Yak-50 ignition troubleshooting
moose8154
PostPosted: Sat Aug 18, 2012 6:29 pm    Post subject: Yak-50 ignition troubleshooting Reply with quote
Hi,
My shower of sparks stopped working... Can someone give me some tips on how to proceed to troubleshoot this issue?
Olivier
cjpilot710(at)aol.com
PostPosted: Sun Aug 19, 2012 3:07 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
Olivier,
If all your wiring is good, there is not much you can do to "repair" the "shower of sparks" vibrator. You may open it up and clean it out but I doubt you'll get much of a change. You'll most likely have to replace it.
Jim "Pappy" Goolsby
GeorgeCoy
PostPosted: Sun Aug 19, 2012 4:49 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
We offer a solid state replacement. Contact off list.
George coy
Sent from my iPad
On Aug 19, 2012, at 7:04 AM, "\"" <cjpilot710(at)aol.com (cjpilot710(at)aol.com)> wrote:
[quote] Olivier,
Jim "Pappy" Goolsby
dsavarese0812(at)bellsout
PostPosted: Sun Aug 19, 2012 5:23 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
Most of the time the problem is the wire from the starting coil to the
left mag. The way to check it is to remove the wire from the left
magneto cap. Then follow this procedure.
- Make sure the main air valve is turned off
- Squeeze the brake handle until you no longer hear the "woosh" sound
when you release the brakes. (you are making sure there is no air
forward of the main air valve. You'll understand why in just a minute.)
- Now hold (or have someone hold) the end of the starting coil wire
approximately 3/8" to 1/2" away from any bare metal around the engine.
Use a pair of pliers to hold the wire and be at least 6" from the end of
the wire.
- In the cockpit, turn on the BATT and IGN switches. (remember, there
is no air in the system now FORWARD of the main air valve).
- In the cockpit, press the START button. The engine will not rotate
(no air), but the starting coil wire should arc to ground. It normally
should jump about 3/8" - 1/2" if the wire is good. Move the tip of the
wire closer to see at what point the spark from the tip jumps. If it
does not jump the 3/8" - 1/2", replace the wire (easy to do on the Yak
50) and repeat the test. The wire is 7 mm and you can buy 10' of it on
this web site. http://www.mfgsupply.com/24-8775.html
Check the points inside the starting coil case.
- Remove the cover of the starting coil and look for a small set of
points on the brown coil. If the points have "mounds" built up, use a
point file GENTLY to clean the mound off the points. Once the points are
cleaned you can actually adjust the spark by adjusting the point
opening. While holding the starting coil wire close to ground again,
rotate the knob by the points in the starting coil unit while someone
presses the START button in the cockpit and adjust the gap until the
spark jumps about 3/8" inch or so.
Hope this helps.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 8/19/2012 6:04 AM, " wrote:
[quote] Olivier,
replace it.
Jim "Pappy" Goolsby
jan.mevis(at)informavia.b
PostPosted: Sun Aug 19, 2012 10:15 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
And I confirm that this works VERY well, I replaced mine recently with George's solution. Since then, flawless and immediate startup!
Jan
From: george coy <george.coy(at)gmail.com (george.coy(at)gmail.com)>
Reply-To: "yak-list(at)matronics.com (yak-list(at)matronics.com)" <yak-list(at)matronics.com (yak-list(at)matronics.com)>
Date: Sunday 19 August 2012 14:46
Subject: Re: Yak-50 ignition troubleshooting
George coy
Sent from my iPad
[quote]Olivier,
Jim "Pappy" Goolsby
moose8154
PostPosted: Sun Aug 19, 2012 4:44 pm    Post subject: Re: Yak-50 ignition troubleshooting Reply with quote
Thanks everybody,
I checked the resistance of the cable between the vibrator and the mag: 2.4 ohm.
Even after cutting the tip that didn't look so good, it is still the same, so I'll try changing that first.
Olivier
PostPosted: Sun Aug 19, 2012 10:27 pm    Post subject: Yak-50 ignition troubleshooting Reply with quote
So why do you think that the cable is the problem, with 2.4 ohm (measured)?
Do you get a good spark from the shower-of-sparks-device (using Dennis's
method)?
It is not uncommon for ignition cables to have some electrical resistance.
That resistance can be rather high, in the hundreds of ohms, with the new
type of cables (i.e. The 8 mm spiro wound).
Jan
On 20/08/12 02:44, "moose8154" <olivier_langeard(at)hotmail.com> wrote:
Thanks everybody,
2.4 ohm.
Olivier
http://forums.matronics.com/viewtopic.php?p=381293#381293
moose8154
PostPosted: Mon Aug 20, 2012 1:33 am    Post subject: Re: Yak-50 ignition troubleshooting Reply with quote
No spark whatsoever...
PostPosted: Mon Aug 20, 2012 2:16 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
Then it's the shower-of-sparks-device.
These things are getting old, I'd replace it with George Coy's electronic
device.
Jan
http://forums.matronics.com/viewtopic.php?p=381321#381321
PostPosted: Mon Aug 20, 2012 3:18 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
Before you assume it is a starting coil failure, do you hear a 'buzz'
coming from the starting coil assembly when you press the start button?
Next, remove the cover on the starting coil assembly and have someone
press the start button (remember, main air off and all air bled from the
system using the brake handle) and you watch the points on the starting
coil to see if they are arcing. If they are, replace the wire. It is by
far more common for the starting coil wire to go bad than the starting
coil itself. Especially if it is one of the original wires because the
rubber on the wire deteriorates and cracks causing the wire to arc to
the shielding (ground). If the points are not arcing, then by all
means replace the starting coil with George Coy's unit.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
device.
Jan
PostPosted: Mon Aug 20, 2012 3:53 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
As usual, that makes perfect sense, Dennis!
Jan
On 20/08/12 13:15, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net>
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
>electronic
> device.
> Jan
Vic
PostPosted: Mon Aug 20, 2012 5:05 am    Post subject: Re: Yak-50 ignition troubleshooting Reply with quote
Hello Olivier,
just in case you may prefer the old style non electronic buzzer coil, military grade, real fat spark, I could supply them at $ 100.- inc. shipping. They turn up a few times a year, new old stock and work perfectly - a bit more weight but a lot more durable, see below :
http://forums.matronics.com/viewtopic.php?t=74605&highlight=buzzer+coil
Cheers
Vic
PostPosted: Mon Aug 20, 2012 5:32 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
Nice stuff!
Jan
On 20/08/12 15:05, "Vic" <vicmolnar(at)aol.com> wrote:
Hello Olivier,
Cheers
Vic
http://forums.matronics.com/viewtopic.php?p=381338#381338
mark.bitterlich(at)navy.m
PostPosted: Mon Aug 20, 2012 6:53 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
The starting coil on both the YAK-50 and the CJ6A are identical.
Totally interchangeable. The spark coils develop continuous spark
energy when the starting button is depressed. They require 28 Volts
D.C. to be applied before they will operate, thus good troubleshooting
procedure is to first make sure that you are getting 28 VDC TO THE
STARTING COIL ITSELF (!!!) before you replace it with a new one. This
is not too hard to do, and if you look at it, this should become pretty
obvious.
Next: A coil like this does not operate with pure "D.C." per se.
Instead it needs some form of Alternating Current" to make it work.
This allows the coils magnetic field to move ... as in expand and
collapse.... so that it passes through the "coil of wires" in order to
INDUCE energy into the secondary winding and ramp it up to really
serious voltage. Enough to make a spark jump through the air. This is
done with a very simple design called a "buzzer".
A "buzzer" is simply a small relay type of device wired so that when the
contacts are closed, voltage is supplied to the RELAY coil, (not the
main coil which makes the high voltage, but a much smaller one) which
then creates its own magnetic field pulling the contacts open. This
breaks the circuit, the magnetic field goes away, and the contacts close
thus completing the circuit again and the cycle repeats. This creates a
BUZZING sound when it is operating. This buzzer contact is tapped and
then feeds the MAIN coil. This then creates a SQUARE WAVE of voltage
fed to the main coil (On and off. On and off) which is in fact a form
of AC energy, allowing the coil to create a continuous output (more or
less).
The "contacts" in the "Shower of Sparks Coil" (or whatever you want to
call it) are in fact easily visible and are in fact adjustable. There
is a little wheel on one end that sets the "gap" between these points.
If memory serves me .... you can take off an inspection plate and get at
these points yourself. Use some kind of marker so that you can put
things back where they were to begin with, and try rotating this wheel
to adjust the point gap. If the unit starts working again (buzzing),
you can adjust that gap for the biggest spark you can get at a plug.
Of course replacement is very easy, and I also *HIGHLY* recommend George
Coy's replacement, however ... if you want to go with the exact original
also check Doug Sapp. He used to sell them for the CJ-6A, and as I
said, those are identical to what is used in YAK's and Sukhoi's for that
matter.
Mark Bitterlich
dougsappllc(at)gmail.com
PostPosted: Mon Aug 20, 2012 7:16 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
I have the stock Russian/Chinese boost coils in stock.  Contact me off line if I can help.
Best from Omak,
Doug
On Mon, Aug 20, 2012 at 6:05 AM, Vic <vicmolnar(at)aol.com (vicmolnar(at)aol.com)> wrote:
[quote]--> Yak-List message posted by: "Vic" <vicmolnar(at)aol.com (vicmolnar(at)aol.com)>
Hello Olivier,
Cheers
Vic
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
GeorgeCoy
PostPosted: Mon Aug 20, 2012 7:22 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
Yes a great system! It worked well in the early Model"T" Fords. They had 4
spark coils lined up, one for each cylinder and you could see them buzzing
away while driving. Not giving away my age, but I once drove one from New
York City to Vermont.
PostPosted: Mon Aug 20, 2012 7:37 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
George, as a kid, my Mom would always complain about the squirrels
eating the food out of her birdfeeders. I wired one of those things up
using two parallel wires to the birdfeeder tray. I told my Mom to turn
on the switch when she saw the squirrel sitting there pilfering the
seeds and such. That little sucker would go straight up! I mean, do
not pass go! That squirrel launched like an Atlas Rocket!
My Mom loved this.
Of course she didn't love it when I wired the same device up to the
metal studs in the wooden seats used in my Junior High School
auditorium. It had the same effect on a lot of students when I fired it
up during a sports award ceremony. Got suspended for that move ... well
worth it though.
That was the beginning of my career in electronics.
Model T Spark Coil... gotta love it!
Mark
pilko2(at)btinternet.com
PostPosted: Tue Aug 21, 2012 7:57 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
Love the Squirrel launcher !
Brought back memories of an incident in the early 70's when I was a
committed Drag Racer.
In a big headed demonstration of the superior spark produced by my tricked
up 8 cylinder Vertex Scintilla race magneto I gripped it in the bench vice
and attached the power drill to the drive shaft. I then took #1 plug lead
attached a loose spark plug and earthed the plug body to the vice being
careful to hold it with non metallic, insulated fibre plug grips held for
good measure (and effect) in a leather welding gauntlet. Stay with me
here..... 'cos I know you can see it coming. The result was an extremely
impressive vivid blue discharge across the electrodes and this is when I
made the mistake of resting my left uninsulated hand on the all steel bench
top. This would have been a benign event but for the unfortunate coincidence
of HT leads #2 through #8 resting against my right inner leg spanning from
crotch, clothed in Levi 501's with metal studs, to just south of my knee.
My race car could cover quarter mile in just under 10 seconds from a
standing start.... my standing start launch was somewhat faster, Usain Bolt
wouldn't have stood a chance ............
kp
PostPosted: Tue Aug 21, 2012 8:44 am    Post subject: Yak-50 ignition troubleshooting Reply with quote
EXCUSE ME!!!!! But I haven't laughed so hard in a long while!
Jim "Pappy" Goolsby
viperdoc(at)mindspring.co
PostPosted: Tue Aug 21, 2012 3:43 pm    Post subject: Yak-50 ignition troubleshooting Reply with quote
ROFLMAO! Brings back memories of MMO and the neighbors' cat! Hmmm...electrify my garage floor ought really launch that pesky maker of cat tracks on my sports car!
Doc
Little car!
Sent from my iPad
On Aug 21, 2012, at 10:54 AM, "kevin pilling" <pilko2(at)btinternet.com> wrote:
