uvtreith(at)t-online.de Guest
Posted: Thu Oct 11, 2012 12:47 am Post subject: Mod 73 and Service Bulletin 15 |
Hi Family,
The accident with William and Paul happened not due to a technical problem with the Europa, it was a built problem.
But further investigations were showing that some builders had not made the layout of the pippin/tailplane correctly. Therefore to avoid problems for the future Mod 73 was issued.
As there was in addition a play via the complete system (from the stick to the tailplane due to the sum of connections) the Service Bulletin 15 was issued.
Here it is mandatory to use Loctite 603 (very low viscosity) and apply it to all fixed connections. Dirk Oyen had for that a great solution (using a vacuum cleaner to get the Loctite between the bushes and the torque tube). He made pictures and gave it at that time to the forum. Maybe it is still available.
I hope this helps.
Best Regards,
Bruno
-----Ursprüngliche Nachricht-----
Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Alan Carter
Gesendet: Donnerstag, 11. Oktober 2012 00:54
An: europa-list(at)matronics.com
Betreff: Re: Mod 73
--> Europa-List message posted by: "Alan Carter" <alancarteresq(at)onetel.net>
Hi Brian.
To me it feels like play, i will check again, and slide the Stablators off and check inserts making sure they are bonded.
I am just a pilot but i could have done a better job in designing this linkage.
As this has the possibility of grounding the aircraft for some considerable time, due to the fact that clamps are individually made to size, Why has,t something not been done about it.??
Why can,t you get a complete unit with clamps already made, so the job could be done in one go, say a day, not grounded for 2 months.
Alan
http://forums.matronics.com/viewtopic.php?p=385078#385078
 Download |
| Filename: |
Sb_15_Remove_of_play.pdf |
23.53 KB |
| Downloaded: |
316 Time(s) |
ptag.dev(at)talktalk.net Guest
Posted: Thu Oct 11, 2012 2:39 am Post subject: Mod 73 and Service Bulletin 15 |
Hi! Bruno,
I was unaware that the fatal accident involving William and Paul had categorically been attributed to the tail plane issue?
Since I also believed that there was an issue concerning wing rear lift pins And close out lay ups with the aluminium strips being mis –aligned so the threaded holes were broken through the side of the plates. I saw one photo into the root lay ups where there was serious separation in that the layers were glossy after separation.
Frankly.... the slop between tail plane trailing edges is likely to cause flutter of catastrophic proportions so I personally have little confidence in Loctite as a permanent solution. It is also conceivable that the slop will result in constant battering of the stabilator inner bearing bonding . “Better bite the bullet” and send an order for my clamps! See the current LAA mag, where it is alleged that the pins wear, this is incorrect because it is actually the torque tube which becomes slotted by the radial loads from the pins. (Not PIP PINS)
I am aware of a number of aircraft where the Loctite method has failed.
The issue of stabilator retention PIP PINS requiring the torque tube matching holes radially elongating (ONLY the torque tube or your PIP pins may fall OUT) and the de-bonding of the inner stabilator bush allowing the stabilator to exit from the drive pins at the close out, are completely separate and independent issues, but likewise are of vital importance. To loose the drive to one stabilator would have unthinkable consequences.
Bob Harrison G-PTAG Trike 914 Kit 337 nearing 1000 hours.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of UVTREITH
Sent: 11 October 2012 09:46
Subject: Mod 73 and Service Bulletin 15
Hi Family,
I hope this helps.
Best Regards,
Bruno
Von: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] Im Auftrag von Alan Carter
An: europa-list(at)matronics.com (europa-list(at)matronics.com)
Betreff: Re: Mod 73
--> Europa-List message posted by: "Alan Carter" <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)>
Hi Brian.
Alan
raimo.toivio(at)rwm.fi Guest
