Posted: Tue May 30, 2006 6:12 pm Post subject: How to add 15kt to cruise speed by adding weight |
I see the same thing in my -4. Put about 100-120 lbs in the back seat
and gain about 10 kts. It is very noticeable. Next time you fly solo,
trim out the plane and look at the level the elevator sits relative to
the HS. Add a passenger and look again. In my plane with a 120lb
passenger, the elevators will be almost level with the HS, but flying
solo they are quite a bit different.
-Mike
martin(at)gbonline.com Guest
Posted: Tue May 30, 2006 6:21 pm Post subject: How to add 15kt to cruise speed by adding weight |
Joe and others,
5 years ago when I first began racing the Air Venture race and others, I
added a lead pig (approx 10 lbs) to the tail area of my RV8 to improve the
CG. I mounted it just aft of the tail wheel in the tail cone. It fit very
nicely and did improve the airspeed. However after a couple hundred hours ,
I noticed that my tailwheel spring rod was bending (taking a set) . I
removed the tail weight and replaced the tailwheel attach rod. I now use a
lead shot bag, 25 lbs strapped to the baggage floor and installed or removed
as needed with a heavy passenger. The speed improvement is about the same
with either of the about the same.
On a separate note: I am getting ready for the Air Venture race this summer
and would encourage all of you who have flying airplanes to particiipate.
Don't worry about not having the fastest airplane. You will learn a lot by
participating and competing with the other guys.
Dick Martin
RV8 N233M
the fast one
pbesing(at)yahoo.com Guest
Posted: Tue May 30, 2006 6:46 pm Post subject: How to add 15kt to cruise speed by adding weight |
I fly my -4 with a 40lb bag of salt in the baggage
compartment (sans passenger of course)...haven't
noticed the speed difference, but it does fly
better...I'll have to check that out.
Paul B esing
time you fly solo,
plane with a 120lb
the HS, but flying
-Mike
jebrick(at)comcast.net Guest
Posted: Tue May 30, 2006 8:09 pm Post subject: How to add 15kt to cruise speed by adding weight |
What are we to make of the speeds that Van gives for solo and gross weights?
About one mph slower at gross, tandem or side-by side.
jb
LessDragProd(at)aol.com Guest
Posted: Tue May 30, 2006 8:35 pm Post subject: How to add 15kt to cruise speed by adding weight |
Van's cruise performance testing is usually done at a 8,000' density
altitude using full throttle and 2500 RPM. (It helps to remove as many variables as
possible when doing performance testing.)
I have used a 7,500' density altitude for my RV-3 performance testing. This
has been a station altitude of 5,500', at times. I have an RMI MicroEncoder
in my RV-3, so I can get a direct readout on density altitude (I believe the
outside air temperature is even corrected for compressibility effects).
Jim Ayers
In a message dated 05/30/2006 9:11:04 PM Pacific Daylight Time,
jebrick(at)comcast.net writes:
jb
Ron Schreck
Joined: 10 Jan 2006 Posts: 94 Location: Gold Hill, NC
Posted: Wed May 31, 2006 3:05 am Post subject: How to add 15kt to cruise speed by adding weight |
I like both Dan and Rick's explanations and throw in a specific example
of a very unstable airplane to illustrate the aft CG phenomnon. I used
to fly an airplane that had the CG well aft of the center of lift (CL).
In this configuration the tail plane needed to produce lift in order to
keep the aircraft level. The advantage of this configuration was that
both the wing and tail plane created lift in most every flight regime
rather than the wing producing lift and the tail plane producing down
force as for a conventionally balance aircraft. This made for some
extremely tight turns and rapid response to control inputs but also made
the aircraft impossible to control by the most experienced pilots.
Solution: Put a computer in charge of stability and let the pilot input
his desires through an electronic input to the computer. Thus you have
fly-by-wire technology and the only way to control an F-16.
Ron Schreck
RV-8 "Miss Izzy"
Gold Hill Airpark, NC
I like Dan's explanation, but will add a bit more.
Specifically, we require the CG to be forward of the center of
lift (CL) in
order to have a stable aircraft (and one whose nose drops when the
wing is
stalled). The closer the CG gets to the CL, the less induced
drag, but the
less stable the plane will be. If the CG should go aft of the CL,
all bets
are off in terms of controllability.
Another e-mail commented on Bonanzas and how their CG moves with
fuel burn.
Whether the CG moves aft with fuel burn should depend on the CG of
the tank
and its fuel relative to the CG of the plane. I fly an A-36
Bonanza, and
when weight is up (hence, realistically, with a CG farther aft
than when
lightly loaded), I have indeed noticed greater pitch sensitivity
after a
long flight. When I plan flights at higher weights, I check my
loading by
calculating CG for zero fuel, just to be on the safe side. For
extra
margin), I try to land with fuller tanks, too.
Rick
A-36, RV-7 in process
khorton01(at)rogers.com Guest
Posted: Wed May 31, 2006 4:14 am Post subject: How to add 15kt to cruise speed by adding weight |
Anyone who is thinking about moving the CG aft by
adding some weight needs to keep two things in mind:
1. The weight should be properly secured. You don't
want it coming loose during turbulence or an off-field
landing and hitting you in the back of the head.
2. Adding weight aft will increase the moment of
inertia on the yaw axis, and this will probably
degrade the spin characteristics. I.e the results
from any spin testing you did without that weight are
now invalid.
Kevin Horton
RV-8 (Finishing Kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
cjensen(at)dts9000.com Guest
Posted: Wed May 31, 2006 4:38 am Post subject: How to add 15kt to cruise speed by adding weight |
To say nothing of having unsecured weight in the tail that, during a
steep climb-out, slips even further back. You have now just been
promoted to test pilot; one that may have his hands...and shorts full.
Chuck Jensen
[quote] --
dreel(at)cox.net Guest
Posted: Wed May 31, 2006 6:39 am Post subject: How to add 15kt to cruise speed by adding weight |
To answer a few questions that came up, I was leaned out during both tests
but I lean by ear and have no fuel flow meter. At 5,500 ft, I have measured
9.2 to 9.4 gph using the 'fly it half an hour on one tank then see how much
it takes to refill the tank' method. To get the aft CG, I added weight to a
fixture I built for the aft baggage shelf and added a 50 lb sand bag to the
aft seat. Total 142 lb. I can refly the forward CG test at the higher
altitude & will report the result. But it will probably be a while because
I'm flying the RV to Brady TX for paint. I'll have to leave it there about
a month. Of course, I'll put everything in the aft baggage compartment for
the flight!
Dave
low pass
Posted: Wed May 31, 2006 7:30 am Post subject: Re: How to add 15kt to cruise speed by adding weight |
| martin(at)gbonline.com wrote: | Joe and others,
added a lead pig (approx 10 lbs) to the tail area of my RV8 to improve the CG. |
I sure don't need any corrective ballast, but am thinking I might see what the effect of moving my battery aft (with an O-320 up front) would have on the CG envelope... Gotta carry it anyway.
batfinks(at)mchsi.com Guest
Posted: Wed May 31, 2006 9:42 pm Post subject: How to add 15kt to cruise speed by adding weight |
I'll bet there are a lot of replies, but that is exactly what you should
expect. With more weight in back, the tail has to produce less lift
(downward) with it's associated lift drag. Just don't move the CG too
far back, there be dragons there.
Scott
DAVID REEL wrote:
I've been exploring the CG range in flight testing of my RV8A and have found
an unanticipated cruise speed effect. At 85.9 inches, I was getting 155kias
with 2300rpm, 23 in mp, 5,500 ft, and 42 degrees F outside. At 79.6 inches,
I got 142kias with 2300rpm, 23 in mp, 4,500 ft, and 64 degrees F outside.
My whiz wheel gives true airspeeds of roughly 169kt and 154kt. Quite an
improvement just by adding some weight in back. Yes, the fast flight was
with a little bit higher weight!
There's lots of discussion of speed improvements in the archives, but
nothing related to CG location that I could find and certainly nothing so
easy to get and of this magnitude. So, my question to everyone is have you
had similar experience? Do you know anywhere this has been quantified or
further detailed? After all, I'm just comparing two test flights here, but
theoretically, I'd guess the decrease in drag due to decreased pitch
stability requirements as the CG moves aft would explain the speed increase.
Excited!
Dave Reel - RV8A
