nail13zg(at)centurytel.ne Guest
Posted: Fri Jan 25, 2013 7:56 am Post subject: water temp on Stratus eng |
Does anyone use an actual water temperature taken from a sensor on a water hose? Or are you just using the sensor from the block as water temp?
I have not flown my plane yet, but ground runs show a higher, and climbing, in-hose temp than the block temp.
Trey Moran
Kitfox M5
