pcondon(at)mitre.org Guest
Posted: Thu Jun 01, 2006 6:23 am Post subject: Octain Rating is not energy content in auto fuel - Its BTU ( |
Octain boosters will allow higher compression engines to extract a
little bit more energy from the combustion cycle by virtue of enabling
higher compression piston/cylinders by delaying the combustion point
and allowing a smoother flame front upon actual ignition not
preignition(compressive heating causing premature combustion). BTU is
one measure of the potential energy of the fuel we ignite. Kerosene or
diesel has the highest potential energy, then gas and finally
alcohol(in this limited fuel discussion). Adding alcohol, which has
much less BTU potential to gas makes the new mixture less BTU capable
per unit volume (gallon of fuel). Alcohol mixed gas has roughly 17%
less energy per unit volume(as currently mixed and sold I the US). Less
energy to extract, less miles per gallon, less manifold pressure, less
work. Adding octane boosters has little to nothing to this energy
conversion equation. There is simply less BTU (energy) in this new
liquid we can burn.
noelloveys(at)yahoo.ca Guest
Posted: Thu Jun 01, 2006 2:12 pm Post subject: Octain Rating is not energy content in auto fuel - Its BTU ( |
The question of octane boosters came from the fact you can wash the ethanol
out of your gasoline but as you do that you will reduce the octane rating of
the gas about 4 or 5 points. I was wondering what is readily available to
add to the fuel to get those few octane points back. From the sound of it
kero or diesel in small quantities might, and I stress might, work. I
understand from another list racers used to add a bit of kero to smooth out
their high compression engines. I'm not sure I would want to try that in
the plane.
Noel
[quote] --
bryanmmartin
Posted: Thu Jun 01, 2006 7:11 pm Post subject: Octain Rating is not energy content in auto fuel - Its BTU ( |
I don't think adding diesel or kerosene not increase the octane
rating of gasoline since both of these fuels by themselves have a
much lower octane rating than gasoline. To increase the octane rating
of gasoline you need to add a compound composed of lighter short
chain molecules with lots of branching such as benzene or toluene.
On Jun 1, 2006, at 6:10 PM, Noel Loveys wrote:
ethanol
rating of
available to
sound of it
smooth out
that in
the plane.
Noel
Bryan Martin
do not archive.
_________________ --
Bryan Martin
do not archive. |
Crvsecretary(at)aol.com Guest
Posted: Fri Jun 02, 2006 2:58 am Post subject: Octain Rating is not energy content in auto fuel - Its BTU ( |
Exactly what IS the octane rating of diesel and kerosene? I understood
diesel to have a CETANE rating which measures the AFFINITY of fuel to ignite
spontaneously under extreme heat and pressure - exactly the opposite of octane.
Tracy Smith
Naugatuck, CT
601xl N458XL (reserved)
In a message dated 6/1/2006 11:12:28 PM Eastern Standard Time,
bryanmmartin(at)comcast.net writes:
bryanmmartin
Posted: Fri Jun 02, 2006 5:43 am Post subject: Octain Rating is not energy content in auto fuel - Its BTU ( |
From What I've read, kerosene and diesel have octane ratings in the
15 to 25 range. I don't believe adding them to gasoline will raise
its octane rating.
On Jun 2, 2006, at 6:56 AM, Crvsecretary(at)aol.com wrote:
understood
to ignite
opposite of octane.
Bryan Martin
do not archive.
Bryan Martin
do not archive. |
Michael Valentine
Posted: Fri Jun 02, 2006 6:34 am Post subject: Octain Rating is not energy content in auto fuel - Its BTU ( |
Do not archive.
Sorry, but could someone explain the signficance of the octane discussion.
I understand that alcohol has less energy. What significance does the
octane rating have. Plus, if I have 93 octane mogas and add alcohol, how
does that affect the rating. Then, if I remove said alcohol, why does that
then affect the rating?
Thanks, Michael
(Planning on using a Corvair, which is likely to be fed some mogas.)
moorecomp(at)yahoo.com Guest
Posted: Fri Jun 02, 2006 7:44 am Post subject: Octain Rating is not energy content in auto fuel - Its BTU ( |
Tracy,
Here is a very informative article about octane and
cetane ratings.
http://www.prime-mover.org/Engines/GArticles/octane.html
Best regards,
Craig Moore A&P
701 builder wannabe
--- Crvsecretary(at)aol.com wrote:
Tracy Smith
Naugatuck, CT
Standard Time,
<bryanmmartin(at)comcast.net>
increase the octane
themselves have a
the octane rating
lighter short
benzene or toluene.
browse
Subscriptions page,
FAQ,
Admin.
Posted: Fri Jun 02, 2006 9:11 am Post subject: Octain Rating is not energy content in auto fuel - Its BTU ( |
Michael:
If you have 93 octane gas and add 10% ethanol the resulting octane rating
will be around 98. Ergo if you have 98 octane gasahol and remove the "ahol"
part you are back to 93 octane. Many aircraft engines need high octane fuel
so the question arises as to how to boost the 93 octane "clean" gas back to
something we can use.
The other method to use would be to find a way to remove most/all the lead
form 100 LL although the lead it self helps to raise the octane level. This
is mostly an issue with the high revving two stroke crowd. Although the
lead certainly has a big effect on certified engines.
Any way you want to cut the mustard ethanol and aviation should not mix!
Noel
[quote] --
frank.hinde(at)hp.com Guest
Posted: Fri Jun 02, 2006 9:52 am Post subject: Octain Rating is not energy content in auto fuel - Its BTU ( |
Not sure I agree with that satetment at all..i think there has simply
been very little resarch done on the matter, more like that is the
established wisdom but it has not been proven that there is a real
issue. Certainly in the altitudes that Zodiacs fly at I believe is is a
non issue (400 hours would prove it my case). As I said at length in a
previous note, Superior said they tested 10% ethanol on a Lycoming clone
and it caused vapor lock and was therfore a no-no...When I pressed them
it turns out they were not talking about vapor lock at all, but boiling
within the injector lines, which may or may not turn out to be no more
than a nusance, until it is TESTED though I don't think we can take this
as truth.
"Many aircraft engines need high octane fuel"...
Once again, this highly conjectural (is that a word?). All of the
naturally aspirated Lycomings will run quite happily on 92 octane
mogas...In fact Superior found it very difficult to make an IO360
detonate on the test stand running unleaded (92 octane) fuels.
About the only flat engine that will detonate without 100ll is the
turbocharged 350HP IO540...Not "many" of those around and a totally
different (fire breathing) animal than most of the
Lycoming/continentals.
Frank
Clmelenyzeriv(at)cs.com Guest
Posted: Tue Jun 06, 2006 7:04 am Post subject: Octain Rating is not energy content in auto fuel - Its BTU ( |
FYI there is a flying team, 4 or 5 aircraft, all RVs that fly out of Tea, South Dakota which is just south of Sioux Falls. This team is sponsored by the Ethanol lobby and they are using E85. I do not know what engines they are using or what modifications were required. I have not talked to any of the pilots, but have heard from others at the airport that the engines are "tricky" to start.
C. L.
601XL 20%
"Do not archive"
Posted: Tue Jun 06, 2006 7:39 am Post subject: Octain Rating is not energy content in auto fuel - Its BTU ( |
Yes they will be, at least when trying tostart a hot engine. this is because they have 1/8th Stainless injector lines that sit on top of the engine. As the only restriction is the injector restrictors (which is basically an open pipe onto the back of the inlet valve), when the engine stops the injector line fuel boils off and you have to wait till the mechanical pump refills the pretty long lines...Hence the cranking and cranking.
With my Lycoming I have electric pumps only so I'm hoping a lot of this issue will not happen with my setup.
The E85 engines MAY have larger nozzles to get more fuel in there. As the mixture is set by the pilot this is no big deal.
Make me less worried about finding alcohol in my Lycoming though.
Frank
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Clmelenyzeriv(at)cs.com
Sent: Tuesday, June 06, 2006 8:04 AM
Subject: Re: Zenith-List: Octain Rating is not energy content in auto fuel - Its BTU (...
C. L.
601XL 20%
"Do not archive"
