icubob(at)gmail.com Guest
Posted: Sat Jun 02, 2012 5:15 am Post subject: warp prop |
hi all,
just installed the ''stone guard'' tape on my blades and it is hard to believe how much they hurt the performance. used to be 2850 rpm was 110 mph, now 2950 is onlt 103 mph. anyone have any experience with this?
bob noffs
propellerdesign(at)tele2. Guest
Posted: Sat Jun 02, 2012 6:15 am Post subject: warp prop |
I heard something similar on a RV-6, very interesting, is this a clear PU tape, also called helicopter tape? with a noticeble thickness?
Jan
lcfitt(at)sbcglobal.net Guest
Posted: Sat Jun 02, 2012 6:47 am Post subject: warp prop |
Bob, This is interesting. It reminds me of an article in a recent Kitplanes where airfoils are discussed. One instance mentioned was of a canard airplane which was test flown and everything tweaked to satisfaction, then the builder decided it was time to paint. he put longitudinal stripes on the canard and the paint line after pulling the masking tape caused enough disruption of the laminar flow that handling was seriously compromised.
Lowell
Sent: Saturday, June 02, 2012 6:14 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: warp prop
hi all,
bob noffs
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Posted: Sat Jun 02, 2012 10:49 am Post subject: warp prop |
hi all, yes, this is clear, rather thick tape. since i posted i got a hold of another builder who helped me all the way with advice while building. he had a warp on a cont 85 hp and was very happy with it. when i asked him this morning about the tape he said, ''i guess we never discussed that tape. after i tried it i ripped the (at)#$%^& stuff off , it hurt performance so much. flew without it for 12 yrs. and my prop is still ok.
so mine will come off tomorrow!.
bob noffs
On Sat, Jun 2, 2012 at 9:46 AM, Lowell Fitt <lcfitt(at)sbcglobal.net (lcfitt(at)sbcglobal.net)> wrote:
[quote] Bob, This is interesting. It reminds me of an article in a recent Kitplanes where airfoils are discussed. One instance mentioned was of a canard airplane which was test flown and everything tweaked to satisfaction, then the builder decided it was time to paint. he put longitudinal stripes on the canard and the paint line after pulling the masking tape caused enough disruption of the laminar flow that handling was seriously compromised.
Lowell
Subject: warp prop
hi all,
bob noffs
Posted: Sat Jun 02, 2012 11:47 am Post subject: warp prop |
Bob and Lowell,
This show how sensitive it is, even if we can't compeer and Warp airfoil (RAF6) with a sensitive laminar airfoil, as was used on some canards, I almost said old laminar airfoil, but how old is the RAF6 then
But think that we scale up the prop blade with the Pu tape to the size of a wing, that step where the tape ends will be a giant step for the air.
I asked Sensenich about there new wood propellers with rubber LE if it was must different performance then the old one SS or brass that is certified, but they didn't think it was much difference, even if they had not tested it !
Jan
www.jcpropellerdesign.com
peteohms
Posted: Sat Jun 02, 2012 12:20 pm Post subject: warp prop |
I use tape from Powerfin props on my Ivo prop and it is thinner than others I've used. Seems to be holding up just fine and went on easily.
Pete
Kitfox III/912
Leander, TX
On 6/2/2012 2:46 PM, JC Propeller Design wrote: [quote] Bob and Lowell,
Jan
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
Lynn Matteson
Posted: Sat Jun 02, 2012 12:58 pm Post subject: warp prop |
Could it be any worse than the bugs that decorate the leading edge
of my prop after every flight in the spring/summer/fall?
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with 1276 hrs... (since 3-27-2006)
On Jun 2, 2012, at 9:14 AM, bob noffs wrote:
| Quote: | hi all,
bob noffs
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Sat Jun 02, 2012 1:21 pm Post subject: warp prop |
Bob-
The stuff I use came from Lonnie Prince (Prince Aircraft Co). It is
fairly thin, and a bit tricky to apply, but once on it is virtually
invisible....until covered with bug guts. : )
Lynn Matteson
Jabiru 2200, #2062
On Jun 2, 2012, at 2:49 PM, bob noffs wrote:
| Quote: | hi all, yes, this is clear, rather thick tape. since i posted i got
bob noffs
On Sat, Jun 2, 2012 at 9:46 AM, Lowell Fitt <lcfitt(at)sbcglobal.net>
Lowell
Subject: warp prop
hi all,
bob noffs
forums.matronics.com href="http://www.matronics.com/
contribution">http://www.matronics.com/c arget="_blank">http://
www.matronics.com/Navigator?Kitfox-List tp://forums.matronics.com
N369LM |
7suds(at)Chartermi.net Guest
Posted: Sat Jun 02, 2012 4:21 pm Post subject: warp prop |
Guys,
I run an IVO with the SS Leading edge tape, anyone have any experience with
the SS tape causing a similar concern on the IVO? Anyone running the IVO
without the leading edge protector?
Lloyd Cudnohufsky
Northern Mi.
Model 5 912ul IVO IFA
Rebuilt Ground Looped Project
Status: Flying 8 hrs since rebuild
peteohms
Posted: Sat Jun 02, 2012 4:55 pm Post subject: warp prop |
Lloyd,
I had an Ivo blade throw the metal leading edge tape off while I was in a misting rain getting ready to land to wait out an approaching storm. I think the tape was only a couple months old. I had to remove all the tape on all the blades to proceed. I so far like the Powerfin tape I replaced it with. Easier to apply. Lighter. Goes on smoothly. Sticks better.
Pete
Kitfox III/912
Leander, Tx
Sent from my iPad
On Jun 2, 2012, at 7:20 PM, "Lloyd & Lorrie Cudnohufsky" <7suds(at)Chartermi.net> wrote:
Guys,
Lloyd Cudnohufsky
Northern Mi.
Leander, TX
dwight purdy
Posted: Sun Jun 03, 2012 5:53 am Post subject: warp prop |
Jog my memory. What is the Power Fin tape like?
Dwight Purdy
model II 503
[quote] <pchristensen10(at)austin.rr.com>
Lloyd,
Pete
Kitfox III/912
Leander, Tx
Sent from my iPad
wrote:
> <7suds(at)chartermi.net>
> Guys,
> Lloyd Cudnohufsky
> Northern Mi.
_________________ dwight
model II |
peteohms
Posted: Sun Jun 03, 2012 6:21 am Post subject: warp prop |
Dwight,
Very thin urethane. Mine is black but they also have clear.
Pete
Sent from my iPad
Dwight Purdy
model II 503
> Lloyd,
> Pete
> Kitfox III/912
> Leander, Tx
> Sent from my iPad
>> Guys,
>> Lloyd Cudnohufsky
>> Northern Mi.
Leander, TX
Roger Lee
Posted: Sun Jun 03, 2012 7:45 am Post subject: Re: warp prop |
Buy it from Warp.
It is pre-cut and much thinner than the 3M from places like Spruce.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
