carlmeek(at)gmail.com Guest
Posted: Mon Jul 09, 2012 1:10 am Post subject: Rudder - Sprung? |
Hi,
Is the Europa supposed to have springs on the rudder pedals? Mine don't – they flop around. Doesn't cause a problem for the most part, but it can cause it to flap around in the wind, which can't do it any good.
-Carl.
g-iani(at)ntlworld.com Guest
Posted: Mon Jul 09, 2012 1:48 am Post subject: Rudder - Sprung? |
Carl
The rudder system should have a spring at the forward end of each cable (see CBM 22- . As standard they are not very strong and most owners add some sort of additional stop (strap) for when the aircraft is parked.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Carl Meek
Sent: 09 July 2012 10:08
To: david park
Subject: Rudder - Sprung?
Hi,
-Carl.
craigb(at)onthenet.com.au Guest
Posted: Mon Jul 09, 2012 2:03 am Post subject: Rudder - Sprung? |
There is supposed to be two springs at the end of the tunnel, right next to the engine mount on each side of the tunnel, they connect to the
Arm the cable is attached to and connect to bolts at the end of the side of the foot well pulling forward to tension the cables.
Sent: Monday, July 09, 2012 7:08 PM
To: david park
Hi,
-Carl.
Quote: | http://www.matronics.com/Navigator?Europa-List | 0123456789
Checked by AVG - www.avg.com
07/08/12
ptag.dev(at)talktalk.net Guest
Posted: Mon Jul 09, 2012 2:14 am Post subject: Rudder - Sprung? |
Hi! Carl,
Yes springs are light but centralising to neutral mounted to levers which make up part of the pedal pivot drive shafts in front of the central firewall. See figure 1 of General Arrangement of Rudder Pedals Sketch page 29-9 issue 1.
Of course as one is pushed it returns the other being both attached to cables at the rudder end.
Bob Harrison G-PTAG
To: david park
Hi,
-Carl.
Posted: Mon Jul 09, 2012 2:26 am Post subject: Rudder - Sprung? |
Thanks Bob,
Mine work perfectly in flight, but flop about when your feet are not on them. Definitely no springs what so ever.
-Carl.
From: Bob Harrison <ptag.dev(at)talktalk.net (ptag.dev(at)talktalk.net)>
Reply-To: <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Date: Monday, 9 July 2012 11:13
Subject: RE: Rudder - Sprung?
<![endif]--> <![endif]-->
Hi! Carl,
Bob Harrison G-PTAG
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of Carl Meek
To: david park
Subject: Europa-List: Rudder - Sprung?
Hi,
-Carl.
01234567
8
