brubakermal(at)yahoo.com Guest
Posted: Thu Sep 27, 2012 5:01 pm Post subject: oil usage?? |
My new plane W/ 582 has oil injection and i have never used oil injection befor so im getting used to topping it off. it looks like my last 2 nites flying four short flights 4 landings and take offs with taxing and such I burned 9 gallons gas in 2.2 hrs and used 12 oz of semi synthetic oil.
Is this a safe amount? of oil for that many gallons of fuel over that time on the tiny tac?
mal
Malcolm & Jeanne Brubaker
Michigan Sport Pilot Repair
http://michigansportpilotrepair.com/
LSRM-A, PPC, WS
Great Sails - Sailmaker
for Ultralight & Light Sport
(989)513-3022
Guy Buchanan
Posted: Thu Sep 27, 2012 7:52 pm Post subject: oil usage?? |
On 9/27/2012 6:01 PM, Malcolm Brubaker wrote: | Quote: | | 9 gallons gas in 2.2 hrs and used 12 oz of semi synthetic oil. |
9 gallons gas and 12oz. oil is 96:1, not good. You should be running closer to 50:1. (The injection system will run 70:1 at idle, but you probably didn't idle very much.) Don't know what to tell you to look for, other than making sure both carbs have evidence of oil. It looks like maybe only 1/2 the system is working.
Guy Buchanan Normal Guy Buchanan 2 21 2011-09-20T05:05:00Z 2011-09-20T05:05:00Z 1 31 183 1 1 213 14.00 <![endif]--> 59 false false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} <![endif]--> <![endif]--> <![endif]-->Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded
Now a glider pilot, too.
Deceased K-IV 1200
A glider pilot too. |
