Posted: Sat Jan 12, 2013 12:54 pm Post subject: Ground connector (was Anderson PowerPole connectors) |
Robert L. Nuckolls, III a écrit :
Yeah, I've been seeing them for years but never
really sat down and studied the products and their
technology. Pretty slick.
Bob and all,
Your messages about PowerPole connectors prompted a question :
What type of ground connector would you recommend to easily connect our
Optimate charger to the ship's batteries through the aircraft skin
(without opening the baggage door) ?
Among goals we are aiming at :
- Lightweight
- Small footprint
- Resistance/protection from water, mud, etc.
- As aerodynamically clean as possible
Any ideas ?
Thanks for any input,
Best regards,
Gilles
http://contrails.free.fr
james(at)etravel.org Guest
Posted: Sun Jan 13, 2013 4:07 am Post subject: Ground connector (was Anderson PowerPole connectors) |
Gilles,
I went for the Piper style connector for my Jodel D150 project. Unfortunately, it's not very light, nor, I suppose, aerodynamically clean, but it does have a sprung cover to keep mud, etc. out. As for small, that's subjective. It needs a 2" hole, with two 21/64" holes at 2-15/16" centres.
See http://www.aircraftspruce.com/pdf/2013Individual/Cat13519.pdf for details.
Despite its downsides, I'm hoping that its ubiquity will be its saving grace.
James
On 12 January 2013 20:53, Gilles Thesee <Gilles.Thesee(at)ac-grenoble.fr (Gilles.Thesee(at)ac-grenoble.fr)> wrote:
[quote]--> AeroElectric-List message posted by: Gilles Thesee <Gilles.Thesee(at)ac-grenoble.fr (Gilles.Thesee(at)ac-grenoble.fr)>
Bob and all,
What type of ground connector would you recommend to easily connect our Optimate charger to the ship's batteries through the aircraft skin (without opening the baggage door) ?
- Lightweight
- Small footprint
Any ideas ?
Best regards,
Gilles
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
e -
-Matt Dralle, List Admin.
Posted: Sun Jan 13, 2013 8:50 am Post subject: Ground connector (was Anderson PowerPole connectors) |
James Kilford a écrit :
James,
Thank you for responding. Unfortunately the Piper style ground connector
is way too bulky, heavy etc. for our airplane.
We only need a 0.8-1 amp capacity, and our four-seater empty weight and
dimensions are less than those of your Jodel Mascaret, so we're trying
to keep weight and drag under strict control.
Thanks anyway for the input.
Best regards,
Gilles
email(at)jaredyates.com Guest
Posted: Sun Jan 13, 2013 10:38 am Post subject: Ground connector (was Anderson PowerPole connectors) |
Is there an air inlet at the bottom of the cowling? I wonder if you
could use a pigtail of wire with a 2-pin connector like the one that
comes on most trickle chargers. You could make a fastening system out
of velcro to hold it up out of the breeze when you don't need it. I
suppose this strategy could apply to any number of other air outlets,
depending on which is closest to your battery.
On Sun, Jan 13, 2013 at 11:55 AM, Gilles Thesee
<Gilles.Thesee(at)ac-grenoble.fr> wrote:
> How much current does your charger
> produce? Is the airplane metal or
> composite?
Bob,
Thank you for your response.
The current needed is only that supplied by our little charger, of the order
of 0.8-1 amp.
The aircraft skin and structure are carbon fiber.
The idea is to facilitate recharging when in a 'foreign' hangar, without
having to leave the door/canopy ajar.
Thank you,
Best regards,
Gilles
