Posted: Tue Jul 24, 2012 5:51 am Post subject: Resistor for LR3C-14 and CML LED indicator for low voltage |
| Quote: | What I don't know and could use some direction on, is since my LED
module already has built in resistor, which resistor do I add to the
circuit to keep the LED from illuminating at all times? Or do I
still use both? Same values? I have not found a schematic for the
CML device anyplace to help shed any light on the subject.
Just wire a 470 ohm resistor in parallel with your
lamp fixture. It's not terribly important were
that resistor is located . . . it can be inside
across the LED or across the LED-resistor string
inside your fixture.
pmnewlon
Posted: Wed Jul 25, 2012 4:49 am Post subject: Re: Resistor for LR3C-14 and CML LED indicator for low vol |
Thank you Bob!
Radold
Posted: Wed Jul 25, 2012 7:46 am Post subject: Re: Resistor for LR3C-14 and CML LED indicator for low vol |
| pmnewlon wrote: | | Thank you Bob! |
Thanks a lot bob. I followed your advice and my led lights are working perfectly now.
