sarg314(at)gmail.com Guest
Posted: Tue Jul 10, 2012 10:11 pm Post subject: testing static system |
I've read a lot about static system tests, but how do you do it exactly? I assume I tape up one static port and then attach ... what to the other one? How do I temporarily bond a vinyl tube to a static port with no leaks? RTV?
Tom Sargent, RV-6A
vanremog(at)aol.com Guest
Posted: Tue Jul 10, 2012 10:52 pm Post subject: testing static system |
Window mastic works well.
-GV
Posted: Wed Jul 11, 2012 3:23 am Post subject: testing static system |
I put a test fitting in mine that I connect one of those JC Whitney brake bleeder vacuum gizmos to.
I tape over both static fittings....
wstucklen1(at)cox.net Guest
Posted: Wed Jul 11, 2012 3:41 am Post subject: testing static system |
Tom,
The best way to test the static system is by using a small automotive hand vacuum pump (like the ones used to test carburetors). Sears used to carry these as well as most of the auto parts stores. The vacuum pump comes with a variety of fittings, including a suction cup that can be put directly over the static port. Tape the opposite side static port off first, then apply a suction (not over 1000’ indicated on the altimeter) to the other side. The static system should be able to hold the altitude within 100’ for over a minute.
One of the problems you might run into is suction leakage from around the static port – between the static port and the skin. I had to apply a silicone seal on the inside of the skin to avoid this issue.
All other leaks can usually be found around other fittings within the static system. When I can’t get a leak-free system, I find that breaking the static line such that I isolate the rear of the aircraft from the front area, it’s easier to isolate the problem to specific areas.
Fred Stucklen
RV-7A N924RV 740 Hrs Flying
RV-6A N926RV 875 Hrs sold
RV-6A N925RV 2008 Hrs Sold
Time:
11:11:58 PM PST US
Subject:
thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> | Quote: | | I've read a lot about static system tests, but how do you do it exactly? I assume I tape up one static port and then attach ... what to the other one? How do I temporarily bond a vinyl tube to a static port with no leaks? RTV? -- | 0
khorton02(at)gmail.com Guest
Posted: Wed Jul 11, 2012 4:52 am Post subject: testing static system |
How do you verify that your test fitting doesn't leak when it is not in use?
Kevin Horton
Kellym
Posted: Wed Jul 11, 2012 4:59 am Post subject: testing static system |
Keep several things in mind. You do not want to pull more than 1000 ft
on your altimeter. Lowering the pressure on the static side without
similar reduction to the pitot puts a pressure on the airspeed
indicator. Also, other than ensuring you have a leak free system, you
cannot certify the static system. You will need to have the system
certified if you want to fly anywhere an encoder is required, like Class
B or controlled airspace above 10,000 ft. It takes a shop with a repair
station license to certify your transponder, encoder and static system.
Doubly so if you want to fly IFR. One of those few items you can't do
for yourself on a homebuilt.
On 7/11/2012 4:40 AM, Fred Stucklen wrote:
Tom,
Checked by AVG - www.avg.com
KCHD |
Posted: Wed Jul 11, 2012 5:08 am Post subject: testing static system |
When I get the official check, they don't use the test port - as they have their own procedure...I didn't know that when I put the test port in.
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Wed Jul 11, 2012 5:33 am Post subject: testing static system |
I didn't do anything fancy.
I went to Fleet Farm (a farm supply store) and got a plastic syringe (the
package said "veterinary use only," and when the kid at the counter said
"what's this going to be used for," I said...."ummm.... Errrrr.... It's for
my dog.... And my cat (I had two sizes because I didn't know what size to
use)... They wouldn't take their pills so I've got some liquid medication. I
felt like a meth dealer).
I also bought some "medical tubing" (which made me look like a heroin
addict) and attached it to the syringe and used safety wire to secure it. I
attached the other end to a piece of the rigid plastic tubing I used in the
pitot/static system (SafeAir system). I also secured that connection with
safety wire, and removed a line from a junction and installed the tubing in
its place. Do not connect it directly to an instrument.
Image here:
http://tinyurl.com/6tjx48v
I taped over the static ports -- use electrical tape because duct tape will
not work... Too pourous.
I similarly plugged the pitot tube and applied a SMALL vacuum to 1,000 feet
and watched the instruments. I reinstalled the line I replaced and then
disconnected another location and repeated the process to check all
instruments.
I had a leak and -- as many others have found -- it was at a fitting at one
of the instruments. The other "leak" was a poor job of plugging the pitot
tube. Both were adjusted and rechecked. Zero change in "altitude."
I used 23.1325 as my guide:
(i) Unpressurized airplanes. Evacuate the static pressure system to a
pressure differential of approximately 1 inch of mercury or to a reading on
the altimeter, 1,000 feet above the aircraft elevation at the time of the
test. Without additional pumping for a period of 1 minute, the loss of
indicated altitude must not exceed 100 feet on the altimeter.
Cost: About $10 and a bad reputation at Fleet Farm.
There's another method -- a manometer -- which you can learn about here:
http://www.iflyez.com/manometer.shtml
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
pdeits(at)comcast.net Guest
Posted: Wed Jul 11, 2012 7:55 am Post subject: testing static system |
Please unsubscribe for now. Thank you very much
