support of Vertical Power, unlike the other EFIS vendors.
> Matt Dralle
> RV-8/RV-6/RV-4
Posted: Tue Feb 05, 2013 9:43 am Post subject: Dynon Skyview software version 5.0? |
Disregard that last email. I just finished reading the threads.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
On Feb 5, 2013, at 12:15 PM, Jesse Saint <jesse(at)saintaviation.com> wrote:
Thanks.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
>> Matt Dralle
>> RV-8/RV-6/RV-4
> No virus found in this message.
