Left\Right Fuel Systems?
oldjagman(at)yahoo.com
PostPosted: Wed Sep 19, 2012 6:25 pm    Post subject: Left\Right Fuel Systems? Reply with quote
John
The Cessna 150's and 172's do the same thing.
 There's too much fuel in the tank. Heat of the day will also
expand the fuel volume, if re-fueled in the evening,
or early morning.
Try a little less fuel ...a gallon or two is all.
I doubt valves, unless you put them in a vent line...(DON'T!)  will help.
Charlie NJ
Sent: Wednesday, September 19, 2012 7:44 PM
Subject: Re: Left\Right Fuel Systems?
Thanks all for the input...
The main grip is really not uneven feeding during flight, it is the sloshing of fuel on the ground.
If I fuel up for a long flight and taxi on un-even ground there is the very real possibility ( IE it HAS happened to me) for fuel to come out of the vents on the ground.
John Marzulli
http://MarzulliPhoto.net/
http://701Builder.blogspot.com/
On Wed, Sep 19, 2012 at 4:25 PM, <NYTerminat(at)aol.com (NYTerminat(at)aol.com)> wrote:
I am pretty sure those are the ones that I used. Use a tubing bender to prevent kinks in the tube.
Bob Spudis
In a message dated 9/19/2012 7:17:09 P.M. Eastern Daylight Time, craig(at)craigandjean.com (craig(at)craigandjean.com) writes:
Wag-Aero sells a cap with the tube. It is delivered straight. You install it on your tank, clock it to the closed position and then bend the vent pipe to face forward. As I recall people “tune� the pressure to prevent over-pressure by varying the angle of the forward-facing tube downward. The price of $38.95 seems high.
Ram Air Pressure Cap, SKU: E-481-000
http://store.wagaero.com/product_info.php?products_id=8107
-- Craig
ist href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
s.matronics.com/">http://forums.matronics.com
p://www.matronics.com/contribution">http://www.matronics.com/contribution
ist" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
http://www.matronics.com/Navigator?Zenith701801-Listhttp://=======================
