Posted: Sat Dec 01, 2012 4:24 pm Post subject: Routing the Elevator Trim cables |
Gang
I am finding it almost “impossible” to route the CT Q-43 teleflex cables from the Elevator Trim system through the Horizontal Stabilizer spars.
Is there a secret I must know about this?
Any hints are welcome
Carlos
rene(at)felker.com Guest
Posted: Sat Dec 01, 2012 4:39 pm Post subject: Routing the Elevator Trim cables |
If I remember right…I used a shot fish tape…coat hanger…to make it happen…..
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo
Sent: Saturday, December 01, 2012 5:22 PM
Subject: Routing the Elevator Trim cables
Gang
Carlos 01234567890123456789
Posted: Sat Dec 01, 2012 4:46 pm Post subject: Routing the Elevator Trim cables |
Run a piece of Pitot line or similar tubing throwing backwards, put threaded end into tube, push through as you get the HS in place.
Jesse SaintI-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Dec 1, 2012, at 7:22 PM, "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
[quote] <![endif]--> <![endif]-->
Gang
Carlos
Quote: |
ctric.com
Quote: | www.buildersbooks.com
uilthelp.com
matronics.com/contribution
://www.matronics.com/Navigator?RV10-List
cs.com
rnewman(at)tcwtech.com Guest
Posted: Sat Dec 01, 2012 4:56 pm Post subject: Routing the Elevator Trim cables |
Carlos, The first time I tried to route those cables I thought, “ how is this possible?” fighting them all the way. So when I put them together after paint I attached a fish tape to the end of the cable and was able to pull them through the bushings and that elongated first hole without much difficulty at all. Being able to pull the cable through while pushing it from the other end was the secret for me. I though I was going to have to open up the oval hole, but did not with the help of a fish tape.
Bob Newman
N541RV flying,
N361RV under construction...oops I did it again.
Sent: Saturday, December 01, 2012 7:22 PM
To: rv10-list(at)matronics.com (rv10-list(at)matronics.com) C
Gang
Carlos
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
Posted: Sat Dec 01, 2012 5:54 pm Post subject: Routing the Elevator Trim cables |
I was not thrilled with having the cable ride in the oval hole without some kind of protection. I added a snap bushing to the cable, but as the snap bushing is at an angle to the aluminum edge of the oval hole I added epoxy to hold the bushing in place. This eliminated the issue of having the oval hole aluminum edge cut into the cable.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob-tcw
Sent: Saturday, December 01, 2012 7:56 PM
Subject: Re: Routing the Elevator Trim cables
Bob Newman
N541RV flying,
Gang
Carlos 0123456789012345678901234567
iansdad
Posted: Sat Dec 01, 2012 6:36 pm Post subject: Routing the Elevator Trim cables |
I wasn't as smart as all of the other sensible solutions Inow see here. I think I lost about a pint of bloodfrom my fingers the first time I put them through there.
Date: Sun, 2 Dec 2012 00:22:04 +0000
Gang
I am finding it almost impossible to route the CT Q-43 teleflex cables from the Elevator Trim system through the Horizontal Stabilizer spars.
Carlos
_blank">www.aeroelectric.com
" target="_blank">www.buildersbooks.com
http://forums.matronics.com
toaster73(at)embarqmail.c Guest
Posted: Sat Dec 01, 2012 6:58 pm Post subject: Routing the Elevator Trim cables |
I did this too but opened the oval a little more and added the Spring Fast edge protection to the oval. Fished cable through with aluminum tubing.
-Chris
N919AR
Bob Turner
Posted: Sat Dec 01, 2012 8:15 pm Post subject: Re: Routing the Elevator Trim cables |
I remember it was hard. I think I found a pair of 12" hemostats useful.
_________________ Bob Turner
RV-10 QB |
Posted: Sun Dec 02, 2012 2:30 am Post subject: Routing the Elevator Trim cables |
Thanks to all who responded.
Now I even know that you call “fish tape” to those steel or nylon wire guides used by the electricians to run electric wires through the walls…
The plastic or aluminum tube solution also look promising.
Now let’s fight again with those cables…
Carlos
Sent: domingo, 2 de Dezembro de 2012 00:56
Bob Newman
N541RV flying,
Gang
n223rv(at)wolflakeairport Guest
Posted: Sun Dec 02, 2012 5:18 am Post subject: Routing the Elevator Trim cables |
I think others mentioned this, but I used a piece of Tygon tubing with an ID larger than the threaded end of the cable. I routed this backwards from the rear spar of the HS forward. Then routed the cable fore-aft into this tube. Then slowly pushed the cable and pulled the tube aft until the cable comes out. Literally takes less than 1 minute.
-Mike Kraus
RV-4 sold
RV-10 flying
Gang
Carlos
Quote: |
ctric.com
uilthelp.com
cs.com
