freefolk(at)screaming.net Guest
Posted: Fri May 19, 2006 12:43 am Post subject: Nosewheel Shimmy |
The current high winds in the UK remind me of the problem which has =
occurred to me twice this year after a crosswind departure from home =
base (Old Sarum - a fairly bumpy grass airfield) with a subsequent =
landing on a hard runway without significant crosswind. Having =
taken-off with a 15-25 knot crosswind (from the right in both cases - =
the "best" side), severe nosewheel shimmy was encountered on landing, =
which continued until the aircraft was brought to rest. Not pleasant =
waiting for something to break, and unable to do anything about it. =
Fortunately no damage on either occasion. Has anyone else encountered =
this problem, and is there a remedy? The friction on the (so called) =
shimmy damper was checked as between 8-9 Kgs on both occasions. Ian =
Rickard has suggested that I reduce friction to around 5-6 Kgs in the =
hope that slipstream will straighten the nosewheel in flight from any =
inadvertant sidethrust imparted during rotation.
Brian Tarmar
G-OBJT 055 Classic Trigear, 912S/Warpdrive and XS front/mods
65 hours and still smiling when it ain't shimmying!
rholder(at)avnet.co.uk Guest
Posted: Fri May 19, 2006 1:14 am Post subject: Nosewheel Shimmy |
Brian and Pat Tarmar wrote:
| Quote: | The current high winds in the UK remind me of the
problem which has occurred to me twice this year after
a crosswind departure from home base (Old Sarum - a
fairly bumpy grass airfield) with a subsequent landing
in both cases - the "best" side), severe nosewheel
shimmy was encountered on landing, which continued
anything about it. Fortunately no damage on either
occasion. Has anyone else encountered this problem, and
occasions. Ian Rickard has suggested that I reduce
friction to around 5-6 Kgs in the hope that slipstream
| Quote: | Brian Tarmar G-OBJT 055 Classic Trigear,
912S/Warpdrive and XS front/mods 65 hours and still
I would say the opposite ! The shimmy is the nosewheel
moving from side to side on the ground when landing. Any
deflection from central on take-off may make the first
shimmy movement but once the oscillation starts looseness
of the damper will actually make it worse.
I would suggest tightening up the "big nut" one flat and
trying it again. Maybe two flats. If it is too tight it
will not want to steer on the ground (but it won't shimmy !)
I took mine apart on my annual and found that there were a
lot of grooves in the plastic (damping) disc and there was
some cr*p in there as well. I cleaned it all up, including
the metal surfaces and then I turned the plastic disc over
to give me a new smooth surface. I had it tight before and
the movement was in jerks. Now it is very smooth, and no
shimmy. And it steers on the ground (most of the time !)
G-OWWW is exactly the same as yours - Classic Tri-Gear, XS
FWF, 912S but I have an Airmaster.
Richard
peter.rees01(at)tiscali.c Guest
Posted: Fri May 19, 2006 1:45 am Post subject: Nosewheel Shimmy |
I have to agree with Richard
Our nose wheel damper seems to requrie fairly regular checking and tightening
- when it gets a little loose, we do get a bit of shimmy - that said, we've
been flying out of rochester (grass) and landing at hard runways with the
friction as low as about 3kg with very little discernable shimmy.
Don't know if you have to do anything about balancing the wheel in any way
| Quote: | -- Original Message --
Date: Fri, 19 May 2006 10:11:56 +0100
Subject: Re: Nosewheel Shimmy
Reply-To: europa-list(at)matronics.com
Richard
___________________________________________________________
Tiscali Broadband from 14.99 with free setup!
http://www.tiscali.co.uk/products/broadband/
Hi! Brian
IMHO increase the shimmy damper load to 12kg and take off with the stick
held back to get the nose "flying" as early as possible. On Landing keep
the stick back and so reduce the weight on the nose wheel even at slow
speeds it reduces the weight on the wheel which has to be good news for
it.
My take off procedure is always to set up the line by differential
braking then simultaneously hit full right rudder as you hit full
throttle to keep the take off line. Only very rarely is the right rudder
relaxed during the entire take off run and I can never remember
requiring any left rudder in fact I take up the attitude that I have
only one leg.(this is with right hand tractor prop wash)
Bob Harrison G-PTAG Europa MKI/Jabiru 3300
ward.t(at)xtra.co.nz Guest
Posted: Fri May 19, 2006 5:01 pm Post subject: Nosewheel Shimmy |
Solution;
Conversion kit to convert to the wonderful Monowheel!!!!
Sorry, couldn't help myself, no offense.
Cheers,
From: "Brian and Pat Tarmar" <freefolk(at)screaming.net>
Date: 2006/05/19 Fri PM 08:37:42 GMT+12:00
Subject: Nosewheel Shimmy
Brian Tarmar
Tim Ward
12 Waiwetu Street
Fendalton
Christchurch.
Ph. 0064 33515166
jrm03(at)bigpond.com Guest
Posted: Fri May 26, 2006 2:11 am Post subject: Nosewheel Shimmy |
Thank you Steve for the info. on DAMPING GREASE. Several of us in OZ will
have some grease in a few days.
Could you please advise if you still use the recommended 8-9 kg dampening
stiffness with the grease or is some other
figure more suitable
John Moore # 142
Posted: Thu Jun 01, 2006 12:21 am Post subject: Nosewheel Shimmy |
Thanks to the words of Steve Vestuti on this forum last week I believe =
we may have cured the nosewheel shimmy experienced on hard runways. The =
British agent for Nye Lubricants Inc, (www.newgatesimms.co.uk) was =
extremely helpful and sent two 50grm pots of damping grease for me to =
try. I decided to use the less thick of the two (NYE NYOGEL 767A) first =
and coated both the shaft and washer. Test flying in a quartering 15kts =
crosswind with high touchdown speed resulted in no shimmy, and best of =
all the braking required to turn had been reduced to light fingertip =
pressure and accuracy of control never before experienced. Lubricating =
the "friction" washer naturally make it impossible to achieve 8-9kgs of =
static friction before the nosewheel turned, but by cranking the shaft =
nut up more than before (Bob you are making me nervous now!!) I achieved =
a "snatch" value on the spring balance of 8 kg and 2kgs before the wheel =
started to move with a steady pull. I now intend experimenting with NYE =
PG44A grease which is the thickest grease in their range, in the hope =
that the shaft nut can be backed off some for the same friction figures.
My thanks to Steve for introducing me to damping grease, a subject I had =
never heard of previously. =20
and to Bob Harrison - sorry to hear about the lost nosewheel and =
consequent damage. Roll pins never did get my vote.
Brian Tarmar G-OBJT Classic Trigear XS Front 912S=20
75 hours and smile fast returning
