Garmin 327 problem
1rv4
PostPosted: Mon Aug 20, 2012 5:29 pm    Post subject: Garmin 327 problem Reply with quote
Just hoping someone else has run across this problem and better still has a solution. I have a new Garmin 327 installed in a ragwing aircraft. When the Transponder is switched to Alt. the correct altitude shows up on the Garmin but the controllers can't read the altitude, the Ident function works. It's a stand alone Transcal encoder.
  Thanks Kit
henry(at)pericynthion.org
PostPosted: Mon Aug 20, 2012 5:49 pm    Post subject: Garmin 327 problem Reply with quote
Probably an issue with the transponder antenna or connection between
the antenna and the transponder. A marginal connection between the
xpdr and antenna can give a weak return signal that is strong enough
for Mode A / Ident but not strong enough for Mode C. The correct
altitude readout on the Garmin 327 indicates that the encoder and
encoder-transponder connection is fine.
Good luck,
Henry
On Mon, Aug 20, 2012 at 6:27 PM, Chris Fordham <fconsult(at)telus.net> wrote:
Thanks Kit
