peterthomson
Posted: Mon Oct 22, 2012 3:38 am Post subject: Pitch servo |
hi List
I've just fitted a Dynon SV32 pitch servo to a Jabiru J170C, but not yet test-flown.
It certainly has some heavy work due to the two cables and the spring trim it has to work with.
Does anyone have some experience to share ?
thanks
Peter
| | - The Matronics Jabiru-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Jabiru-List |
tejasflyer
Posted: Mon Oct 22, 2012 4:37 am Post subject: Pitch servo |
While not a dynon, I have a GRT servo in a jabiru 450 experimental. I utilized what GRT terms a high torque servo, and it has performed very well. I assume Dynon would have something comparable. It's been in for 400+ hours, with no issues. I used an additional push pull cable to the elevator horn directly from the servo.
Ken Bailey
On Oct 22, 2012, at 6:38 AM, Peter Thomson <peterlthomson(at)gmail.com (peterlthomson(at)gmail.com)> wrote:
[quote]hi List
thanks
Peter
_________________ KB |
peterthomson
Posted: Mon Oct 22, 2012 6:58 pm Post subject: Pitch servo |
thanks Ken
Yes, Dynon make two levels of torque in servos, and did have an even
heavier one.
I had both, and put the stronger one as the roll servo, thinking it
would be seeing more use. I may have to switch them, as the two cables
(elevator and pitch servo) plus the spring on the trim makes for a
heavy load. Will wait to check in flight and advise.
Ken Bailey
[quote]hi List
yet test-flown.
thanks
Peter
