n223rv(at)wolflakeairport Guest
jump2(at)sbcglobal.net Guest
Posted: Sun Sep 16, 2012 10:09 am Post subject: Garmin 696 XM music question |
I have the same in my c310 I'll look it up tomorrow and check what I can.
Patrick Thyssen
N15pt
Down waiting on new engine
Sent from my iPad
On Sep 16, 2012, at 12:24 PM, Michael Kraus <n223rv(at)wolflakeairport.net> wrote:
I have a Garmin 696 with XM music and I can't seem to get the sound loud enough to hear consistently. I have it going into the music input of an Apollo SL-15 audio panel.
What I need is a way to amplify the output of the 696. Does anyone have any ideas? I thought I heard of a way to add a resistor or diode or something somewhere and it would increase the output??
Any advice would be greatly appreciated.
-Mike Kraus
KitFox SS7 building
RV-10 Built and Flying
RV-4 Built, Flying and sold
Sent from my iPad
rene(at)felker.com Guest
Posted: Sun Sep 16, 2012 10:17 am Post subject: Garmin 696 XM music question |
Radio shack sells audio amplifiers.....I think they are around $20. They
are battery operated.
rick.mcbride(at)me.com Guest
Posted: Sun Sep 16, 2012 10:37 am Post subject: Garmin 696 XM music question |
I can't speak for the Apollo audio panel but my Garmin audio panel required a minor modification to increase the XM volume out of my 396 and 496 units. My local avionics shop did the mod for a minimal cost.
Rick McBride
RV-6 finished '92 sold '97
RV-8 finished '04 630 hours and climbing
RV-10 started 9/12
Posted: Sun Sep 16, 2012 10:55 am Post subject: Garmin 696 XM music question |
That's what I'm looking for... What was the mod???
Rick McBride
RV-10 started 9/12
Posted: Sun Sep 16, 2012 11:11 am Post subject: Garmin 696 XM music question |
Let me do some research. The mod instructions came with the unit if I recall. I need to look through my files.
Rick
On Sep 16, 2012, at 2:54 PM, Michael Kraus <n223rv(at)wolflakeairport.net> wrote:
> Rick McBride
> RV-10 started 9/12
Posted: Sun Sep 16, 2012 11:57 am Post subject: Garmin 696 XM music question |
The only details I could find are in the installation manual. For the Garmin 340 panel there were two mods (2 & 5) that both claim to boost the music audio. The manual doesn't provide any details on either mod. As I mentioned, my local shop did the work. I have no idea if these type of mods apply to your Apollo. A call to your local avionics shop might help. Sorry I can't be of any more help.
Rick
> Rick McBride
> RV-10 started 9/12
Posted: Sun Sep 16, 2012 12:07 pm Post subject: Garmin 696 XM music question |
Mike,
Here's a write-up I did a few years ago on the Aeroelectric list.
This pertains to the 496 but maybe it's similar. Hope it helps.
Message: #38783
Subject: 496 Audio
Date: Nov 01, 2007
Marty and all, We learned a bunch today about audio out from the
Garmin 496 that could be helpful. I had a harness built by Stark to
allow me to put audio from the power/data chord from a 2/3/496 into
unswitched audio in my GMA340 audio panel. Seemed like a simple thing,
but we never got any audio from the power/data chord. Audio jack, yes,
data chord, no. Turns out the audio from the power/data cable is to
drive an 8 ohm speaker. I learned that by taking apart a Garmin 12V
adapter/speaker and reading the back of the $.05 speaker inside: Made
in China, 8 Ohms, 2/3W. The audio panel was looking for a 600 ohm
input. Interestingly, Garmin told told both John and me that the only
audio coming out of the 496, in aviation mode, was from the audio
jack(3/496s have a 1/8" audio jack, which outputs XM audio, and all
the warnings, as well as "Voice +" and "Voice -" wires in the
power/data cable). Garmin said not even to bother trying to get audio
from the Voice wires while in aviation mode. It did not exist. Well,
it does exist because it plays just fine with the speaker/12V adapter
plugged in. I put the unit in sim mode and flew into a mountain. The
speaker gives every warning you would expect, and the "Sound" page of
the Setup menu controls the audio as you would expect. With a jack
inserted into the audio plug, the XM audio is turned off to the
power/data chord but all the warnings still come through. Which is
nice, because if you wire the unit per Garmin's advice, and run the
audio jack into the music input of the audio panel, your terrain
warnings will get muted by intercom activity or incoming
transmissions. I want to know about those pesky mountains, even if it
interupts music playing in the background... Now my problem is to
figure out how to convert the 8 ohm signal from the power/data chord
to 600 ohms. I guess I need a transformer. I found a 8 ohm to 1000
ohm, with center tap, at radio shack...can anyone tell me if that will
work? How do I wire it? Dave Saylor AirCrafters LLC 140 Aviation Way
Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com
Dave Saylor
831-750-0284 CL
On Sun, Sep 16, 2012 at 10:24 AM, Michael Kraus
-Mike Kraus
KitFox SS7 building
Sent from my iPad
jjessen01
Posted: Sun Sep 16, 2012 12:35 pm Post subject: Garmin 696 XM music question |
Dave, did you ever get it to work?
On Sep 16, 2012, at 1:06 PM, Dave Saylor <dave.saylor.aircrafters(at)gmail.com> wrote:
Mike,
Message: #38783
Subject: 496 Audio
Date: Nov 01, 2007
Dave Saylor
831-750-0284 CL
> -Mike Kraus
> KitFox SS7 building
> Sent from my iPad
Posted: Sun Sep 16, 2012 3:39 pm Post subject: Garmin 696 XM music question |
Dang, I didn't mean to leave you in suspense... I shoulda read it again!
We did get it working, not with a transformer but by using just the
voice + and letting it ground via the "regular" ground, not "voice -".
The rational was that the voice +/- was meant to drive a speaker so
"voice -" is actually a signal opposite the hi side, not just zero.
I'm in a little over my head but I'm sure some audio folks can
describe it better.
Dave Saylor
831-750-0284 CL
On Sun, Sep 16, 2012 at 1:35 PM, John Jessen <n212pj(at)gmail.com> wrote:
> Mike,
> Message: #38783
> From: "Dave Saylor" <Dave(at)AirCraftersLLC.com>
> Subject: 496 Audio
> Date: Nov 01, 2007
> Dave Saylor
> 831-750-0284 CL
>> -Mike Kraus
>> KitFox SS7 building
>> Sent from my iPad
Bob Turner
Posted: Sun Sep 16, 2012 4:19 pm Post subject: Re: Garmin 696 XM music question |
The radio shack transformer should work okay. Cut the center tap off. Of course you'll need two for stereo.
Early Garmin 340 panels didn't have sufficient gain for the usual audio sources, whether ipad, CD, xm, etc. Garmin had a fix which required you to go to a dealer, where they soldered in one or two new resistors to increase the gain. Later 340 panels brought the fix out to a pin in the back, ground it to increase the gain. The reason it's an option is that along with the higher gain comes more noise. It is really poor engineering when you can hear electronic noise in an airplane!
I cannot comment on later Garmin panels, nor the Apollo/UPS.
_________________ Bob Turner
RV-10 QB |
Posted: Sun Sep 16, 2012 5:31 pm Post subject: Garmin 696 XM music question |
Dave,
I get the voice to work fine, it's just the music output that cuts in and out due to not enough output. I have a small iPod amplifier that I temporarily hooked up and it does solve the problem, but the design of it is not something I'd like to try and incorporate.
Did your solution fix voice and music? Or just voice transmissions?
Thank you
-Mike
On Sep 16, 2012, at 7:38 PM, Dave Saylor <dave.saylor.aircrafters(at)gmail.com> wrote:
describe it better.
Dave Saylor
831-750-0284 CL
>> Mike,
>> Message: #38783
>> Subject: 496 Audio
>> Date: Nov 01, 2007
>> Dave Saylor
>> 831-750-0284 CL
>>> -Mike Kraus
>>> KitFox SS7 building
>>> Sent from my iPad
