barryjedwards(at)lineone. Guest
Posted: Mon Sep 03, 2012 2:39 am Post subject: 912 Plug Caps and carb mounts |
Hi all,
I need to get a set of 912 plug caps but they cost £35.00 EACH in the UK from the Rotax agent. I think I asked this question a couple of years ago and someone kindly put me in touch with a company I think in NZ that could do them for a more realistic price, but I’ve lost all the details of who they were.
Has anyone used the carb mount rubbers from this company in the US?
http://www.jbmindustries.com/912socket.html
Again, the original Rotax part is half the price of a new engine so I might be interested in buying some of these parts. It would be good to know if anyone has any experience of them.
Thanks all,
Barry
G-XPXP 912 Taildragger UK 1030hrs
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
CYard52306(at)aol.com Guest
Posted: Mon Sep 03, 2012 3:18 am Post subject: 912 Plug Caps and carb mounts |
Barry
Do you have automotive plugs or the original aircraft with aircraft plugs.
Regards Cy g-plsa 912
kdpalmer(at)mweb.co.za Guest
Posted: Mon Sep 03, 2012 3:19 am Post subject: 912 Plug Caps and carb mounts |
Barry,
The Bing Carb Mount Rubbers are BMW R100RS motor cycle rubber mounts, the spark plug caps find a Local dealer that supplies the smaller size plugs they should have suppressed caps. When you live in Africa you learn to improvise.
Keith
Posted: Mon Sep 03, 2012 3:42 am Post subject: 912 Plug Caps and carb mounts |
Keith,
When you live in the UK everyone tries to stop you improvising if it costs them a sale! There is no non Rotax supply available of the carb mounts that I have been able to find in the UK and nor are there any plug caps that match the originals. I’ve found some similar ones but they have a 90 degree bend and don’t fit on the lower plugs at all well.
Cy, I’m using some originals and some ‘improvised’ ones but I want to fit all ‘original’ types if I can buy at a sensible price!
Barry
Sent: Monday, September 03, 2012 12:19 PM
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Subject: Re: 912 Plug Caps and carb mounts
Barry,
Keith
esalehto(at)yahoo.com Guest
Posted: Mon Sep 03, 2012 5:18 am Post subject: 912 Plug Caps and carb mounts |
Hi,
Does anyone have BMW part number for carb mounts available?
Esa
From: Barry J Edwards <barryjedwards(at)lineone.net>
Sent: Monday, September 3, 2012 4:41 AM
Subject: Re: Pulsar-List: 912 Plug Caps and carb mounts
Keith,
Barry
Barry,
Keith
Posted: Mon Sep 03, 2012 5:53 am Post subject: 912 Plug Caps and carb mounts |
Esa,
They are standard on the older Boxer type bikes, take your sample to the agents to check.
Posted: Mon Sep 03, 2012 5:59 am Post subject: 912 Plug Caps and carb mounts |
Bernie,
Didn't you buy BMW Carbs mounts when you broke down that time ?.
Please confirm that they worked Okay ?
Keith
pulsardr(at)gmail.com Guest
Posted: Mon Sep 03, 2012 8:24 am Post subject: 912 Plug Caps and carb mounts |
Barry,
I have used these carb mounts from this company. The mount is very well made, looks better than the original Rotax mount but I suppose only time will tell how they hold up. Don't know the difference in cost from the BMW part.
Dean
On Sep 3, 2012, at 5:34 AM, Barry J Edwards wrote:
Hi all,
Thanks all,
Barry
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronics.com/Navigator?Pulsar-List
briana(at)xtra.co.nz Guest
Posted: Mon Sep 03, 2012 11:17 am Post subject: 912 Plug Caps and carb mounts |
Barry,
I got a plug cap [identical, I think it was Bosch] from a local motorcycle dealer at a very reasonable price. All mine are 90 deg caps with a suppressor resistor built in.
I also replaced the carb sockets some time back because the originals had cracks inside. The cracks were not visible until the socket was removed, but it would not have been a fun day if they cracked all the way through. The original sockets were rather soft and flexible. I bought the replacements from the local Rotax agent, and I thought that the price was acceptable. Well, at that time I didn't know that there might have been other possibilities anyhow. The new sockets were much harder rubber, and much less flexible. Supposed to last a deal longer and so far they are OK.
Brian
On 3/09/2012, at 10:34 PM, Barry J Edwards <barryjedwards(at)lineone.net (barryjedwards(at)lineone.net)> wrote:
[quote] Hi all,
Thanks all,
Barry
