IO-540 crankcase breather
carl.froehlich(at)verizon
PostPosted: Sat Jun 30, 2012 1:19 pm    Post subject: IO-540 crankcase breather Reply with quote
All,
I was going to use the same crankcase breather oil separator that I have on the 8A http://www.aircraftspruce.com/catalog/eppages/hboilbreather.php
but then I noted the IO-540 has a huge crankcase breather fitting for a 1” inside diameter hose. The above separator uses 5/8” hose.
This separator works well on the IO-360 in the 8A. Is anyone using this on a IO-540? Does the IO-540 really need a 1” breather hose?
Carl
flysrv10(at)gmail.com
PostPosted: Sun Jul 01, 2012 5:59 am    Post subject: IO-540 crankcase breather Reply with quote
Mine really does not leak without a separator. My overflow tube is right above the exhaust pipe.
Also, there are debates regarding putting the oil byproducts in the breather back into the engine.
Do not archive.
Rob Kermanj
On Jun 30, 2012, at 5:18 PM, "Carl Froehlich" <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
All,
Carl
://www.matronics.com/Navigator?RV10-List
cs.com
matronics.com/contribution
PostPosted: Sun Jul 01, 2012 6:33 am    Post subject: IO-540 crankcase breather Reply with quote
This company’s product came recommended on the Lycoming list and is discussed on VAF:  http://antisplataero.com/
I have an email into them on price for the IO-540 version.
One point to clarify; as I did on the 8A the oil from the separator will be collected in a small can (~6oz), not returned to the engine.  On the 8A, I empty the can every oil change and never had more than a couple of ounces in it – but a couple of ounces less on the belly.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj
Sent: Sunday, July 01, 2012 10:06 AM
Subject: Re: IO-540 crankcase breather
Do not archive.
Rob Kermanj
All,
Carl
===================================://www.matronics.com/Navigator?RV10-List===================================cs.com===================================matronics.com/contribution===================================
Kelly McMullen
PostPosted: Sun Jul 01, 2012 6:43 am    Post subject: IO-540 crankcase breather Reply with quote
Yes, the debates with no data. Everything that comes out the breather started in the engine and will be in just as high concentration there. Folks get confused, thinking the separator somehow concentrates contaminates, or condenses water vapor.
On Sun, Jul 1, 2012 at 7:06 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
rv10rob(at)gmail.com
PostPosted: Sun Jul 01, 2012 10:22 am    Post subject: IO-540 crankcase breather Reply with quote
I don't get any noceable oil out the breather, either.  I run about 8 qts as indicated on the dipstick.
On Sun, Jul 1, 2012 at 7:43 AM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
ttp://forums.matronics.com
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
PostPosted: Sun Jul 01, 2012 3:34 pm    Post subject: IO-540 crankcase breather Reply with quote
I did say that there is a debate Smile
> _blank">http://www.matronics.com/contribution
Rob Kochman
Woodinville, WA
Rob Kermanj
dave.saylor.aircrafters(a
PostPosted: Sun Jul 01, 2012 6:42 pm    Post subject: IO-540 crankcase breather Reply with quote
I just have the standard breather that exits over the exhaust pipe.  I add a quart when it gets to 8.  I clean the belly two or three times a year, which takes about 15 minutes.
I get a drip on the floor if it doesn't fly for a couple weeks--never any more than that.
Dave Saylor
[url=tel:831-750-0284]831-750-0284[/url] CL
1087 hours
On Sun, Jul 1, 2012 at 11:21 AM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
[quote] I don't get any noceable oil out the breather, either.  I run about 8 qts as indicated on the dipstick.
Rob Kochman
Woodinville, WA
nukeflyboy
PostPosted: Tue Jul 03, 2012 1:16 pm    Post subject: Re: IO-540 crankcase breather Reply with quote
I was consistently getting 2-3 drops of oil on the hanger floor where it ran down from the breather tube to the exhaust pipe. I installed Van's breather (slime fighter I think) and it has stopped it completely.
Dave Moore
RV-6 built and sold
RV-10 built and flying
