edgraydallas
Posted: Fri Sep 28, 2012 7:22 am Post subject: Oil use |
I agree with Guy. I used a little less than 50 / 1 in my 582. You are using just over half that ratio. There is an adjustment on the oil injector to increase the oil flow. There are some engines that are OK on 100 to one, but I would not chance it for too long. Ed Gray
mikeperkins
Posted: Fri Sep 28, 2012 11:12 am Post subject: Re: Oil use |
Richard Swiderski from the Kolb forum wrote back in August of 2000 that he was getting an oil ratio of 58-60 to 1 overall with his 582. As Ed said, it might be as simple as adjusting the oil metering linkage.
An article by Mike Stratman on setting up oil injection is here: http://www.800-airwolf.com/pdffiles/ARTICLES/part45.pdf
There is also a short section here on oil injection: http://www.ultralightnews.com/enginetroublshooting/techtips/techtips1.htm
Hope this helps.
_________________ Mike Perkins
Havana, Illinois
Model I, 532, B gearbox, GSC prop |
brubakermal(at)yahoo.com Guest
Posted: Fri Sep 28, 2012 4:20 pm Post subject: Oil use |
today we made an ajustment on the actuator and cable end , and put a new filter in line .It is a good idea to track the oil usage often i think.
Malcolm & Jeanne Brubaker
Michigan Sport Pilot Repair
http://michigansportpilotrepair.com/
LSRM-A, PPC, WS
Great Sails - Sailmaker
for Ultralight & Light Sport
(989)513-3022
Sent: Friday, September 28, 2012 11:21 AM
Subject: Oil use
[quote]httphttp://www.matronics.com/contribut==============
