pilot623(at)gmail.com Guest
Posted: Tue Jul 17, 2012 6:29 pm Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
As one of the few AD Series 2 Pulsar owners, I will add that the Series 2
carries a max gross weight of 1200 pounds.
Jim
_____
[mailto:Pulsar-Aviators(at)yahoogroups.com] On Behalf Of gregsmi(at)aol.com
Sent: Tuesday, July 17, 2012 7:16 PM
To: Pulsar-Aviators(at)yahoogroups.com; pulsar-list(at)matronics.com
Subject: [Pulsar-Aviators] Pulsar weight restrictions
All the discussion on Pulsar gross weights got me back into the manuals,
news letters, and finally discussions with my favorite air craft designer. I
know there has been some confusion about this, and if you have a plane that
was purchased and built in stages, then this can be very confusing. So, here
is the simple explanation.
Early Pulsar kits had a sitka spruce wood spar. Spar caps of unidirectional
glass were added to the top and bottom of the spar for strength. On the
earliest wood spars, the spar caps did not go all the way to the wing tip.
The gross weight of a Pulsar built with these spars is 870 pounds. Latter in
the program, the spar caps were extended to almost the wing tip. With that,
the gross weight was upped to 900 pounds. 900 pounds is the max for the wood
spar. This is exactly as stated by Alan Gill for Pulsar aircraft in the UK.
Later Pulsars had the composite spar and gross weight was increased to 1060
pounds.
Please note, gross weight limitation is solely determined by the spar
material and spar caps. Composite wing skins and added glass to the spar
sides does not increase the max gross weight.
I have looked in the Skystar manuals and not found the numbers for their
aircraft, so will limit my comments to the Aerodesigns kits.
Flying an airplane over it's design limit is like driving a car, with smooth
tires, at high speed on a wet surface. You may get away with it, until you
hit a puddle, or in our case, turbulence. Turbulence adds G loading, and if
you are over design limits, the wing could fail, not a good situation.
Needless to say, this is a major safety issue, and thus my concern. If you
have any questions about this, please get back to me and I will try to get
an answer for you.
Fly safe,
See you at Oshkosh,
Greg
Jabiru 2200 Pulsar
1500 hours
__._,_.___
Reply
<mailto:GREGSMI(at)aol.com?subject=Re%3A%20Pulsar%20weight%20restrictions> to
sender | Reply
<mailto:Pulsar-Aviators(at)yahoogroups.com?subject=Re%3A%20Pulsar%20weight%20re
strictions> to group | Reply
<http://groups.yahoo.com/group/Pulsar-Aviators/post;_ylc=X3oDMTJxNm85cDY1BF9
TAzk3MzU5NzE0BGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRtc2dJZAM0MDE0BHN
lYwNmdHIEc2xrA3JwbHkEc3RpbWUDMTM0MjU3MDU0OA--?act=reply&messageNum=4014> via
web post | Start
<http://groups.yahoo.com/group/Pulsar-Aviators/post;_ylc=X3oDMTJmb25hM3Y3BF9
TAzk3MzU5NzE0BGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZnRyBHNsawN
udHBjBHN0aW1lAzEzNDI1NzA1NDg-> a New Topic
Messages
<http://groups.yahoo.com/group/Pulsar-Aviators/message/4014;_ylc=X3oDMTM1ZXZ
hNXV2BF9TAzk3MzU5NzE0BGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRtc2dJZAM
0MDE0BHNlYwNmdHIEc2xrA3Z0cGMEc3RpbWUDMTM0MjU3MDU0OAR0cGNJZAM0MDE0> in this
topic (1)
Recent Activity:
* New
<http://groups.yahoo.com/group/Pulsar-Aviators/members;_ylc=X3oDMTJndDFmdnJ1
BF9TAzk3MzU5NzE0BGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDdnRsBHNs
awN2bWJycwRzdGltZQMxMzQyNTcwNTQ4?o=6> Members 1
Visit
<http://groups.yahoo.com/group/Pulsar-Aviators;_ylc=X3oDMTJmMXFzbTc0BF9TAzk3
MzU5NzE0BGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDdnRsBHNsawN2Z2hw
BHN0aW1lAzEzNDI1NzA1NDg-> Your Group
<http://groups.yahoo.com/;_ylc=X3oDMTJldmNzOWp0BF9TAzk3NDc2NTkwBGdycElkAzEzM
DMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZnRyBHNsawNnZnAEc3RpbWUDMTM0MjU3MDU0O
A--> Yahoo! Groups
Switch to: Text-Only
<mailto:Pulsar-Aviators-traditional(at)yahoogroups.com?subject=Change Delivery
Format: Traditional> , Daily
<mailto:Pulsar-Aviators-digest(at)yahoogroups.com?subject=Email Delivery:
Digest> Digest . Unsubscribe
<mailto:Pulsar-Aviators-unsubscribe(at)yahoogroups.com?subject=Unsubscribe> .
Terms of Use <http://docs.yahoo.com/info/terms/>
bernard.wilder2(at)gmail. Guest
Posted: Wed Jul 18, 2012 3:58 am Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
This series I,,II,,III,, or whatever always confused me. Aero Designs sold
a "Pulsar". Then a "Pulsar XP". Then a "Turbo Pulsar".
I have kit number 390- - - a Pulsar XP - with a composite spar fast build
wing kit. I haven't the slighterst idea whether it is a I,, II ,,, III or
whatever. Don't really care. As sold to me, it was and remains a "Pulsar
XP", not a series I,, II,,,or III..
I am away from home right now so I can't refer to my files but I seem to
remember that the gross weight that I was given was less than 1,200 - - - -
around 1,100 something.
I suspect that the records don't exist but the most helpful way to address
the issue of the evolujtion of gross weights would be to do it by kit
number if it is an Aero Designs kit. After that Pulsars could be
identified by a series number given to them by the new owners but to give
Aero Designs produced kits a series number is like putting tits on a boar.
Happy flying to all in whatever it is ! ! ! ! ! !
Bernie Wilder
On Tue, Jul 17, 2012 at 10:27 PM, pilot623 <pilot623(at)gmail.com> wrote:
[quote] **
Jim
Pulsar-Aviators(at)yahoogroups.com] *On Behalf Of *gregsmi(at)aol.com
*Sent:* Tuesday, July 17, 2012 7:16 PM
*To:* Pulsar-Aviators(at)yahoogroups.com; pulsar-list(at)matronics.com
*Subject:* [Pulsar-Aviators] Pulsar weight restrictions
Posted: Wed Jul 18, 2012 5:27 am Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
Hi Bernie ,
The various designations have always confused me but my kit from AD was definitely billed as a Series 2. The AD turbo pulsar demomstrator was a Series 2 with a 914.
Jim
Sent from my Android
Bernard Wilder <bernard.wilder2(at)gmail.com> wrote:
| Quote: | This series I,,II,,III,, or whatever always confused me. Aero Designs sold
Bernie Wilder
> Jim
> *From:* Pulsar-Aviators(at)yahoogroups.com [mailto:
> I know there has been some confusion about this, and if you have a plane
> that was purchased and built in stages, then this can be very confusing.
> So, here is the simple explanation.
> unidirectional glass were added to the top and bottom of the spar for
> strength. On the earliest wood spars, the spar caps did not go all the way
> to the wing tip. The gross weight of a Pulsar built with these spars is 870
> pounds. Latter in the program, the spar caps were extended to almost the
> wing tip. With that, the gross weight was upped to 900 pounds. 900 pounds
> is the max for the wood spar. This is exactly as stated by Alan Gill for
> 1060 pounds.
> smooth tires, at high speed on a wet surface. You may get away with it,
> until you hit a puddle, or in our case, turbulence. Turbulence adds G
> loading, and if you are over design limits, the wing could fail, not a good
> situation.
> an answer for you.
> Fly safe,
> See you at Oshkosh,
> Greg
> Jabiru 2200 Pulsar
> 1500 hours
> __._,_.___
> Reply to sender<GREGSMI(at)aol.com?subject=Re%3A%20Pulsar%20weight%20restrictions>| Reply
> to group<Pulsar-Aviators(at)yahoogroups.com?subject=Re%3A%20Pulsar%20weight%20restrictions>| Reply
> via web post<http://groups.yahoo.com/group/Pulsar-Aviators/post;_ylc=X3oDMTJxNm85cDY1BF9TAzk3MzU5NzE0BGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRtc2dJZAM0MDE0BHNlYwNmdHIEc2xrA3JwbHkEc3RpbWUDMTM0MjU3MDU0OA--?act=reply&messageNum=4014>| Start
> a New Topic<http://groups.yahoo.com/group/Pulsar-Aviators/post;_ylc=X3oDMTJmb25hM3Y3BF9TAzk3MzU5NzE0BGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZnRyBHNsawNudHBjBHN0aW1lAzEzNDI1NzA1NDg->
> Messages in this topic<http://groups.yahoo.com/group/Pulsar-Aviators/message/4014;_ylc=X3oDMTM1ZXZhNXV2BF9TAzk3MzU5NzE0BGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRtc2dJZAM0MDE0BHNlYwNmdHIEc2xrA3Z0cGMEc3RpbWUDMTM0MjU3MDU0OAR0cGNJZAM0MDE0>(
> 1)
> Recent Activity:
> - New Members<http://groups.yahoo.com/group/Pulsar-Aviators/members;_ylc=X3oDMTJndDFmdnJ1BF9TAzk3MzU5NzE0BGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDdnRsBHNsawN2bWJycwRzdGltZQMxMzQyNTcwNTQ4?o=6>
> 1
> Visit Your Group<http://groups.yahoo.com/group/Pulsar-Aviators;_ylc=X3oDMTJmMXFzbTc0BF9TAzk3MzU5NzE0BGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDdnRsBHNsawN2Z2hwBHN0aW1lAzEzNDI1NzA1NDg->
> [image: Yahoo! Groups]<http://groups.yahoo.com/;_ylc=X3oDMTJldmNzOWp0BF9TAzk3NDc2NTkwBGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZnRyBHNsawNnZnAEc3RpbWUDMTM0MjU3MDU0OA-->
> Switch to: Text-Only<Pulsar-Aviators-traditional(at)yahoogroups.com?subject=Change+Delivery+Format:+Traditional>,
> Daily Digest<Pulsar-Aviators-digest(at)yahoogroups.com?subject=Email+Delivery:+Digest>•
> Unsubscribe<Pulsar-Aviators-unsubscribe(at)yahoogroups.com?subject=Unsubscribe>• Terms
> __,_._,___
barrynorman(at)comcast.ne Guest
Posted: Wed Jul 18, 2012 5:46 am Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
It's also 1200 for the Series III. Not sure if there was any difference in spar design from the II to the III. I know the Series III was heavier, mine came in at 711 with a 912 and a bit heavier for those that had the 914. I can't fly mine under 1200 pounds gross with full fuel, my wife and I and 60 pounds of luggage. That puts it at 1320.
Barry
To: Pulsar-Aviators(at)yahoogroups.com, pulsar-list(at)matronics.com
Sent: Tuesday, July 17, 2012 10:27:23 PM
Subject: RE: [Pulsar-Aviators] Pulsar weight restrictions
.MsgBody-text, .MsgBody-text * { font: 10pt monospace; } As one of the few AD Series 2 Pulsar owners, I will add that the Series 2 carries a max gross weight of 1200 pounds.
Jim
| Quote: | From: Pulsar-Aviators(at)yahoogroups.com [mailto:Pulsar-Aviators(at)yahoogroups.com] On Behalf Of gregsmi(at)aol.com
All the discussion on Pulsar gross weights got me back into the manuals, news letters, and finally discussions with my favorite air craft designer. I know there has been some confusion about this, and if you have a plane that was purchased and built in stages, then this can be very confusing. So, here is the simple explanation.
Early Pulsar kits had a sitka spruce wood spar. Spar caps of unidirectional glass were added to the top and bottom of the spar for strength. On the earliest wood spars, the spar caps did not go all the way to the wing tip. The gross weight of a Pulsar built with these spars is 870 pounds. Latter in the program, the spar caps were extended to almost the wing tip. With that, the gross weight was upped to 900 pounds. 900 pounds is the max for the wood spar. This is exactly as stated by Alan Gill for Pulsar aircraft in the UK.
Later Pulsars had the composite spar and gross weight was increased to 1060 pounds.
Please note, gross weight limitation is solely determined by the spar material and spar caps. Composite wing skins and added glass to the spar sides does not increase the max gross weight.
I have looked in the Skystar manuals and not found the numbers for their aircraft, so will limit my comments to the Aerodesigns kits.
Flying an airplane over it's design limit is like driving a car, with smooth tires, at high speed on a wet surface. You may get away with it, until you hit a puddle, or in our case, turbulence. Turbulence adds G loading, and if you are over design limits, the wing could fail, not a good situation.
Needless to say, this is a major safety issue, and thus my concern. If you have any questions about this, please get back to me and I will try to get an answer for you.
Fly safe,
See you at Oshkosh,
Greg
Jabiru 2200 Pulsar
1500 hours
__._,_.___
Reply to sender ([email]GREGSMI(at)aol.com?subject=Re%3A%20Pulsar%20weight%20restrictions[/email]) | Reply to group ([email]Pulsar-Aviators(at)yahoogroups.com?subject=Re%3A%20Pulsar%20weight%20restrictions[/email]) | Reply via web post | Start a New Topic
Messages in this topic (1)
Recent Activity: Visit Your Group
Text-Only ([email]Pulsar-Aviators-traditional(at)yahoogroups.com?subject=Change Delivery Format: Traditional[/email]), Daily Digest ([email]Pulsar-Aviators-digest(at)yahoogroups.com?subject=Email Delivery: Digest[/email]) • Unsubscribe ([email]Pulsar-Aviators-unsubscribe(at)yahoogroups.com?subject=Unsubscribe[/email]) • Terms of Use
[img]http://geo.yahoo.com/serv?s=97359714/grpId=13031253/grpspId=1705786083/msgId=4014/stime=1342570548/nc1=4507179/nc2=3848614/nc3=4767085[/img]
__,_._,___
| #ygrp-mkp { BORDER-BOTTOM: #d8d8d8 1px solid; BORDER-LEFT: #d8d8d8 1px solid; PADDING-BOTTOM: 0px; MARGIN: 10px 0px; PADDING-LEFT: 10px; PADDING-RIGHT: 10px; FONT-FAMILY: Arial; BORDER-TOP: #d8d8d8 1px solid; BORDER-RIGHT: #d8d8d8 1px solid; PADDING-TOP: 0px } #ygrp-mkp HR { BORDER-BOTTOM: #d8d8d8 1px solid; BORDER-LEFT: #d8d8d8 1px solid; BORDER-TOP: #d8d8d8 1px solid; BORDER-RIGHT: #d8d8d8 1px solid } #ygrp-mkp #hd { LINE-HEIGHT: 122%; MARGIN: 10px 0px; COLOR: #628c2a; FONT-SIZE: 85%; FONT-WEIGHT: 700 } #ygrp-mkp #ads { MARGIN-BOTTOM: 10px } #ygrp-mkp .ad { PADDING-BOTTOM: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px } #ygrp-mkp .ad P { MARGIN: 0px } #ygrp-mkp .ad A { COLOR: #0000ff; TEXT-DECORATION: none } #ygrp-sponsor #ygrp-lc { FONT-FAMILY: Arial } #ygrp-sponsor #ygrp-lc #hd { LINE-HEIGHT: 122%; MARGIN: 10px 0px; FONT-SIZE: 78%; FONT-WEIGHT: 700 } #ygrp-sponsor #ygrp-lc .ad { PADDING-BOTTOM: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; MARGIN-BOTTOM: 10px; PADDING-TOP: 0px } A { COLOR: #1e66ae } #actions { PADDING-BOTTOM: 10px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; FONT-FAMILY: Verdana; FONT-SIZE: 11px; PADDING-TOP: 10px } #activity { PADDING-BOTTOM: 10px; BACKGROUND-COLOR: #e0ecee; PADDING-LEFT: 10px; PADDING-RIGHT: 10px; FONT-FAMILY: Verdana; FLOAT: left; FONT-SIZE: 10px; PADDING-TOP: 10px } #activity SPAN { FONT-WEIGHT: 700 } #activity SPAN:first-child { TEXT-TRANSFORM: uppercase } #activity SPAN A { COLOR: #5085b6; TEXT-DECORATION: none } #activity SPAN SPAN { COLOR: #ff7900 } #activity SPAN .underline { TEXT-DECORATION: underline } .attach { PADDING-BOTTOM: 10px; PADDING-LEFT: 0px; WIDTH: 400px; PADDING-RIGHT: 0px; DISPLAY: table; FONT-FAMILY: Arial; CLEAR: both; FONT-SIZE: 12px; PADDING-TOP: 10px } .attach DIV A { TEXT-DECORATION: none } .attach IMG { BORDER-BOTTOM-STYLE: none; BORDER-LEFT-STYLE: none; PADDING-RIGHT: 5px; BORDER-TOP-STYLE: none; BORDER-RIGHT-STYLE: none } .attach LABEL { DISPLAY: block; MARGIN-BOTTOM: 5px } .attach LABEL A { TEXT-DECORATION: none } BLOCKQUOTE { MARGIN: 0px 0px 0px 4px } .bold { FONT-FAMILY: Arial; FONT-SIZE: 13px; FONT-WEIGHT: 700 } .bold A { TEXT-DECORATION: none } DD.last P A { FONT-FAMILY: Verdana; FONT-WEIGHT: 700 } DD.last P SPAN { FONT-FAMILY: Verdana; FONT-WEIGHT: 700; MARGIN-RIGHT: 10px } DD.last P SPAN.yshortcuts { MARGIN-RIGHT: 0px } DIV.attach-table DIV DIV A { TEXT-DECORATION: none } DIV.attach-table { WIDTH: 400px } DIV.file-title A { TEXT-DECORATION: none } DIV.file-title A:active { TEXT-DECORATION: none } DIV.file-title A:hover { TEXT-DECORATION: none } DIV.file-title A:visited { TEXT-DECORATION: none } DIV.photo-title A { TEXT-DECORATION: none } DIV.photo-title A:active { TEXT-DECORATION: none } DIV.photo-title A:hover { TEXT-DECORATION: none } DIV.photo-title A:visited { TEXT-DECORATION: none } DIV#ygrp-mlmsg #ygrp-msg P A SPAN.yshortcuts { FONT-FAMILY: Verdana; FONT-SIZE: 10px; FONT-WEIGHT: normal } .green { COLOR: #628c2a } .MsoNormal { MARGIN: 0px } o { FONT-SIZE: 0px } #photos DIV { WIDTH: 72px; FLOAT: left } #photos DIV DIV { BORDER-BOTTOM: #666666 1px solid; BORDER-LEFT: #666666 1px solid; WIDTH: 62px; HEIGHT: 62px; OVERFLOW: hidden; BORDER-TOP: #666666 1px solid; BORDER-RIGHT: #666666 1px solid } #photos DIV LABEL { TEXT-ALIGN: center; WIDTH: 64px; WHITE-SPACE: nowrap; COLOR: #666666; FONT-SIZE: 10px; OVERFLOW: hidden } #reco-category { FONT-SIZE: 77% } #reco-desc { FONT-SIZE: 77% } .replbq { MARGIN: 4px } #ygrp-actbar DIV A:first-child { PADDING-RIGHT: 5px; MARGIN-RIGHT: 2px } #ygrp-mlmsg { FONT-FAMILY: Arial, helvetica,clean, sans-serif; FONT-SIZE: small } #ygrp-mlmsg TABLE { } #ygrp-mlmsg SELECT { FONT: 99% Arial, Helvetica, clean, sans-serif } INPUT { FONT: 99% Arial, Helvetica, clean, sans-serif } TEXTAREA { FONT: 99% Arial, Helvetica, clean, sans-serif } #ygrp-mlmsg PRE { FONT: 100% monospace } CODE { FONT: 100% monospace } #ygrp-mlmsg * { LINE-HEIGHT: 1.22em } #ygrp-mlmsg #logo { PADDING-BOTTOM: 10px } #ygrp-mlmsg A { COLOR: #1e66ae } #ygrp-msg P A { FONT-FAMILY: Verdana } #ygrp-msg P#attach-count SPAN { COLOR: #1e66ae; FONT-WEIGHT: 700 } #ygrp-reco #reco-head { COLOR: #ff7900; FONT-WEIGHT: 700 } #ygrp-reco { PADDING-BOTTOM: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; MARGIN-BOTTOM: 20px; PADDING-TOP: 0px } #ygrp-sponsor #ov LI A { FONT-SIZE: 130%; TEXT-DECORATION: none } #ygrp-sponsor #ov LI { PADDING-BOTTOM: 6px; LIST-STYLE-TYPE: square; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; FONT-SIZE: 77%; PADDING-TOP: 6px } #ygrp-sponsor #ov UL { PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-LEFT: 8px; PADDING-RIGHT: 0px; PADDING-TOP: 0px } #ygrp-text { FONT-FAMILY: Georgia } #ygrp-text P { MARGIN: 0px 0px 1em } #ygrp-text TT { FONT-SIZE: 120% } #ygrp-vital UL LI:unknown { BORDER-RIGHT-STYLE: none !important } [quote]
arget=_blank>http://www.matronics.com/Navigator?Pulsar-List
p://forums.matronics.com
Posted: Wed Jul 18, 2012 6:37 am Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
Series III is also 1200 max gross weight.
Barry
Jim
Fly safe,
See you at Oshkosh,
Greg
Jabiru 2200 Pulsar
1500 hours
__._,_.___
__,_._,___
briana(at)xtra.co.nz Guest
Posted: Wed Jul 18, 2012 12:27 pm Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
Bernie et al,
Mine is kit #456. It was one of the later kits produced by Aero Designs, designated Pulsar XP, composite spars, composite wing skins, and supplied in the kit were hydraulic brakes.
The documentation specifies MAUW 1060 lbs.
Brian
On 18/07/2012, at 11:50 PM, Bernard Wilder wrote:
[quote]This series I,,II,,III,, or whatever always confused me. Aero Designs sold a "Pulsar". Then a "Pulsar XP". Then a "Turbo Pulsar".
I have kit number 390- - - a Pulsar XP - with a composite spar fast build wing kit. I haven't the slighterst idea whether it is a I,, II ,,, III or whatever. Don't really care. As sold to me, it was and remains a "Pulsar XP", not a series I,, II,,,or III..
I am away from home right now so I can't refer to my files but I seem to remember that the gross weight that I was given was less than 1,200 - - - - around 1,100 something.
I suspect that the records don't exist but the most helpful way to address the issue of the evolujtion of gross weights would be to do it by kit number if it is an Aero Designs kit. After that Pulsars could be identified by a series number given to them by the new owners but to give Aero Designs produced kits a series number is like putting tits on a boar.
Bernie Wilder
On Tue, Jul 17, 2012 at 10:27 PM, pilot623 <pilot623(at)gmail.com (pilot623(at)gmail.com)> wrote:
| Quote: | As one of the few AD Series 2 Pulsar owners, I will add that the Series 2 carries a max gross weight of 1200 pounds.
Jim
| Quote: | From: Pulsar-Aviators(at)yahoogroups.com (Pulsar-Aviators(at)yahoogroups.com) [mailto:Pulsar-Aviators(at)yahoogroups.com (Pulsar-Aviators(at)yahoogroups.com)] On Behalf Of gregsmi(at)aol.com (gregsmi(at)aol.com)
To: Pulsar-Aviators(at)yahoogroups.com (Pulsar-Aviators(at)yahoogroups.com); pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Fly safe,
See you at Oshkosh,
Greg
Jabiru 2200 Pulsar
1500 hours
__._,_.___
Text-Only ([email]Pulsar-Aviators-traditional(at)yahoogroups.com?subject=Change+Delivery+Format:+Traditional[/email]), Daily Digest ([email]Pulsar-Aviators-digest(at)yahoogroups.com?subject=Email+Delivery:+Digest[/email]) • Unsubscribe ([email]Pulsar-Aviators-unsubscribe(at)yahoogroups.com?subject=Unsubscribe[/email]) • Terms of Use
__,_._,___
arget="_blank">http://www.matronics.com/Navigator?Pulsar-List
ttp://forums.matronics.com
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronics.com/Navigator?Pulsar-List
| [b]
Posted: Wed Jul 18, 2012 1:32 pm Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
Jim,
Doesn't your plane have the cooling intakes in the wings ? ? ? ? ?
I thought that was a Sky Star innovation.
Now II am really confused.
Bernie Wilder
On Wed, Jul 18, 2012 at 9:26 AM, Jim Fillman <pilot623(at)gmail.com> wrote:
[quote] Hi Bernie ,
Jim
Posted: Wed Jul 18, 2012 1:35 pm Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
Barry,
Who did you buy your kit from ? ? ? ? ? Aero Designs or Sky Star.
Did antbody buy a kit from Soley ? ? ? ? ? ?
Bernie Wilder
On Wed, Jul 18, 2012 at 9:45 AM, <barrynorman(at)comcast.net> wrote:
[quote] It's also 1200 for the Series III. Not sure if there was any difference
Barry
*To: *Pulsar-Aviators(at)yahoogroups.com, pulsar-list(at)matronics.com
*Sent: *Tuesday, July 17, 2012 10:27:23 PM
*Subject: *RE: [Pulsar-Aviators] Pulsar weight restrictions
Jim
rwilhelm(at)dc.rr.com Guest
Posted: Wed Jul 18, 2012 1:47 pm Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
They III has the cooler intakes at the wing roots only if you installed a
Rotax.
Ray Pulsar III/JAB3300
[mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of Bernard Wilder
Sent: Wednesday, July 18, 2012 2:29 PM
Subject: Re: RE: [Pulsar-Aviators] Pulsar weight restrictions
Jim,
Bernie Wilder
Hi Bernie ,
Jim
Bernie Wilder
Jim
_____
pounds.
an answer for you.
Fly safe,
See you at Oshkosh,
Greg
Jabiru 2200 Pulsar
1500 hours
__._,_.___
Reply to
sender | Reply to
strictions> group | Reply
web post |
udHBjBHN0aW1lAzEzNDI1NzA1NDg-> Start a New Topic
0MDE0BHNlYwNmdHIEc2xrA3Z0cGMEc3RpbWUDMTM0MjU3MDU0OAR0cGNJZAM0MDE0> (1)
Recent Activity:
ghf4986(at)gmail.com Guest
Posted: Wed Jul 18, 2012 2:10 pm Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
Brian,
My kit is an XP number 464 and has the same 1060 load limit. I believe
this is one of the very last AD Pulsars shipped.
Dennis
On Wed, Jul 18, 2012 at 2:24 PM, Brian Anderson <briana(at)xtra.co.nz> wrote:
[quote] Bernie et al,
Brian
Posted: Wed Jul 18, 2012 3:24 pm Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
You have a very good memory. I incorporated several Skystar Series 3
improvements into my AD Series 2 including the wing root air inlets and I
used a Skystar FWF package. That's why I often refer to my plane as a Series
2.75.
Jim
_____
Sent: Wednesday, July 18, 2012 4:29 PM
Jim,
Bernie Wilder
Hi Bernie ,
Jim
Bernie Wilder
Jim
_____
pounds.
an answer for you.
Fly safe,
See you at Oshkosh,
Greg
Jabiru 2200 Pulsar
1500 hours
__._,_.___
Reply to
sender | Reply to
Recent Activity:
* New Members
awN2bWJycwRzdGltZQMxMzQyNTcwNTQ4?o=6> 1
Visit Your Group
A--> Yahoo! Groups
<mailto:Pulsar-Aviators-traditional(at)yahoogroups.com?subject=Change+Delivery+
Format:+Traditional> , Daily Digest
<mailto:Pulsar-Aviators-digest(at)yahoogroups.com?subject=Email+Delivery:+Diges
t> . Unsubscribe
Terms of <http://docs.yahoo.com/info/terms/> Use
Posted: Thu Jul 19, 2012 5:19 am Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
My kit came from Skystar, kit number 563.
Barry
From: "Bernard Wilder" <bernard.wilder2(at)gmail.com>
Sent: Wednesday, July 18, 2012 5:32:59 PM
Barry,
Bernie Wilder
On Wed, Jul 18, 2012 at 9:45 AM, <barrynorman(at)comcast.net (barrynorman(at)comcast.net)> wrote:
Barry
From: "pilot623" <pilot623(at)gmail.com (pilot623(at)gmail.com)>
To: Pulsar-Aviators(at)yahoogroups.com (Pulsar-Aviators(at)yahoogroups.com), pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Jim
Fly safe,
See you at Oshkosh,
Greg
Jabiru 2200 Pulsar
1500 hours
__._,_.___
__,_._,___
gregsmi
Posted: Thu Jul 19, 2012 1:09 pm Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
I got another update on the series II. Bob Bye has s/n 505. Gross is 1200.
He says the vertical tail is 6 inches longer than the series I. It also has
the removable bottom cowl and larger wing tanks. But, as noted
by others, the empty weight is 630 pounds. Bob has installed a Jabiru 2200
and loves it, has over 200 hours of flying fun.
Greg
In a message dated 7/18/2012 6:25:41 P.M. Central Daylight Time,
pilot623(at)gmail.com writes:
improvements into my AD Series 2 including the wing root air inlets and I used a
Skystar FWF package. That's why I often refer to my plane as a Series 2.75
Posted: Thu Jul 19, 2012 6:49 pm Post subject: [Pulsar-Aviators] Pulsar weight restrictions |
I got the kit right after Bob, S/N 506
Jim
_____
[mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of GREGSMI(at)aol.com
Sent: Thursday, July 19, 2012 4:09 PM
Greg
2.75.
Jim
_____
Jim,
Bernie Wilder
Hi Bernie ,
Jim
Bernie Wilder
Jim
_____
pounds.
an answer for you.
Fly safe,
See you at Oshkosh,
Greg
Jabiru 2200 Pulsar
1500 hours
__._,_.___
Reply to
sender | Reply to
Recent Activity:
* New Members
Visit Your Group
A--> Yahoo! Groups
t> . Unsubscribe
