william(at)gbta.net Guest
Posted: Thu Nov 15, 2012 11:59 am Post subject: Electric aileron trim |
Im just getting ready to install the electric aileron trim in my wings before I rivet the bottom wing skins. Is this something that needs to be done now or do I need to wait until I have the ailerons rigged? Also, I read on Tim Olsons website about the "safety" trim. Is this something completely different than the standard vans electric aileron trim kit or is it simply changing out the ray allen servo for a different one. Anyone have info where to research the "safety trim" system?
rv10flyer(at)live.com Guest
Posted: Thu Nov 15, 2012 12:07 pm Post subject: Electric aileron trim |
I thought the safety trim just avoided runaway Ray allen servo issues. Not a replacement but “in addition� to. If you have a Vertical Power system, it has it built in BTW.
Sent: Thursday, November 15, 2012 11:58 AM
To: RV10-list(at)matronics.com (RV10-list(at)matronics.com)
Subject: Electric aileron trim
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
Posted: Thu Nov 15, 2012 12:28 pm Post subject: Electric aileron trim |
Correct the Safety Trim module is and additional item added to your trim control system. Here is the link to the unit: http://www.tcwtech.com/Safety-Trim-Page.htm
If you have ever tried to fly an RV substantially out of trim it will scare you enough to install some system to reverse the out of trim situation so you can make it safely down. I have installed on in my 6A, 10 & 8A.
Robin
From: owner-rv10-list-server(at)matronics.com [owner-rv10-list-server(at)matronics.com] on behalf of Pascal [rv10flyer(at)live.com]
Sent: Thursday, November 15, 2012 12:07 PM
Subject: Re: Electric aileron trim
I thought the safety trim just avoided runaway Ray allen servo issues. Not a replacement but “in addition” to. If you have a Vertical Power system, it has it built in BTW.
_blank">www.aeroelectric.com
" target="_blank">www.buildersbooks.com
tp://forums.matronics.com
Bob Turner
Posted: Thu Nov 15, 2012 12:29 pm Post subject: Re: Electric aileron trim |
"Safety Trim" is a commercial product. As stated above, it is an electronic control box which will not allow the trim to run for more than 3 seconds at one button push, to guard against a runaway trim situation. This could be due to a stuck top hat switch, or some have reported a passenger leaning on the right stick trim switch. (For this reason I opted not to install a pitch trim switch on the right yoke.)
This is more critical for pitch trim, which is much stronger than the spring loaded aileron trim. I don't know anyone who has the Safety Trim box powering their aileron trim.
_________________ Bob Turner
RV-10 QB |
Bob Turner
Posted: Thu Nov 15, 2012 12:32 pm Post subject: Re: Electric aileron trim |
I cannot answer your original question about whether it is better to hook up the aileron trim now or later, as I don't have it. I think you can go either way, I just don't know what's easiest.
RV-10 QB |
Posted: Thu Nov 15, 2012 12:40 pm Post subject: Electric aileron trim |
Bob, I chose to provide full functionality to the co-pilots stick but I also have a Activate Co-Pilots Grip switch on my panel. The co-pilots stick functions (Trim/PTT/Flip-flop/AP-Off/Flaps) are all inactive unless the panel switch arms the co-pilot controls.
I did the same for the 8A which was a mistake. Just too complicated for the few times they may be desired.
Robin
________________________________________
From: owner-rv10-list-server(at)matronics.com [owner-rv10-list-server(at)matronics.com] on behalf of Bob Turner [bobturner(at)alum.rpi.edu]
Sent: Thursday, November 15, 2012 12:29 PM
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=387990#387990
Posted: Thu Nov 15, 2012 12:50 pm Post subject: Electric aileron trim |
Safety Trim is used as a replacement for relays and such. I have the trim top hat on the control stick going to the Safety Trim box, then from the box to the aileron and elevator trim servos.
On the "co-pilot messing with the trim top hat on his/her stick" problem, I added a Trim/Flap control switch on the panel. It has a Pilot and Co-Pilot position. This way the co-pilot cannot inadvertently operate the trim or flap switches on co-pilot stick unless selected. It has a side benefit of isolating the pilot stick switches if one fails and allowing trim/flap operation from the other stick as a backup.
Carl
On Nov 15, 2012, at 3:29 PM, "Bob Turner" <bobturner(at)alum.rpi.edu> wrote:
Bob Turner
RV-10 QB
Tim Olson
Posted: Thu Nov 15, 2012 12:52 pm Post subject: Electric aileron trim |
You would probably be better off to install the trim now while
it's easy to access...even in a wing cradle. You could do it
later, but as long as you do it per-plans on the timing, you
won't go wrong. The important part is to get the measurements
down so that the spring preload isn't high in either direction,
but with the measurements they give, you should be able to do
that easily.
The Safety Trim just replaces the Ray Allen relays.
It makes it a ton easier to wire up your hat switches!
On 11/15/2012 1:58 PM, Billy Britton wrote:
| Quote: | Im just getting ready to install the electric aileron trim in my wings
Tim Olson
Posted: Thu Nov 15, 2012 12:54 pm Post subject: Electric aileron trim |
I did the same. The one single switch basically disables the
ground on the co-pilot side, so one panel switch can remove
all control from the co-pilot.
On 11/15/2012 2:40 PM, Robin Marks wrote:
inactive unless the panel switch arms the co-pilot controls. I did
Robin ________________________________________ From:
[bobturner(at)alum.rpi.edu] Sent: Thursday, November 15, 2012 12:29 PM
To: rv10-list(at)matronics.com Subject: Re: Electric aileron
trim
yoke.) This is more critical for pitch trim, which is much stronger
-------- Bob Turner RV-10 QB
Bob Turner
Posted: Thu Nov 15, 2012 1:56 pm Post subject: Re: Electric aileron trim |
Slight thread drift.....I really like the Trio pro autopilot with auto trim for making fine adjustments to trim manually, when hand flying. Trim speed is programable, slower trim speed with higher airspeed. Between the autopilot trim function, high on center stack, and the Ray Allan rocker, on the panel to the right of the radios, I'm comfortable flying right seat without a right stick top hat?
RV-10 QB |
rnewman(at)tcwtech.com Guest
Posted: Thu Nov 15, 2012 3:53 pm Post subject: Electric aileron trim |
Some details and comments on Safety-trim: Safety-Trim provides two speed
control of the trim surfaces, with 3 second runaway prevention. It
eliminates the need for any relay decks. As such, it makes wiring of the
trim systems very easy, we've seen most customers choose our two axis
controller (pitch and roll trim), thereby greatly simplifying the wiring,
instead of using relays for the roll axis and a single axis Safety-Trim for
pitch. Lastly the VP trim system is not exactly the same as Safety-Trim.
If you drive the system for more than 3 seconds with Safety-trim it stops
the servos from run-away, if you need to drive more than 3 seconds worth of
trim, just let up on the switch and press again for more trim. We patented
this feature. The VP system must utilize a menu or another method of
resetting the time limit to get more than 3 second limit. (We believe this
may be quite important on a go-around depending on your aircraft's
particular trim requirements)
All the details and our instruction sheet can be found on www.tcwtech.com
Lastly, regarding installation of the aileron trim servo after the build.
We did it without issue. The only pain is that you must remove the bolts
thru the rod ends on the aileron push tube so you can drill the tube in the
proper location for the spring attach brackets. Its also way more fun
working on your back, laying on the cold hangar floor, reaching up thru the
access hole. Seriously though, it certainly is not a difficult
retrofit, I'd much rather do this than move the fuel flow transducer out
of the tunnel!
Bob Newman
RV-10
N541RV
Posted: Thu Nov 15, 2012 4:58 pm Post subject: Electric aileron trim |
I'm a very happy safety trim user - 200 hours. The 3 second thing is a
good thing all around. And it did make the wiring easier than using the
relays.
Going back to the original post - installing the trim in the wing is
really easy while you have in the cradle. You just rivet two little
bits of aluminum to the pushrod and run the wires to where the trim
servo is mounted. You don't even have to do the trim servo mounting at
this point - it's installed on the access panel and can easily be
completed whenever. Determining exactly where the two bits are mounted
is the only trick, but as I recall (I said "recall"), all you have to do
is get it close, and that's easy.
In other words, there's very little to do before putting the skins on
but it does pay to do it before.
And safety trim (and I assume the VP system) are all installed up by
the panel so there's nothing to do there relative to the wing.
So if you can roughly locate those two bits of aluminum that attached
the pushrod to the trim springs, and rivet them, that's all you really
need to do before skinning. Getting any and all wiring in is good too
but a conduit can handle the wiring too.
Bill Watson
On 11/15/2012 6:52 PM, bob-tcw wrote:
speed control of the trim surfaces, with 3 second runaway prevention.
It eliminates the need for any relay decks. As such, it makes
wiring of the trim systems very easy, we've seen most customers
choose our two axis controller (pitch and roll trim), thereby
greatly simplifying the wiring, instead of using relays for the roll
axis and a single axis Safety-Trim for pitch. Lastly the VP trim
system is not exactly the same as Safety-Trim. If you drive the system
for more than 3 seconds with Safety-trim it stops the servos from
run-away, if you need to drive more than 3 seconds worth of trim,
believe this may be quite important on a go-around depending on your
aircraft's particular trim requirements)
build. We did it without issue. The only pain is that you must
remove the bolts thru the rod ends on the aileron push tube so you can
drill the tube in the proper location for the spring attach
brackets. Its also way more fun working on your back, laying on the
cold hangar floor, reaching up thru the access hole. Seriously
though, it certainly is not a difficult retrofit, I'd much rather
do this than move the fuel flow transducer out of the tunnel!
Bob Newman
RV-10
N541RV
hotwheels
Posted: Fri Nov 16, 2012 7:30 am Post subject: Re: Electric aileron trim |
I just hooked up my aileron trim springs to the left wing pushrod. I wouldn't drill holes until final pushrod alignment when the wings are on as it's possible that things won't line up the same as when the wings are in the cradles. I did, however, pre-wire and mount the servo on the wing access panel long ago.
Jay
Posted: Fri Nov 16, 2012 8:11 am Post subject: Electric aileron trim |
agree. Put the alierons on and get the angles up and down completed before
doing the trim for them.
